Topic: Comparing 2 strings (Read 50255 times) previous topic - next topic
maddog_rvo
The function below is not working properly, how can i compare 2 strings?
I send "temperat" to the arduino through the serial port, so the IF statement should return the analog value, only it doesnt work, it only prints back:
"Received: temperat"
How should i alter the IF statement?
I already tried comparing 2 char arrays
(received and command)
char command[8];
char received[8] = {'t','e','m','p','e','r','a','t'}'
 if (Serial.available() == 8)
   for (int i=0; i < 8; i++)
     command = Serial.read();
   if (command == "temperat")
       val = analogRead(0);
       Serial.print(val,DEC);
   Serial.print("Received: ");
   Serial.print(command);
mem
There are a few functions you can call to compare strings. strcmp is the most basic, it takes the two strings to be compared as parameters and returns 0 if the strings are equal.
you would use it as follows:
 if (Serial.available() >= 8)   // this was == 8, more than one command may be waiting
   if (strcmp(command, "temperat")  == 0)  // test to see if the two strings are equal
BTW, i changed  the test for serial available so that it will work if more than one command is received at the  serial port when the sketch checks to see if charactors are available
maddog_rvo
Quote
Cool thanks for the fast response  ;D
tkbyd
Would it be appropriate to add strcmp to...
http://www.arduino.cc/en/Reference/Extended
... and the keywords list?
Does any library need to be #included to use strcmp?
Is there a different place to find strcmp? Any other "hidden" keywords?
mem
> Would it be appropriate to add strcmp to...  http://www.arduino.cc/en/Reference/Extended
The reference page on strings http://www.arduino.cc/en/Reference/String would be a good place to mention the comparison functions
String handling functions like strcmp are declared in string.h but the Arduino environment seems to include this automatically.
A good book on C should list these library functions and you can find a references to C library functions by doing an online search for words like: c language reference
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
