Topic: Help on MQ-7 CO Gas Sensor (Read 2356 times) previous topic - next topic
rayponsel
I'm new to Arduino. I hope someone can help me with this.
For the MQ7 CO Gas sensor to work, it requires a 1.4V for 60 seconds and 5V for 90 seconds.
Im guessing I have to use PWM. correct me if im wrong but how to obtain such a specific level of 1.4V and 5v?
Pls point me in the right direction guys. Thanks
rayponsel
The data sheet is as follows: ''http://www.sgbotic.com/products/datasheets/sensors/MQ-7.pdf''
PaulS
If you have an Arduino that operates at 5V, the 5V is pretty simple. Turn the pin full on (100% duty cycle).
The 1.4V is not much more difficult. You want the duty cycle to be 1.4/5 times the full range. 70% of 255 is 178.5. Either 178 or 179 should be close enough.
rayponsel
Thank you for your reply.
I read this article. http://principialabs.com/arduino-pulse-width-modulation/#comment-246 to find out more about PWM
If i did my calculations correctly, shouldn't it be 255(5V) for (90 seconds) and 71.4 (1.4V) for 60 seconds?
PaulS
You mean that 1.4/5 isn't 70%? Stupid fingers...
James C4S
From what I read in the datasheet, these voltages are for the heater right?  The problem there is that the heater is a 33ohm load.  So at 5V, it needs to draw about 150mA from the Arduino.
So you won't be able to power it directly from the I/O pin.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
deSilva
It will not need the full amperage, but they say 350mW in the datasheet. I have used some similar sensors, and this is no toy! They will become extremely hot (500 °C)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
