Topic: HOWTO avrdude+linux+diecimila (Read 2313 times) previous topic - next topic
Triffid Hunter
This short howto covers uploading from a terminal without using the arduino software at all.
1) howto reset diecimila, then upload with avrdude just like arduino software
stty 19200 raw ignbrk hup < /dev/arduino && avrdude -cstk500 -b19200 -pm168 -P/dev/arduino
The key here is the 'hup' attribute which tells linux to toggle the DTR pin when the port is opened and closed. The DTR pin going low when the port is opened is what causes the diecimila to reset, so this is perfect.
NOTE: some linux kernels in the 2.6.22+ range had a bug in the ft232 driver where DTR is never de-asserted on close. Symptoms are, even with above code, diecimila only resets the first time you program after plugging in. patch is available at http://lkml.org/lkml/2007/10/6/14 if you are affected.
I put both of the above in a script for easy reference. Replace /dev/arduino with /dev/ttyUSB0 or whatever it is on your system, or continue reading
2) howto ask udev to create a /dev/arduino symlink for you
I added
SUBSYSTEMS=="usb", ATTRS{product}=="FT232R USB UART", ATTRS{idProduct}=="6001", ATTRS{idVendor}=="0403", NAME="%k", SYMLINK+="arduino", MODE="0660"
to /etc/udev/rules.d/10-local.rules
If you'd like it to create particular symlinks for particular arduinos, run
udevinfo -a -p /sys/bus/usb/drivers/ftdi_sio/* | grep serial
and add the first line to the above udev rule with appropriate commas. The rule might look like:
SUBSYSTEMS=="usb", ATTRS{product}=="FT232R USB UART", ATTRS{serial}=="A1001Ncz", NAME="%k", SYMLINK+="arduino_1", MODE="0660"
which will create a /dev/arduino_1 symlink only for ft232R chips with that serial number.
D-rock
Just wanted to say thanks for posting this info.
Triffid Hunter
Just thought I'd add that I successfully reprogrammed the FT232RL on my diecimila to request 500mA from my USB port. See MProg tool from ftdichip.com. Unfortunately, I had to run it in virtualbox, ftdi_eeprom appariently doesn't support ft232R yet due to insufficient documentation from ftdi :(
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
