Topic: HOW? RUN STEPPER AND TWO SERVOS AT SAME TIME? (Read 4505 times) previous topic - next topic
BRANDONSHMINTON
HELLO,
IF SOMEONE COULD HELP ME OUT. I'VE BEEN STUCK ON THIS PROBLEM FOR A FEW WEEKS.
**MY MAIN GOAL IS TO GET A SKETCH THAT I CAN MODIFY THAT WILL RUN A STEPPER MOTOR AND TWO SERVOS AT THE SAME TIME.
I AM BUILDING A MOTION CONTROL RIG FOR A CAMERA WITH A STEPPER FOR TRACKING. ONE SERVO FOR PAN. ONE SERVO FOR TILT.
I AM RUNNING EVERYTHING ON THE ADAFRUIT MOTOR SHIELD THAT CONNECTS ON TOP OF THE ARDUINO.
I HAVE SUCCESSFULLY GOT THE STEPPER TO RUN ON ITS OWN. WITH THIS CODE.
#include <AFMotor.h>
AF_Stepper motor(200, 2);
 Serial.begin(9600);           // set up Serial library at 9600 bps
 Serial.println("Stepper test!");
 motor.setSpeed(50);  // 10 rpm
 Serial.println("Single coil steps");
 motor.step(3000, BACKWARD, SINGLE);
 motor.step(3000, FORWARD, SINGLE);
AND THE SERVO TO MOVE ON ITS OWN WITH THIS CODE
// Sweep
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
               // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
 myservo.attach(9);  // attaches the servo on pin 9 to the servo object
 for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
 {                                  // in steps of 1 degree
   myservo.write(pos);              // tell servo to go to position in variable 'pos'
   delay(15);                       // waits 15ms for the servo to reach the position
 for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
ALSO, HOW DO YOU GET THE PROGRAM TO RUN ONCE... INSTEAD OF LOOPING OVER AND OVER AGAIN?
ANY HELP WOULD BE GREATLY APPRECIATED!!!
prawnhead
No need to shout, 'eh? Let go of the CAPS LOCK!  ;)
BRANDONSHMINTON
PaulS
Code that is put in setup() runs once. Code that is put in loop() runs over and over. If you want the code to run once, it should (now) be obvious where to put it.
Put the code from setup() in each sketch into a new sketch, in the setup() function.
Put the code from loop() in each sketch into the new sketch, in the loop() function.
BRANDONSHMINTON
Thanks Paul. I'm going to try that out. That solves one hurdle.
BRANDONSHMINTON
Paul.
I am a bit of a beginner with the script (sketch) writing.
What does this mean?>
I tried to put the code from the loop() into the setup(). but it wont run. what do i do with the loop? i deleted it. and... it wont run. all these errors come up. I tried some different variations.
PaulS
If you have this:
Code: [Select]
[glow]   Serial.println("Hello!");
[/glow]}
Hello will be printed over and over again.
If you change it to this:
Code: [Select]
[/glow]}
Hello will print once.
Now, try that with your code.
BRANDONSHMINTON
This worked like a charm!
Servo only moved once.
Thank you PaulS
// Sweep
#include <Servo.h>
BRANDONSHMINTON
I got this code to work. It moves one servo...then moves the stepper.
How do i move them both at the same time?
// Sweep and step
#include <Servo.h>
 motor.step(2000, FORWARD, SINGLE);
PaulS
You are telling the servo to move in 1 degree increments, from 0 to 179, with a delay after each move starts.
Once the servo is all the way to the end, you tell it to move in 1 degree increments back to 0, with a delay after each move starts.
Then, you initialize the serial port, and write a message.
Then, you tell the stepper to move 2000 steps.
If you want the servo and stepper to move at the same time, you have to break the stepper stepping into smaller chunks, and move some steps each time the servo moves.
Grumpy_Mike
Look at the blink without delay example and copy that technique to break down the movement into small steps that will then appear to be happening at the same time.
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
BRANDONSHMINTON
