Topic: Servo Library, can I address servos dynamically? (Read 488 times) previous topic - next topic
pinter75
Howdy.
using a case switch can I dynamically address a servo?
switch(ch) {
case '0'...'9':
      v = v * 10 + sm - '0';
case 'a'...'z':
     ch.write(v);
I get error: request for member 'write' in 'ch', which is of non-class type 'char'
any ideas?
Thanks.
hari
Without seeing the rest of the code, I can't figure out what you're trying to do.
The compiler did not yell at you on the switch and case, so I presume ch is really a char and not a Servo object.
That is why the compiler pukes on ch.write.  Unlike a Servo object, a char is not even an object and therefore it does not know how to write itself.
You probably meant something like this:
Servo myServoArray[4];
myServoArray[ servoIndex ].write(v);
If you post more complete code, we can try to help you further.
Groove
Code: [Select]
switch(ch) {
case '0'...'9':
case 'a'...'z':
    ch.write(v);
Your switch selector is a "char" - it can't also be a "Servo".
Per Arduino ad Astra
mem
#3
Mar 15, 2010, 09:51 am Last Edit: Mar 15, 2010, 09:53 am by mem Reason: 1
Here is an example sketch that may help, you can easily convert the if statements to a case statment if you want.
I use this sketch to test lots of servos with different boards
Code: [Select]
* Servo serial tester
* Command a servo by entering a numeric value for the angle followed by a letter to identify the servo
* where 'a' is the first servo, 'b' the second and so on
* '*' commands all servos
* '+' sweeps all servos in one direction and '-' sweeps then in the other direction
#include <Servo.h>
const int NBR_SERVOS = MAX_SERVOS;       // the number of servos, up to 48 for Mega, 12 for other boards
const int FIRST_SERVO_PIN = 2;
Servo Servos[NBR_SERVOS] ; // max servos is 48 for mega, 12 for other boards
 for(int i=0; i < NBR_SERVOS; i++)
   Servos[i].attach(FIRST_SERVO_PIN +i);
 delay(2000);
 Serial.print(" Initialized ");
 Serial.print(NBR_SERVOS,DEC);
 Serial.println(" Servos");
 static int pos = 0;
 if ( Serial.available())
   char ch = Serial.read();
   if(ch >= '0' && ch <= '9')              // is ch a number?
     pos = pos * 10 + ch - '0';           // yes, accumulate the value
   else if(ch >= 'a' && ch <= 'a'+  NBR_SERVOS) // is ch a letter for one of our servos?
     Servos[ch - 'a'].write(pos);         // yes, save the position in the position array
     pos = 0;
     int channel =  ch - 'a';
     int  angle = Servos[channel].read();
     Serial.print("Servo on pin ");
     Serial.print(FIRST_SERVO_PIN + channel, DEC);
     Serial.print(": angle = ");
     Serial.println(angle,DEC);
   else if (ch == '*')
     // position all the servos
       Servos[i].write(pos);
     pos = 0;
   else if (ch == '+')
     // sweep all servos from 0 to 180
     for(int angle = 0;angle < 180; )
         Servos[i].write(angle);
       Serial.print("Angle = ");
       ++angle;
       delay(20);
     pos = 0;
   else if (ch == '-')
     // sweep all servos from 180 to 0
     for(int angle = 180;angle >= 0; )
       angle = Servos[0].read();
       --angle;
       delay(20);
     pos = 0;
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
