Topic: Is it possible to count time in Arduino? (Read 11179 times) previous topic - next topic
Oldbeaver
Hello everybody!
Vanessa Schauer developed a good clock and alarm for Arduino. I don´t know if she logs in at present.
Anyway, I wonder if we can have a reasonable exact measure of time based on Arduino hardware. Something simple, but necessary to many applications.
Is anyone in possession of this knowledge?
Thank you in advance,
OldBeaver
8-)
mem
There is a Date and Time library in the playgound that makes it easy to keep time using no extra hardware and is accurate to a few seconds per day.
see: http://www.arduino.cc/playground/Code/DateTime
Oldbeaver
Dear Mem,
I tried to make a little time counter, but don´t work.
Well, my idea is to use the time counter in minutes and seconds only.
Anyway, the compiler says: "LiquidCrstal does not name a type In function void loop(); in function "void lcdPrintFloat(float, byte)"
Something is wrong. Here´s the code:
#include <LiquidCrystal.h>
//create object to control an LCD.
LiquidCristal lcd(12, 11, 2, 7, 8, 9, 10);
void setup(){
void loop(){
 static float sec;
 static float min;
 static float hour;
 float value;
 value = millis();
 lcd.clear();
 if value == 1000;{
   sec=sec + 1;
 value = 0;
 if(sec==60);{
   min=min+1;
 sec=0;
 if(min==60) {
 hour=hour+1;
 min=0;
 //if(hour==24) {
 // hour=0;
 lcd.setCursor(0,0);
 lcd.print("Min=");
 lcd.setCursor(1,6);
     x = min;
     lcdPrintFloat(x,1);
 lcd.setCursor(0,1);
 lcd.print("Sec=");
 lcd.setCursor(2,6);
     x = sec;
     lcdPrintFloat(x,2);
 digitalWrite(13,LOW);
 delay (1000);
 digitalWrite(13,HIGH);
 void lcdPrintFloat(float x, byte precision){
   lcd.print((long)x);
Will take a look to the solution you mention.
OldBeaver
mem
#3
Nov 23, 2008, 09:05 pm Last Edit: Nov 23, 2008, 09:08 pm by mem Reason: 1
The compiler is giving you good advice. [glow]LiquidCristal[/glow]  is not a valid name for a type it  know about.  It's a typo, you meant write [glow]LiquidCrystal[/glow].
I expect there are other syntax errors in that code. If you study the compiler messages you should be able to fix them.
p.s. watch out for semicolons:
this:
if(sec==60)[glow];[/glow]{
  min=min+1;
  sec=0;
I think should be this:
if(sec==60){
  min=min+1;
  sec=0;
Oldbeaver
Ha, ha, ha !!!  Yes, you are right.
Thank you!
I got the DateTime library, loaded the clock example it comes with. The example was made to be seen on a serial display. I don´t know how to do that, but anyway, that is not what I need. I tried to modify it, to make it capable of printing in the LCD display.
Below is what I made. It passes the compiler scrutiny, but nothing is shown on the LCD. Here's the code:
#include <DateTime.h>
#include <DateTimeStrings.h>
LiquidCrystal lcd(12, 11, 2, 7, 8,9, 10);
void setup(){
 pinMode(13,OUTPUT); // we flash the LED each second
void  loop(){
 unsigned long prevtime;
 if( getPCtime()) {  // try to get time sync from pc
   lcd.setCursor(0,0);
   lcd.print("PCClock:");
   lcd.setCursor(7,0);
   lcdPrintFloat(DateTime.now(),DEC);
 if(DateTime.available()) { // update clocks if time has been synced
   digitalWrite(13,LOW);  // first flash the LED
   prevtime = DateTime.now();
   while( prevtime == DateTime.now() )  // wait for the second to rollover
   DateTime.available(); //refresh the Date and time properties
 delay(100);
 boolean getPCtime() {
 // if time sync available from serial port, update time and return true
 //while(Serial.available(); >=  TIME_MSG_LEN ){  // time message consists of a header and ten ascii digits
    char TIME_HEADER;
    char TIME_MSG_LEN;
    if( Serial.read() == TIME_HEADER ) {
    time_t pctime = 0;
    for(int i=0; i < TIME_MSG_LEN -1; i++){
      char c= Serial.read();
      if( c >= '0' && c <= '9'){
        pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
     DateTime.sync(pctime);   // Sync Arduino clock to the time received on the serial port
     return true;   // return true if time message received on the serial port
 return false;  //if no message return false
 // digital clock display of current date and time
 void lcdPrintFloat(float x, byte digits){
 lcd.print(DateTime.Hour,DEC);
 lcd.print(DateTime.Minute);
 lcd.print(DateTime.Second);
 lcd.print(" ");
 lcd.print(DateTimeStrings.dayStr(DateTime.DayofWeek));
 lcd.print(" ");
 lcd.print(DateTimeStrings.monthStr(DateTime.Month));
 lcd.print(" ");
 lcd.print(DateTime.Day,DEC);
void printDigits(byte digits){
 // utility function for digital clock display: prints preceding colon and leading 0
 lcd.print(":");
 if(digits < 10)
   lcd.print('0');
 lcd.print(digits,DEC);
Any ideas?
