Topic: Bootloader only works once? (Read 3049 times) previous topic - next topic
Gene Buckle
I'm trying to set up some ATMega328 parts with the Arduino bootloader.  I'm using the following commands to upload the bootloader to the part:
avrdude -B 25 -c stk500v2 -P com3 -p m328p -u -U hfuse:w:0xDA:m
avrdude -B 25 -c stk500v2 -P com3 -p m328p -u -U efuse:w:0x05:m
avrdude -B 25 -c stk500v2 -P com3 -p m328p -u -U lfuse:w:0xFF:m
avrdude -B 1 -c stk500v2 -P com3 -p m328p -u -U flash:w:ATmegaBOOT_168_atmega328.hex
The operation completes successfully.  When I use the Arduino IDE (v 0018) to upload the "Blink" sketch, it works.  However, subsequent attempts to upload another sketch fails until I re-load the bootloader code.
Any idea what I've screwed up?  Thanks all.
g.
retrolefty
I suspect the problem is with the proper use of the locking fuse:
atmega328.bootloader.unlock_bits=0x3F
atmega328.bootloader.lock_bits=0x0F
I suspect that the chip isn't being locked after the bootloader is burned in and then when a new sketch is uploaded it clobbers the bootloader. Can't help with the gory details of how to do all that properly, but I've read of this problem before from others.
Lefty
westfw
Have you implemented auto-reset, or are you using a manual reset button?  The bootloader is only active immediately after reset, unless of course the chip contains no sketch at all, in which case the bootloader will continue to run...
Gene Buckle
#3
Mar 16, 2010, 03:33 am Last Edit: Mar 16, 2010, 02:33 pm by geneb Reason: 1
I don't know about the lock bits - The avrdude commands were in a batch file I found linked from a tutorial video...
I'm using the firmware that came with the Arduino IDE - I've tried uploading the sketch both before and after hitting the reset button on my STK500, where the chip is installed.
[Update]
I should also mention that the sketch that was originally uploaded continues to operate, it just won't accept new sketches.
Thnx.
g.
Gene Buckle
C'mon guys, throw me a bone here. :)
I know it's gotta be something stupid that I'm missing.  Help!
g.
retrolefty
Well perhaps if you could say what hardware programmer you are using and how you are using AVRDUDE. Are you using command line staatements to control AVRDUDE or using some script?
I still think it has to do with the locking and unlocking fuse settings, but can't give you help as I've never mastered manual control of AVRDUDE.
Lefty
Gene Buckle
The exact commands used to program the bootloader are in the first message I posted.  I'm using an STK500 to do the programming of the bootloader.  I'm also using it to download sketches to the '328.
Events are:
1.  Program bootloader
2.  Download "blink" sketch via Aruino IDE
3.  Attempt to download new sketch fails, first downloaded sketch is undisturbed and still running.
I've tried hitting the RESET button the STK500 both before and after starting the 2nd download and it doesn't appear to make any difference.
tnx.
g.
retrolefty
#7
Mar 17, 2010, 08:48 pm Last Edit: Mar 17, 2010, 08:54 pm by retrolefty Reason: 1
Quote
That's a little confusing to me. Does that mean you are using the STK500 to load the second sketch, after loading the first sketch using the Arduino IDE?
The Arduino IDE uses the serial USB link to upload sketches with the active bootloader running on the board talking to AVRDUDE. Loading the bootloader into the AVR chip with the STK500 is a one time operation, after that normal uploading is done via the serial link, not via a STK500. If you use a STK500 to load a sketch it will overwrite the bootloader.
I may just not be understanding your last statement. ;)
1.  Program bootloader With a hardware STK500 programmer, correct?
2.  Download "blink" sketch via Aruino IDE Using normal USB serial connection?
3.  Attempt to download new sketch fails Using USB serial connection or a hardware STK500 programmer?, first downloaded sketch is undisturbed and still running.
Lefty
Gene Buckle
After programming the bootloader,  I remove the ISP cable and move the serial connector to the second DB9 on the STK500.  This port is cabled into the '328 via a 2 wire jumper (rx/tx).  I then use the Arduino IDE to upload the sketch.  It works once, but only once.
tnx.
retrolefty
#9
Mar 17, 2010, 09:01 pm Last Edit: Mar 17, 2010, 09:02 pm by retrolefty Reason: 1
Quote
I'm not familiar enough with that hardware programmer. I use a USBtiny programmer for burning bootloaders and it uses it's own separate USB connection to the PC and has a ISP cable to attach to the Arduino board, I then use the normal build-in USB serial connection from the Arduino board to the PC for normal IDE uploads of sketches, works fine.
Lefty
Gene Buckle
*blinks*
There's nothing wrong with the hardware.  The programmer operates just fine.  The programmed part also works - it takes a sketch download *once*.  Subsequent tries fail.
I really need help getting this straightened out.
g.
retrolefty
Maybe you can get help over at the AVRfreaks site, they have a lot of professional types that really know a lot.
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewforum&f=3&sid=08ebf312d189415fb5b177cde07c5a66
Lefty
Gene Buckle
So essentially, you're shoving me off on to another forum because you're not interested in helping me or understanding the problem.
Gee, thanks.
g.
retrolefty
#13
Mar 17, 2010, 09:52 pm Last Edit: Mar 17, 2010, 09:54 pm by retrolefty Reason: 1
Quote
Gee, thanks.
I'm sorry you feel that way. I have claimed no expertize that can solve your problem. I have explained how I accomplish the same task even if I don't understand all the internal complexity that is required. As no one else has been responding to your post lately, I gave you the only lead (avrfreaks) that I can think off. I am certainly not holding back any secret knowlege or solution for your problem.
Again sorry to not be able to rise to your expectations. I suspect it's more about your frustration with your problem, then about my responses.
Lefty
Coding Badly
Have you tried using the Arduino IDE to burn the bootloader?
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
