Topic: How to convert char to unsigned char? (Read 3037 times) previous topic - next topic
pc007
Oct 17, 2010, 04:45 am Last Edit: Oct 17, 2010, 04:47 am by pc007 Reason: 1
I have an LCD display using the ST7920 controller and I am using the dfrobot serial library available here --> http://www.dfrobot.com/image/data/FIT0021/LCD12864RSPI.rar
I'm simply trying to write a number on to the LCD screen but having a little trouble as the function to write text to the screen requires unsigned char.
I can use the following to convert a number to a string.
   char millis_char[16];
   unsigned long millis_ulong = millis();
   sprintf(millis_char,"%d",millis_ulong);
but I don't know how to convert the string to unsigned char.
this is to use in the LCDA.DisplayString function
any ideas?
Korman
Char and unsigned char convert themselves from one to the other, so no trouble there.
To access a single digit in your array, you just index it. For example to pass digit 3 (the numbering starts as 0) to a magic_display_function is:
Code: [Select]
magic_display_function (millis_char[3]);
Korman
davekw7x
#2
Oct 17, 2010, 08:16 pm Last Edit: Oct 17, 2010, 09:40 pm by davekw7x Reason: 1
Quote
You can tell the compiler to treat the array as unsigned char.  (Use a cast)
Code: [Select]
  sprintf(millis_char,"%lu", millis_ulong); // Works OK: sprintf uses char arrays.
  LCDA.DisplayString(0, 0, (unsigned char *)millis_char, 16);// The LCDA function requires unsigned char arrays.
Regards,
Dave
Footnote:
Not related to your question, but Something That It Is Good To Know:
Note that the format specifier "%d" is used for ints.
For long ints use "%ld"
For unsigned long ints use "%lu"
pc007
Thanks davekw7x.  Exactly the info I was looking for.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