Jose
mem
You need to set the time. try this setup code to start the clock at 11pm today:
void setup(){
 time_t t = DateTime.makeTime( 23, 0, 03, 23, 11, 2008 );
 DateTime.sync( t );
Oldbeaver
Well, hello, here is my own program for counting time. The only problem is it doesn't work out.
Here is the code:
 LiquidCrystal lcd(12, 11, 2, 7, 8, 9, 10);
 void setup(){
 void loop(){
 float x;
 static float sec;
 static float min;
 static float hour;
 unsigned long value;
 lcd.clear();
 value = millis();
 if (value==1000){
   sec=sec + 1;
 if(sec==60){
   min=min+1;
   sec=0;
 //if(min==60) {
 //  hour=hour+1;
 //  min=0;
 //if(hour==24) {
 // hour=0;
   lcd.setCursor(0,0);
   lcd.print("Sec=");
   lcd.setCursor(6,0);
   x = sec;
   lcdPrintFloat(x,1);
   lcd.setCursor(0,1);
   lcd.print("Min=");
   lcd.setCursor(6,1);
   x = min;
   lcdPrintFloat(x,2);
 delay (1000);
   lcd.print(long(x));
Actually, it is working partially, but in displaying time.
I will make a check to see if time is actually calculated but not displayed, or none of them.
Any ideas?
Old Beaver
Oldbeaver
Ok Mem, tks for the suggestion. I will try to test that sketch.
What I actually need, is count the time in minutes, since I start a test trip, or a long trip. By the way, how can I reset the program?
I have this sketch, where the if cicles do not work, I don´t know why.
However, the counting of time by assignment of value = millis() is working, cause I have made some test divisions later in the program.
This is my present code:
 void setup(){
 void loop(){
 float tank;
 tank = analogRead(1);
 float spend;
 float x;
 int sec;
 int min;
 int hour;
 unsigned long value;    // value states for time in milliseconds
 lcd.clear();
 value = millis();
 if (value == 1000){
 sec = sec++;                     //this doesn´t work
 value = 0 ;
   if(sec==60){
   min=min++;                   // and this either
   sec=0;
     if(min==60) {
     hour=hour++;              // neither do this
     min=0;
 /* ---------- Prints seconds ------------ */
   lcd.setCursor(0,0);
   lcd.print("Sec");
   lcd.setCursor(5,0);
   x = sec;
   lcdPrintFloat(x,1);
 /* --------- Prints minutes ----------- */
   lcd.setCursor(0,1);
   lcd.print("Min");
   lcd.setCursor(5,1);
   x = min;
   lcdPrintFloat(x,2);
/* ------- Print Tank values ------- */
   lcd.setCursor(8,0);
   lcd.print("Tank");
   lcd.setCursor(14,0);
   x = tank;
   lcdPrintFloat(x,1);
/* ------- Print Spend values ------- */
   spend = (55-tank)/min;
   lcd.setCursor(8,1);
   lcd.print("Spend");
   lcd.setCursor(14,1);
   x = spend;
   lcdPrintFloat(x,1);
 delay (1000);                        // this is flashing
   lcd.print(long(x));
Oldbeaver
I made a short sketch trying to test your adviced variables, unsuccessfully.
I assumed time_t is a string, and t is a floating number. Couldn´t find any reference about this new library.
Here is my sketch:
void setup(){
DateTime.sync( t );
 void loop(){
 char time_t[10];
 float t;
 /* --------- Prints time string ----------- */
   lcd.setCursor(0,0);
   lcd.print(time_t);
   lcd.setCursor(0,1);
   lcd.print(t,3);
  digitalWrite(13, LOW); //light the LED
  delay (1000);
  digitalWrite(13, HIGH);  //
The led blinks shortly, and some characters show for time_t and a zero for t.
