Topic: WaveShield - How to Randomize Files on SD Card (Read 1 time) previous topic - next topic
D-man
Hi!
Any help would be most appreciated. We successfully have a waveshield running all the files on our SD card using the code below (from ladyada.com).
It runs the files in the same order every time. We need the files to run at random.
Does anyone know how to adjust our code so it plays the files at random?
Best.
D-Man
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the filesystem on the card
uint8_t dirLevel; // indent level for file/dir names    (for prettyprinting)
dir_t dirBuf;     // buffer for directory reads
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
// Function definitions (we define them here, but the code is below)
void lsR(FatReader &d);
void play(FatReader &dir);
 Serial.begin(9600);           // set up Serial library at 9600 bps for debugging
 putstring_nl("\nWave test!");  // say we woke up!
 putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
 Serial.println(freeRam());
 // Set the output pins for the DAC control. This pins are defined in the library
 pinMode(2, OUTPUT);
 pinMode(3, OUTPUT);
 pinMode(4, OUTPUT);
 pinMode(5, OUTPUT);
 //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
 if (!card.init()) {         //play with 8 MHz spi (default faster!)
   putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
   sdErrorCheck();
   while(1);                            // then 'halt' - do nothing!
 // enable optimize read - some cards may timeout. Disable if you're having problems
 card.partialBlockRead(true);
 // Now we will look for a FAT partition!
 uint8_t part;
 for (part = 0; part < 5; part++) {     // we have up to 5 slots to look in
   if (vol.init(card, part))
     break;                             // we found one, lets bail
 if (part == 5) {                       // if we ended up not finding one  :(
   putstring_nl("No valid FAT partition!");
   sdErrorCheck();      // Something went wrong, lets print out why
 // Lets tell the user about what we found
 putstring("Using partition ");
 Serial.print(part, DEC);
 putstring(", type is FAT");
 Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
 // Try to open the root directory
 if (!root.openRoot(vol)) {
   putstring_nl("Can't open root dir!"); // Something went wrong,
 // Whew! We got past the tough parts.
 putstring_nl("Files found:");
 dirLevel = 0;
 // Print out all of the files in all the directories.
 lsR(root);
//////////////////////////////////// LOOP
 root.rewind();
 play(root);
/////////////////////////////////// HELPERS
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
 extern int  __bss_end;
 extern int  *__brkval;
 int free_memory;
 if((int)__brkval == 0) {
   free_memory = ((int)&free_memory) - ((int)&__bss_end);
 else {
   free_memory = ((int)&free_memory) - ((int)__brkval);
 return free_memory;
* print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void)
 if (!card.errorCode()) return;
 putstring("\n\rSD I/O error: ");
 Serial.print(card.errorCode(), HEX);
 putstring(", ");
 Serial.println(card.errorData(), HEX);
 while(1);
* print dir_t name field. The output is 8.3 format, so like SOUND.WAV or FILENAME.DAT
void printName(dir_t &dir)
 for (uint8_t i = 0; i < 11; i++) {     // 8.3 format has 8+3 = 11 letters in it
   if (dir.name == ' ')
       continue;         // dont print any spaces in the name
   if (i == 8)
       Serial.print('.');           // after the 8th letter, place a dot
   Serial.print(dir.name);      // print the n'th digit
 if (DIR_IS_SUBDIR(dir))
   Serial.print('/');       // directories get a / at the end
* list recursively - possible stack overflow if subdirectories too nested
 int8_t r;                     // indicates the level of recursion
 while ((r = d.readDir(dirBuf)) > 0) {     // read the next file in the directory
   // skip subdirs . and ..
   if (dirBuf.name[0] == '.')
     continue;
   for (uint8_t i = 0; i < dirLevel; i++)
     Serial.print(' ');        // this is for prettyprinting, put spaces in front
   printName(dirBuf);          // print the name of the file we just found
   Serial.println();           // and a new line
   if (DIR_IS_SUBDIR(dirBuf)) {   // we will recurse on any direcory
     FatReader s;                 // make a new directory object to hold information
     dirLevel += 2;               // indent 2 spaces for future prints
     if (s.open(vol, dirBuf))
       lsR(s);                    // list all the files in this directory now!
     dirLevel -=2;                // remove the extra indentation
 sdErrorCheck();                  // are we doign OK?
