Topic: That pesky Error inside Serial.<init>() problem (Read 2009 times) previous topic - next topic
marktrayle
I'm new to the Arduino BT. Just broke open the box today and was having
a great time until I decided to add Serial.print() to my code. Since then
I'm getting....
gnu.io.PortInUseException: Unknown Application
     at gnu.io.CommPortIdentifier.open(CommPortIdentifier.java:354)
     at processing.app.Serial.<init>(Serial.java:127)
     at processing.app.Serial.<init>(Serial.java:72)
     at processing.app.Uploader.uisp(Uploader.java:156)
     at processing.app.Uploader.uploadUsingPreferences(Uploader.java:78)
     at processing.app.Sketch.upload(Sketch.java:1693)
     at processing.app.Sketch.exportApplet(Sketch.java:1755)
     at processing.app.Editor$40.run(Editor.java:1902)
     at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
     at java.awt.EventQueue.dispatchEvent(EventQueue.java:461)
     at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:269)
     at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:190)
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:184)
     at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:176)
     at java.awt.EventDispatchThread.run(EventDispatchThread.java:110)
Error: Resource busy
-> /dev/tty.ARDUINOBT-BluetoothSeri-1
I've already checked the troubleshooting guide. Under Arduino-0008 there's no
macosx-command to run. There's no /var/spool/uucp in /var/spool to delete.
I deleted the Arduino from the list of Bluetooth devices and nuked /dev/*ARDUIN*,
then added the Arduino again. I've tried various forms of acupressure and voodoo involving
the timing and duration of the Arduino's reset button, restarting the Mac, etc., etc.
I'm on OS X 10.4.10.
Ideas, anyone?
thanks,
Mark
Daniel
hi
what exactly did you add in the way of code? The errors you are having sound more like the port is busy.
D
marktrayle
Quote
hi
D
First, I made a copy of the AnalogInput example.
Then, I added Serial.print( val ) right after the first digitalWrite(ledPin, HIGH).
I was trying to get the MotorKnob example to work, and was verifying that
I could even get some analog input.
Yes, it looks to me like the port os busy. But I've rebooted both Mac and Arduino, and deleted
the /dev/tty.*ARD* goodie, and deleted the Arduino from the list of bluetooth devices.
Seems like either one of them should've let go of the port by now.
Mark
admin
Try to connect to the /dev/tty..... instead of the /dev/cu... on the bluetooth board seems to fix a lot of issues
marktrayle
Quote
i tried both, no luck.
marktrayle
Quote
Quote
One more little detail... if I leave the Bluetooth Preferences window up I can see that
the Arduino never connects to the Mac. Unless I hold the reset button down for a few seconds.
Then when I try to upload it toggles between "Connected: Yes" and "Connected: No". Still
doesn't work, but maybe that's a clue?
Should I try resetting the Bluetooth module itself?
Has Arduino-0008 been tested against OS X 10.4.10?
Thanks much,
Mark
marktrayle
Quote
Quote
Ah ha! I swapped power supplies and now it seems to be working consistently.
The voltage from the supply reads a steady 5.0, so there must be some other
problem with it. Odd that it would work a few times then fail.
Sorry to take up your time.
onward,
Mark
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