That is it so far.
Greetings, Jose
mem
#9
Nov 24, 2008, 09:04 am Last Edit: Nov 24, 2008, 01:03 pm by mem Reason: 1
There are no floats used in the DateTime library. Time is maintained as a count in seconds from a particular point in time. The type used to hold the count is defined as a time_t  and is an unsigned long value.
Here is a sketch that uses the library to display elapsed minutes on one line and elapsed hours and minutes on the second line:
Code: [Select]
int resetPin = 3; // pin 3 resets the time
void setup(){
 pinMode(resetPin, INPUT); // a button on this pin resets the time
 DateTime.sync( 0 );  // set time to zero
void loop(){
 if(digitalRead(resetPin) == LOW)
     DateTime.sync( 0 );  // reset time to zero if button pressed
 /* --------- Prints time in minutes and hours ----------- */
 DateTime.available(); // needed to refresh the clock time
 time_t timeNow = DateTime.now();
 lcd.setCursor(0,0);
 lcd.print(timeNow/60);  // this is total elapsed minutes
 lcd.setCursor(0,1);
 lcd.print(DateTime.Hour,DEC);  // this is the total hours (up to 24)
 lcd.print(":");
 lcd.print(DateTime.Minute,DEC); // and minutes since reset
 delay (1000);
Its not tested but I hope gets you going in the right direction.
Oldbeaver
Dear Mem,
Received and many thanks to you.
Will test it today.
I will post the results.
Greetings,
Oldbeaver
Oldbeaver
Dear Mem and all,
I tested the sketch in the following format:
//create object to control an LCD GMD1602K.
void setup(){
void loop(){
 /* --------- Prints time in hours, minutes and seconds ----------- */
 lcd.setCursor(0,0);
 lcd.setCursor(0,8);
 lcd.print(timeNow/360); // checking total elapsed seconds
 lcd.setCursor(0,0);
 lcd.print("Hour:min");
 lcd.setCursor(10,0);
 lcd.print(":");
 lcd.setCursor(0,1);
 lcd.print("Sec");
 lcd.setCursor(10,1);
 lcd.print(DateTime.Second,DEC); // and seconds since reset
 delay (1000);
The code compiles ok, and run. But only the flashing debug led is got as output. The titles print ok on the lcd screen, the numbers print, but as zeros only.
I added seconds as a way of debug.
Test it yourself, maybe you discover the problem.
I also tested the sketch as you sent it, and it printed only zeros.
Greetings,
Oldbeaver. :(
mem
#12
Nov 24, 2008, 01:52 pm Last Edit: Nov 24, 2008, 01:54 pm by mem Reason: 1
Perhaps you don't have the reset pin wired up, it needs to have a pull-up so its value is high except when a button is pressed.
You could use an internal pull-up. Add the following line to setup
digitalWrite(resetPin,HIGH); [glow]// add this line to  enable pull-up [/glow]
also, you may want to look at the example sketch for the DateTime library to see how you can format the time so that minutes is always displayed using two digits
Oldbeaver
Hi Mem and all,
The sketch is working fine now.
Here it is:
void setup(){
 digitalWrite(resetPin,HIGH);  // this line enables pull-up
void loop(){
 lcd.setCursor(0,0);
 lcd.print(timeNow/60);        // total elapsed minutes
 lcd.setCursor(0,8);
 lcd.print(timeNow/3600);    //  total elapsed seconds
 lcd.setCursor(0,0);
 lcd.print(DateTime.Hour,DEC);      // prints total hours (up to 24)
 lcd.print(":");
 lcd.setCursor(0,1);
 lcd.print("Sec");
 lcd.print(" ");                               // clears second digit every minute
 digitalWrite(13, LOW);                  //light the LED every second
 delay (1000);
Do you people know where can one get the documents of libraries? For example "Liquid Crystal.h" and "DateTime.h" ?
Is there any updated or more complete manual about programming Arduino than the Brian W. Evan's "Arduino Programming Notebook"?
Thanks much for the help got, specially to Mem.
Oldbeaver.
mem
#14
Nov 24, 2008, 10:46 pm Last Edit: Nov 24, 2008, 10:53 pm by mem Reason: 1
Good to hear its working.
You can find info on the Liquid Crystal library in the Arduino reference and info on DateTime in the arduino playground.
Massimo Banzi has published a book on getting started with the Arduino: http://www.amazon.com/Getting-Started-Arduino-Make-Projects/dp/0596155514
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