* play recursively - possible stack overflow if subdirectories too nested
 FatReader file;
 while (dir.readDir(dirBuf) > 0) {    // Read every file in the directory one at a time
   // skip . and .. directories
     continue;
   Serial.println();            // clear out a new line
   if (!file.open(vol, dirBuf)) {       // open the file in the directory
     Serial.println("file.open failed");  // something went wrong :(
     while(1);                            // halt
   if (file.isDir()) {                    // check if we opened a new directory
     putstring("Subdir: ");
     printName(dirBuf);
     dirLevel += 2;                       // add more spaces
     // play files in subdirectory
     play(file);                         // recursive!
     dirLevel -= 2;
   else {
     // Aha! we found a file that isnt a directory
     putstring("Playing "); printName(dirBuf);       // print it out
     if (!wave.create(file)) {            // Figure out, is it a WAV proper?
       putstring(" Not a valid WAV");     // ok skip it
       Serial.println();                  // Hooray it IS a WAV proper!
       wave.play();                       // make some noise!
       while (wave.isplaying) {           // playing occurs in interrupts, so we print dots in realtime
         putstring(".");
         delay(100);
       sdErrorCheck();                    // everything OK?
//        if (wave.errors)Serial.println(wave.errors);     // wave decoding errors
Coding Badly
Step #1: In the lsR function, count the number of files.  You'll need a global variable to store the count.
D-man
Thanks so much for the help! I'm fairly new to arduino and processing, so I'm not familiar with the specific strings of code that follow from your suggestion. .
One patch I've been playing with is the following:
Code: [Select]
int i[7]={0,1,2,3,4,5,6};
for (int i = 0; i < 30; i = i + 1)
There are seven files on the SD card, and we labeled them 0 through 6. I've been trying to work this patch into the code from my previous post, but to no avail.
I have, on the other hand, managed to insert this patch into another code, and have seem to be getting random play successfully.
Code: [Select]
   #include "WaveHC.h"
   FatReader f;      // This holds the information for the file we're play
   #define DEBOUNCE 100  // button debouncer
   int freeRam(void)
     int free_memory;
     else {
     return free_memory;
     putstring(", ");
     while(1);
     // set up serial port
     putstring_nl("WaveHC with 6 buttons");
     Serial.println(freeRam());      // if this is under 150 bytes it may spell trouble!
     pinMode(2, OUTPUT);
     pinMode(3, OUTPUT);
     pinMode(4, OUTPUT);
     pinMode(5, OUTPUT);
     // pin13 LED
     pinMode(13, OUTPUT);
     // enable pull-up resistors on switch pins (analog inputs)
     digitalWrite(14, HIGH);
     digitalWrite(15, HIGH);
     digitalWrite(16, HIGH);
     digitalWrite(17, HIGH);
     digitalWrite(18, HIGH);
     digitalWrite(19, HIGH);
       sdErrorCheck();
     uint8_t part;
     putstring_nl("Ready!");
     //putstring(".");            // uncomment this to see if the loop isnt running
     switch (check_switches()) {
       case 1:
      switch (i)
         case 0: playcomplete("0.WAV");
         case 1: playcomplete("2.WAV");
         case 2: playcomplete("3.WAV");
         case 3: playcomplete("4.WAV");
         case 4: playcomplete("5.WAV");
         case 5: playcomplete("6.WAV");
         case 6: playcomplete("1.WAV");
   byte check_switches()
     static byte previous[6];
     static long time[6];
     byte reading;
     byte pressed;
     byte index;
     pressed = 0;
     for (byte index = 0; index < 6; ++index) {
       reading = digitalRead(14 + index);
       if (reading == LOW && previous[index] == HIGH && millis() - time[index] > DEBOUNCE)
         // switch pressed
         time[index] = millis();
         pressed = index + 1;
       previous[index] = reading;
     // return switch number (1 - 6)
     return (pressed);
   // Plays a full file from beginning to end with no pause.
   void playcomplete(char *name) {
     // call our helper to find and play this name
     playfile(name);
     // do nothing while its playing
     // now its done playing
   void playfile(char *name) {
     // see if the wave object is currently doing something
     if (wave.isplaying) {// already playing something, so stop it!
       wave.stop(); // stop it
     // look in the root directory and open the file
     if (!f.open(root, name)) {
       putstring("Couldn't open file "); Serial.print(name); return;
     // OK read the file and turn it into a wave object
     if (!wave.create(f)) {
       putstring_nl("Not a valid WAV"); return;
     // ok time to play! start playback
     wave.play();
The only problem here is our project doesn't use a switch. We are trying to remove the switch from this new code above, so the files play as soon as it is powered. Haven't gotten it yet.
Any help would be greatly appreciated. Many thanks,
D-Man
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
