Topic: How do i call this routine? (Read 2160 times) previous topic - next topic
Quest_UK
searched but cannot find what i am doing wrong?
I am new to Arduino having used Basic before. I wish to use the routine do_this
I like to have things in their own routines so thought i would try something simple first, but cannot get this right?
i get "error 'ledPin' was not declared in this scope"
Code: [Select]
void setup()   {
 do_this();
 pinMode(ledPin, OUTPUT);     //error 'ledPin' was not declared in this scope
 // Do something
void do_this()
 const int ledPin =  13;    // LED connected to digital pin 13
I am sure this is very simple but need a little help?
Regards
Gary
msproul
You have the led = 13 line inside of a routine, that makes it a LOCAL variable and not a GLOBAL variable. Also, C requires that everything be defined BEFORE you use it.
Understand that the setup code gets called ONCE, and loop gets called forever.
Your code should look like this
Code: [Select]
void setup()   {
 do_this();
 // Do something
void do_this()
