Topic: Using the 'short' data type in Arduino (Read 2883 times) previous topic - next topic
Jzone
I'm playing round with some code to run a TLV5618 DAC via Arduino.
It's working fine - but it uses the 'short' data type that (I think) is based on C.
It's used a few times in function declarations - e.g.
Code: [Select]
void setDacAVoltage (short inVoltage) {
 setDacVoltage (inVoltage, 1);
I can't find an explanation for this data type in the Arduino reference - so I'm wondering two things:
1) What exactly is the 'short' data type and 2) Is there a better/more efficient way of writing it in Arduino?
The main reason I'm asking is that I want to try and change the data type for some things these functions are referencing - to try an optimise one part of my code, but don't want to do it before I understand exactly what type of data these functions are looking for now.
Hope that makes sense - thanks in advance.
J
Groove
#1
Dec 17, 2009, 12:34 pm Last Edit: Dec 17, 2009, 12:38 pm by GrooveFlotilla Reason: 1
On the Arduino, "short" is the same as "int".
It's a signed 16 bit quantity, so capable of representing the range -32 768 to +32 767.
IMHO, it's better (more portable) to write "short" which will (almost) always be a 16 bit quantity, whereas "int" depends on the platform.
In fact, probably even better to write "int16" or "int16_t" then there's no argument.
Per Arduino ad Astra
jluciani
Quote
Not sure if it's better or more efficient but I have a C++ DAC library that
supports the TLV5618 and TLV5620 at http://tinyurl.com/y8exe7k
Scroll down to the library links in the sidebar.
(* jcl *)
www: http://www.wiblocks.com
twitter: http://twitter.com/wiblocks
blog: http://luciani.org
Jzone
Thanks all - that helped.
Groove - the function is being passed an 'int' - so I might change that to 'short' rather than the other way round.
JCL - this is part of JP's MIDI2CV code - which you're familiar with! Like I said, it's working fine (along with Lin to EXP conversion and 2 x 4 way multiplexing now) - just trying to get the code running a bit faster.
Appreciated.
jluciani
I have not looked at JP's code but when doing the code for my numerically controlled
oscillator (NCO) I did notice a major speed improvement when I changed the
Code: [Select]
digitalWrite statements to assignment statements that directly set the bits in the ports. I am thinking of going back to my DAC library and updating it.
Fortunately the NCO only requires integer math.
(* jcl *)
Jzone
I did check out your recent NCO post - it looks great.
Changing the digitalWrite sounds like an option (although it's a bit over my head at the moment).
Yes - the speed improvement I'm looking for is in preparation for getting some waveforms out of the DAC.
Thanks heaps.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
