Topic: How to Build Arduino via Eclipse Java? (Read 879 times) previous topic - next topic
Yocttar
Jul 19, 2010, 06:43 am Last Edit: Jul 19, 2010, 07:20 am by Yocttar Reason: 1
Any known guide of how to do this?
This is what I know:
* Download the source code (the svn checkout on google code).
* Load the build.xml file from the "<arduino source folder>/app" folder using ant from within Eclipse Java.
* Try to run processing.run.base (or?).
* this is where I stopped (I got errors).
* Note:
- I'm new to Eclipse Java.
- I use Ubuntu 10.04
- If I've done something wrong, or if you know how to do it with another IDE, I'll be happy if you let me know.
Basically I just want to be able to debug the whole thing eventually, but the first step would be building it.
Oh and another thing, the build process using the terminal which is explained on the wiki at google code doesn't work:
Code: [Select]
victor@victor-desktop:~/Documents/OpenSource/arduinoro2/build$ ant
Buildfile: build.xml
build:
revision-check:
linux-checkos:
subprojects-build:
compile:
 [methods] No changes to PApplet API.
   [mkdir] Created dir: /home/victor/Documents/OpenSource/arduinoro2/core/bin
   [javac] Compiling 34 source files to /home/victor/Documents/OpenSource/arduinoro2/core/bin
build:
     [jar] Building jar: /home/victor/Documents/OpenSource/arduinoro2/core/core.jar
compile:
   [mkdir] Created dir: /home/victor/Documents/OpenSource/arduinoro2/app/bin
   [javac] Compiling 67 source files to /home/victor/Documents/OpenSource/arduinoro2/app/bin
   [javac] Note: Some input files use unchecked or unsafe operations.
   [javac] Note: Recompile with -Xlint:unchecked for details.
build:
     [jar] Building jar: /home/victor/Documents/OpenSource/arduinoro2/app/pde.jar
linux-build:
   [mkdir] Created dir: /home/victor/Documents/OpenSource/arduinoro2/build/linux/work
    [copy] Copying 15 files to /home/victor/Documents/OpenSource/arduinoro2/build/linux/work
    [copy] Copying 1 file to /home/victor/Documents/OpenSource/arduinoro2/build/linux/work
    [copy] Copying 6 files to /home/victor/Documents/OpenSource/arduinoro2/build/linux/work/lib
assemble:
    [copy] Copying 3 files to /home/victor/Documents/OpenSource/arduinoro2/build/linux/work/tools
    [copy] Copied 5 empty directories to 2 empty directories under /home/victor/Documents/OpenSource/arduinoro2/build/linux/work/tools
    [copy] Copying 88 files to /home/victor/Documents/OpenSource/arduinoro2/build/linux/work/libraries
    [copy] Copied 57 empty directories to 1 empty directory under /home/victor/Documents/OpenSource/arduinoro2/build/linux/work/libraries
    [copy] Copying 41 files to /home/victor/Documents/OpenSource/arduinoro2/build/linux/work/hardware
    [copy] Copying 47 files to /home/victor/Documents/OpenSource/arduinoro2/build/linux/work/examples
   [unzip] Expanding: /home/victor/Documents/OpenSource/arduinoro2/build/shared/reference.zip into /home/victor/Documents/OpenSource/arduinoro2/build/linux/work
    [copy] Copying 2 files to /home/victor/Documents/OpenSource/arduinoro2/build/linux/work/hardware
BUILD SUCCESSFUL
Total time: 8 seconds
victor@victor-desktop:~/Documents/OpenSource/arduinoro2/build$ ant run
run:
revision-check:
linux-checkos:
subprojects-build:
compile:
build:
compile:
build:
linux-build:
assemble:
linux-run:
BUILD FAILED
/home/victor/Documents/OpenSource/arduinoro2/build/build.xml:33: The following error occurred while executing this line:
/home/victor/Documents/OpenSource/arduinoro2/build/build.xml:310: Execute failed: java.io.IOException: Cannot run program "linux/work/arduino" (in directory "/home/victor/Documents/OpenSource/arduinoro2/build/linux/work"): java.io.IOException: error=2, No such file or directory
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
