Topic: Memory overflow in EEPROM.write example (Read 2072 times) previous topic - next topic
deko1111
At: EEPROMWrite Reference page
EEPROM.write(address, value)
address: the location to write to, from 0 to 511 (int)
value: the value to write, from 0 to 255 (byte)
Example
 for (int i = 0; i < 512; i++)
   EEPROM.write(i, i);
The example code writes values higher than 255 in EEPROM locations 256 and above, causing memory overflow.
BenF
#1
Nov 12, 2009, 08:18 pm Last Edit: Nov 12, 2009, 08:19 pm by borref Reason: 1
Quote
I'm not sure I understand what you mean by "memory overflow", but if you think the code will attempt to write outside memory boundaries this is not so. Eeprom locations 256 through 511 will receive values 0 through 255.
I agree however that the example should be changed.
electricteardown
#2
Jan 03, 2011, 07:48 am Last Edit: Jan 03, 2011, 07:50 am by electricteardown Reason: 1
Bumping this old thread to change the example located on http://arduino.cc/en/Reference/EEPROMWrite because it's writing a value (256-511) more than the 255 allowed.
Maybe change "i" to 256 to keep it all simple?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
