Topic: Tools->Copy For Forum  Bug? (Read 2179 times) previous topic - next topic
AlphaBeta
Often when I try to use the Copy For Forum menu item, I get this:
Quote
java.lang.ArrayIndexOutOfBoundsException: 37
     at processing.app.tools.DiscourseFormat.formatCode(DiscourseFormat.java:204)
     at processing.app.tools.DiscourseFormat.show(DiscourseFormat.java:117)
     at processing.app.Editor$16$1.run(Editor.java:755)
     at java.awt.event.InvocationEvent.dispatch(Unknown Source)
     at java.awt.EventQueue.dispatchEvent(Unknown Source)
     at java.awt.EventDispatchThread.pumpOneEventForHierarchy(Unknown Source)
     at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
     at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
     at java.awt.EventDispatchThread.run(Unknown Source)
When I restart my IDE everything is fine.
My system is:
Windows XP
Java 1.6.0_07
Arduino 0014
RXTX-2.1-7
eried
My website: http://ried.cl
AlphaBeta
Totally independent of file :(
Seems random.
eried
#3
Mar 15, 2009, 07:24 pm Last Edit: Mar 15, 2009, 07:25 pm by eried Reason: 1
By you error, it fail on:
Code: [Select]
char c = segmentArray[segmentOffset + offset];
in the function:
Code: [Select]
public String formatCode(int line) {
function dedicated to format each line of code for forum from:
Code: [Select]
   // Line by line
   for (int i = 0; i < parent.getLineCount(); i++) {
     cf.append(formatCode(i)); // <- called from here
so the problem is with one of your lines, maybe you could test some codes and paste here any faulty one.
AlphaBeta
Every time I restart arduino IDE the code that once caused an error, does not. This makes me suspect the error is in the IDE not in my code. :)
eried
#5
Mar 15, 2009, 08:46 pm Last Edit: Mar 15, 2009, 08:47 pm by eried Reason: 1
You're right :O is the IDE
Code: [Select]
     for (;;) {
       byte id = tokens.id;
       if (id == Token.END) {
         if (segmentOffset + offset < limit) {
           cf.append(c);
           cf.append('\n');
         return cf.toString();
Fixed code:
Code: [Select]
     for (;;) {
               // BUGBUG: this has been modified :)
           cf.append(segmentArray[segmentOffset + offset]);
           cf.append('\n');
Try with my fixed version (it is not the 0015, just a patched 0014)
http://servicios.ried.cl/arduino/temp/pde_arduino-0015_fixed_2009-03-15.rar
extract that file to your arduino/lib/ path
mellis
eried
Code: [Select]
if (segmentOffset + offset < limit) { ...
The comprobation must be after the char asignation:
Code: [Select]
Small, but important detail.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
