Topic: question about creating functions (Read 961 times) previous topic - next topic
pam
Hi. I wrote the code below to fade in and out the three colors on a rgb LED on three different "schedules" to get this nice sorta continuously changing color thing.  It's working fine, but I was wondering if anyone has any ideas on perhaps making the fading routine into a function. I can see how to do it, except for the problem with updating the boolean flag. Can I have multiple return values? That would be great, but not sure if it's possible.
Code: [Select]
#define R_LED 11    // defining 3 pins for the 3 colors of the LED
#define G_LED 9
#define B_LED 10
int r = 0;         // variables for brightness for each led
int g = 0;
int b = 0;
boolean r_dir = 1;     // variables to flag for direction up or down
boolean g_dir = 1;     // for fades
boolean b_dir = 1;
     //  nothing to setup
void loop()  {
 // loop, one per color for fades
 if(r_dir)  {
   r = r + 3;              // increment up
   if (r >= 252) {
     r_dir = 0;             //change direction
 else  {
   r = r - 3;              // increment down
   if (r <= 0)   {
     r_dir = 1;             // change direction
 // now for green
 if(g_dir)  {
   g = g + 5;              // increment up
   if (g >= 250) {
     g_dir = 0;             //change direction
 else {
   g = g - 5;              // increment down
   if (g <= 0)   {
     g_dir = 1;             // change direction
 // and for blue
  if(b_dir)  {
   b = b + 7;              // increment up
   if (b >= 248) {
     b_dir = 0;             //change direction
 else {
   b = b - 7;              // increment down
   if (b <= 0)   {
     b_dir = 1;             // change direction
//  now to write the values
analogWrite(R_LED, r);
analogWrite(G_LED, g);
analogWrite(B_LED, b);
delay(50);
Any help would be greatly appreciated!
thanks
pam
AWOL
#1
Jun 17, 2009, 09:42 am Last Edit: Jun 17, 2009, 10:08 am by AWOL Reason: 1
It's already in a function - "loop()"     ;)
You can't return multiple values from a function, but you could pass a single pointer to multiple parameters, using a structure, and a pointer to it into your function;
Code: [Select]
typedef struct {
 int currentVal;
 boolean direction;
 byte increment;
 byte LEDpin;
} colour_t;
colour_t red = {0, 1, 3, R_LED};
colour_t green = {yadda-yadda};
void update (colour_t* LED)
 if (LED->direction)
etc, and so-on.
update (&red);
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
pam
thanks for the helpful response!  I had a feeling that was the answer :)
pam
AlphaBeta
Just to give you more options:
Quote
const byte analogPin1 = 0;
const byte analogPin2 = 1;
const byte analogPin3 = 2;
int value1 = 0;
int value2 = 0;
int value3 = 0;
void readAnalogValuesInto(int &pin1, int &pin2, int &pin3);
void setup(){
 pinMode(analogPin1,INPUT);
 pinMode(analogPin2,INPUT);
 pinMode(analogPin3,INPUT);
void loop(){
 readAnalogValuesInto(value1,value2,value3);
 Serial.print(value1);
 Serial.print(" ");
 Serial.print(value2);
 Serial.print(" ");
 Serial.println(value3);
This function will not return anything,
but will modify the values passed down as arguments
void readAnalogValuesInto(int &pin1, int &pin2, int &pin3){
 pin1 = analogRead(analogPin1);
 pin2 = analogRead(analogPin2);
 pin3 = analogRead(analogPin3);
This is called: Passing values by reference.
rFree
#4
Jun 18, 2009, 06:38 am Last Edit: Jun 18, 2009, 06:38 am by rFree Reason: 1
Keep in mind I only know C and not C++, but in C your could would be a bit different:
Code: [Select]
int value1;
int value2;
int value3;
void readAnalogValuesInto(int *pin1, int *pin2, int *pin3);
void setup(){
void loop(){
readAnalogValuesInto(&value1, &value2, &value3);
Serial.print(" ");
Serial.print(" ");
void readAnalogValuesInto(int *pin1, int *pin2, int *pin3){
*pin1 = analogRead(analogPin1);
*pin2 = analogRead(analogPin2);
*pin3 = analogRead(analogPin3);
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
