Loading...
Pages: [1]   Go Down
Author Topic: char array to int  (Read 356 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi I have a project that receives data from a wishield. Most is working but I have a problem converting the char array to an integer value.
I think this is a C related issue and me not properly understanding the  int() conversion method.
Any help is much appreciated
The code below illustrates the problem.
Code:
void setup(){
 Serial.begin(57600);
 char data[] = "128";
 int myint = int(data);
 Serial.println(data); // print "128"
 Serial.println(myint); // print 128
 Serial.println(myint++); // print 129
 Results in serial monitor...
 128
 2290
 2290
void loop(){}
Logged
UK
Offline Offline
Faraday Member
Gorm deficient
View Profile
Have look at "atoi".
What you're doing is converting a pointer to "char" (char*) to an integer.
« Last Edit: March 03, 2010, 10:00:28 am by GrooveFlotilla » Logged
Per Arduino ad Astra
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Technically its a cast, not a conversion - the value of the pointer is being re-interpreted as if it was declared int, the value is not touched.  Casting types like this is often confusing and leads to problems - and certainly casting pointers to and from integers is unlikely to be useful in an Arduino sketch.
atoi() etc are the way to go
Logged
Pages: [1]   Go Up
Print
Jump to:
