Topic: AS3Glue: Send commands to OneWire Thermometer (Read 2945 times) previous topic - next topic
DaveUCSD
Hello!!
I am trying to get the Dallas Semiconductor DS18B20 Digital Thermometer (http://www.arduino.cc/playground/Learning/OneWire) to communicate with Flash AS3 via the AS3Glue protocol and Firmata 2.0.
For those of you who may be a bit fuzzy about this, here's a quick breakdown.
  • OneWire is attached to an Arduino Digital Pin
    Firmata 2.0 is on the Arduino
    The Firmata sends data to Flash via the SerProxy application
    Flash communicates with Firmata via the AS3Glue library
Sooo... In Flash, I am trying to send "ds.write(0xBE);" to the OneWire using something like the arduino.writeDigitalPin () function. :-?
The working arduino code has this main bit: (The full code is attached.)
Code: [Select]
ds.reset();
 ds.select(8);
 ds.write(0x44,1);         // Start Converting Temp Data
 delay(600);
 present = ds.reset();
 ds.select(8);
 ds.write(0xBE);         // Read Temp Data
 for ( i = 0; i < 9; i++) {           // we need 9 bytes
     data[i] = ds.read();
In flash, I have this (doesn't work...yet):
Code: [Select]
var timer6:Timer = new Timer(600,1);
timer6.start();
var resetT:String = "ds.reset()";
var startConversion:String = "ds.write(0x44,1)";
var getConversion:String = "ds.write(0xBE)";
function setUpTherm (e:Object):void {
   arduino.writeDigitalPin(8,resetT);
   arduino.writeDigitalPin(8,startConversion);
   timer6.addEventListener("timer", getTemp);
function getTemp(e:TimerEvent) {
   arduino.writeDigitalPin(8,("getConversion"));
       data[i] = arduino.writeDigitalPin(8,("ds.read()"));
   temperature.text = CTemp.toString();
This taps into a bigger question of how to send info to the digital pins from Flash using more than just HIGH or LOW commands.
Please throw in your 2 cents!! Thanks so much!!
HERE ARE THE FILES:  http://rapidshare.com/files/188937417/OneWire.zip.html
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
