Topic: structures and pointers (Read 960 times) previous topic - next topic
cappy2112
I don't see structs/unions nor pointers in the compiler reference.
Please, someone tell me this compiler supports structures and pointers.
Arduino Reference (extended)
The Arduino language is based on C/C++ and supports all standard C constructs and some C++ features. It links against AVR Libc and allows the use of any of its functions; see its user manual for details.
westfw
Yes, of course it supports pointers and structures.  Here's a snip from some menu code I wrote (which appears to work.)
Code: [Select]
typedef void * menu_action_t;
typedef const struct menu_item_ {
   unsigned char menu_key;
   menu_action_t menu_action;      /* function or menu pointer */
} menu_item_t;
mem
The Arduino uses the GCC compiler, which is ISO 90 compliant so as westfw says, you get full support for the C language including structures and unions.
You can find the documentation on the compile includingISO compliance documentation here: http://gcc.gnu.org/onlinedocs/gcc-4.1.2/gcc/
When I first came across the Arduino, I was surprised that the underlying language was a complete implementation of C and C++. There is little clue to that in the Arduino documentation, perhaps so as not scare away beginners to programming. But so far the compiler has coped with every C and C++ construct that I have thrown into my sketches.
cappy2112
Quote
Yes, that is correct. Well, I'm glad to see it supports full C capabilities.
Can't live without structures and pointers
Thanks for clarifying
westfw
Quote
I don't recall exactly how I came across arduino, but I always knew that gcc was underneath (and not "deep", either.)  I think the "C subset" structure is a wonderful idea, and of course I like having full C available for the more complex things that I'm used to.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
