Topic: Problem with java.lang.StackOverflowError (Read 858 times) previous topic - next topic
HighFever73
I have written a program, and expanded it abit to breakout some code into routines, and when I try to compile it I get 'java.lang.StackOverflowError'. :(
I have got ver 12 Alpha of the compiler, running on Vista.  I have also re-installed java, but have no idea how to check the version.
Any ideas of how to fix would be very welcome 8-).
Thanks,
Martin
Here is the code:
Code: [Select]
/*          Wheel encoder multi test 4
*    This test is designed to test 6 motor driver
*  Mapping so far (Default direction in bracketts):
*   1-Not Working
*   2-Base     (CounterClockwise)
*   7-Shoulder (ClockWise)
*   4-Not Working
*   5-Gripper   (Close)
       int MotorSpeed1 = 0;
       int MotorSpeed2 = 0;
       int MotorSpeed3 = 0;
       int MotorSpeed4 = 0;
       int MotorSpeed5 = 0;
       int MotorSpeed6 = 0;
       int PinPulse1 = 3;
       int PinDirection1 = 2;
       int PinPulse2 = 5;
       int PinDirection2 = 4;
       int PinPulse3 = 6;
       int PinDirection3 = 7;
       int PinPulse4 = 9;
       int PinDirection4 = 8;
       int PinPulse5 = 10;
       int PinDirection5 = 12;
       int PinPulse6 = 11;
       int PinDirection6 = 13;
       int SerialStreamByte = -1;
       int StepSize = 128;
           for (int x = 2; x < 14; x++)
               pinMode(x, OUTPUT);
               digitalWrite(x, LOW);
           Serial.println("P4 Ready");
          // ExecCommand('r');
           SerialStreamByte = ListenForCommand();
           if (SerialStreamByte != -1)
               ExecCommand(SerialStreamByte);
               DebugMotorSpeeds()
               LimitHardware();
               InterfaceHardware();
       int ListenForCommand()
           if (Serial.available() > 0)
               return Serial.read();
           return -1;
       void LimitHardware()
           MotorSpeed1 = constrain(MotorSpeed1, -255, 255);
           MotorSpeed2 = constrain(MotorSpeed2, -255, 255);
           MotorSpeed3 = constrain(MotorSpeed3, -255, 255);
           MotorSpeed4 = constrain(MotorSpeed4, -255, 255);
           MotorSpeed5 = constrain(MotorSpeed5, -255, 255);
           MotorSpeed6 = constrain(MotorSpeed6, -255, 255);
       void InterfaceHardware()
           analogWrite(PinPulse1, abs(MotorSpeed1));
           digitalWrite(PinDirection1, MotorSpeed1 > 0 ? HIGH : LOW);
           analogWrite(PinPulse2, abs(MotorSpeed2));
           digitalWrite(PinDirection2, MotorSpeed2 > 0 ? HIGH : LOW);
           analogWrite(PinPulse3, abs(MotorSpeed3));
           digitalWrite(PinDirection3, MotorSpeed3 > 0 ? HIGH : LOW);
           analogWrite(PinPulse4, abs(MotorSpeed4));
           digitalWrite(PinDirection4, MotorSpeed4 > 0 ? HIGH : LOW);
           analogWrite(PinPulse5, abs(MotorSpeed5));
           digitalWrite(PinDirection5, MotorSpeed5 > 0 ? HIGH : LOW);
           analogWrite(PinPulse6, abs(MotorSpeed6));
           digitalWrite(PinDirection6, MotorSpeed6 > 0 ? HIGH : LOW);
       void DebugMotorSpeeds()
           Serial.print("MotorSpeed 1=");
           Serial.print(MotorSpeed1, DEC);
           Serial.print("            MotorSpeed 2=");
           Serial.print(MotorSpeed2, DEC);
           Serial.print("            MotorSpeed 3=");
           Serial.print(MotorSpeed3, DEC);
           Serial.print("            MotorSpeed 4=");
           Serial.print(MotorSpeed4, DEC);
           Serial.print("            MotorSpeed 5=");
           Serial.print(MotorSpeed5, DEC);
           Serial.print("            MotorSpeed 6=");
           Serial.print(MotorSpeed6, DEC);
       void ExecCommand(int Command)
           switch (Command)
               case 'r':
                   Serial.println("Reset");
                   MotorSpeed1 = 0;
                   MotorSpeed2 = 0;
                   MotorSpeed3 = 0;
                   MotorSpeed4 = 0;
                   MotorSpeed5 = 0;
                   MotorSpeed6 = 0;
               case '1':
                   MotorSpeed1 += StepSize;
               case '!':
                   MotorSpeed1 -= StepSize;
               case '2':
                   MotorSpeed2 += StepSize;
               case '\"':
                   MotorSpeed2 -= StepSize;
               case '7':
                   MotorSpeed3 += StepSize;
               case '&':
                   MotorSpeed3 -= StepSize;
               case '4':
                   MotorSpeed4 += StepSize;
               case '$':
                   MotorSpeed4 -= StepSize;
               case '5':
                   MotorSpeed5 += StepSize;
               case '%':
                   MotorSpeed5 -= StepSize;
               case '6':
                   MotorSpeed6 += StepSize;
               case '^':
                   MotorSpeed6 -= StepSize;
Anachrocomputer
Could you try something for me please?  Could you change the line:
Code: [Select]
               case '\"':
to:
Code: [Select]
               case 34:
and then recompile and see if anything changes.  I've seen a stack-dump recently where a mis-matched quote was present in a source file.  I'm suspicious of that escaped double quote.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
