Topic: Virtual Wire compile error (Read 2915 times) previous topic - next topic
HULK
Jul 18, 2009, 03:42 pm Last Edit: Jul 18, 2009, 03:42 pm by HULK Reason: 1
When i try to compile one of the virtual wire examples from the download library at http://www.open.com.au/mikem/arduino/VirtualWire-1.3.zip
i get following error message, something wrong in the library or could it be just my fault?
Code: [Select]
In file included from C:\Program Files\Arduino\arduino-0015\hardware\cores\arduino/WProgram.h:6,
c:/program files/arduino/arduino-0015/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected unqualified-id before 'double'
c:/program files/arduino/arduino-0015/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected `)' before 'double'
follower
AFAIK it's the same error introduced by a change in Arduino-0015 I'm pretty sure the fix has been covered in the forums.
--Phil.
HULK
Strange is that i have the same error with Arduino-0012 and 0014?
Code: [Select]
In file included from C:\Program Files\Arduino\arduino-0012\hardware\cores\arduino/WProgram.h:6,
c:/program files/arduino/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected unqualified-id before 'double'
c:/program files/arduino/arduino-0012/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected `)' before 'double'
HULK
Made a search on th error "math.h:439" and found no solution to it, only one post by somebody else that notice the issue.
I also removed the o-file in the library to be sure that it as not that messing up things but no change.
follower
Try searching the forums (with Google) for "expected unqualified-id before".
--Phil.
HULK
#5
Jul 19, 2009, 11:25 am Last Edit: Jul 19, 2009, 11:25 am by HULK Reason: 1
Now i got it right.
Adding this to the code before compiling did solve the issue.
Code: [Select]
#undef int
#undef abs
#undef double
#undef float
#undef round
Thanks Phil
mikem
You should not see this error with arduino-0016 or later.
HULK
Almost works with IDE 16 .
Error code i get is:
Code: [Select]
c:/program files/arduino/arduino-0016/hardware/tools/avr/lib/gcc/../../avr/include/math.h:439: error: expected `)' before 'double'
Need to add only :
Code: [Select]
#undef round
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
