Topic: updated OSC library for 0021 (Read 2911 times) previous topic - next topic
nickv
I've done a little bit of work and updated Recotana's OSC library to work with 0021. I haven't tested it extensively so please let me know how it work out for you.
Download Library:
http://www.makesomecode.com/wp-content/uploads/2010/11/OSCClass.zip
razic
can you show the code you used to get this working?
DodgyBob
I tried to get it working but it doesn't seem to do anything with the standard LED example sketch :-/
Code: [Select]
// OSCClass iOSC(iPhone App) test sketch
// OSCClass version 1.0.1 (Arduino ver0014)
// Copyright (c) recotana.  All right reserved.
iOSC setting
           OSCMessage    type  value on  off
button1    /ard/ledyel    int          1   0   :info-AlternateMode "ON" =toggle sw
button2    /ard/ledgrn    int          1   0
button3    /ard/ledred    int          1   0
slider1    /ard/ledpwm    int  min:0 max:255
host setting IP address 192.168.1.99 , port 10000
#include "Ethernet.h"
#include "OSCClass.h"
#include "SPI.h"
#define  LED_RED 2
#define  LED_GRN 3
#define  LED_YEL 4
#define  LED_PWM 6
 OSCMessage recMes;
 OSCClass osc(&recMes);
 byte serverMac[] = { 0x90, 0xA2, 0xDA, 0x00, 0x2A, 0x69 };
 byte serverIp[]  = { 192, 168, 1, 99 };
 int  serverPort  = 10000;
 byte gateway[]   = { 192, 168, 1, 1 };
 byte subnet[]    = { 255, 255, 255, 0 };
 char *topAddress="/ard";
 char *subAddress[4]={ "/ledred" , "/ledgrn" , "/ledyel" , "/ledpwm"};
      //for message logging
   Serial.begin(19200);
 //  Ethernet.begin(serverMac ,serverIp);
 Ethernet.begin(serverMac ,serverIp ,gateway ,subnet);
    //setting osc recieve server
    osc.begin(serverPort);
    pinMode(LED_RED, OUTPUT);
    pinMode(LED_GRN, OUTPUT);
    pinMode(LED_YEL, OUTPUT);
    pinMode(LED_PWM, OUTPUT);
    digitalWrite(LED_RED, HIGH);  //LED OFF
    digitalWrite(LED_GRN, HIGH);  //LED OFF
    digitalWrite(LED_YEL, HIGH);  //LED OFF
    digitalWrite(LED_PWM, HIGH);  //LED OFF
   //osc message buffer clear
    osc.flush();
   //osc arrive check
   if ( osc.available() ) {
logMessage(&recMes);
         //toplevel address matching
         if( !strcmp( recMes.getAddress(0) , topAddress ) ){
             //second level address matching
               if( !strcmp( recMes.getAddress(1) , subAddress[0] ) ){
                     red();
               else if( !strcmp( recMes.getAddress(1) , subAddress[1] ) ){
                     green();
               else if( !strcmp( recMes.getAddress(1) , subAddress[2] ) ){
                     yellow();
               else if( !strcmp( recMes.getAddress(1) , subAddress[3] ) ){
                     pwm();
void red(){
  if(recMes.getArgInt(0) == 1){
         digitalWrite(LED_RED, LOW);  //LED_ON
  else{
void green(){
         digitalWrite(LED_GRN, LOW);  //LED_ON
  else{
void yellow(){
         digitalWrite(LED_YEL, LOW);  //LED_ON
  else{
void pwm(){
 byte value=(byte)recMes.getArgInt(0);
 analogWrite(LED_PWM, 255-value);
// *********  utility  ***********************************
void logMessage(OSCMessage *mes){
   uint8_t *ip=mes->getIp();
    //disp ip & port
   Serial.print("from IP:");
   Serial.print(ip[0],DEC);
   Serial.print(".");
   Serial.print(ip[1],DEC);
   Serial.print(".");
   Serial.print(ip[2],DEC);
   Serial.print(".");
   Serial.print(ip[3],DEC);
   Serial.print(" port:");
   Serial.print(mes->getPort(),DEC);
   Serial.print("   ");
   //disp adr
   for(int i = 0 ; i < mes->getAddressNum() ; i++){
     Serial.print(mes->getAddress(i));
   //disp type tags
   Serial.print("  ,");
   for(int i = 0 ; i < mes->getArgNum() ; i++){
     Serial.print(mes->getTypeTag(i));
   Serial.print(" ");
  //disp args
     switch( mes->getTypeTag(i) ){
       case 'i': {
                     Serial.print( mes->getArgInt(i) );
       case 'f':  {
                     Serial.print( mes->getArgFloat(i) );
      Serial.print(" ");
   Serial.println("");
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
