Topic: Re: Led Matrix Processing, arduino control problems (Read 558 times) previous topic - next topic
AWOL
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
PaulS
Code: [Select]
 if(true)
     Serial.print (0,BYTE);
     Serial.print (1,BYTE);
     Serial.print ((byte) Y1,BYTE);
     Serial.print (2,BYTE);
     Serial.print ((byte) Y2,BYTE);
     Serial.println (Y1);
     Serial.println (Y2);
Under what circumstances would the else block ever be executed?
Do you have you indent value set to random?
Rilart
#2
Dec 03, 2010, 06:26 pm Last Edit: Dec 03, 2010, 06:48 pm by Rilart Reason: 1
My question is, what im doing wrong in the arduino code. The processing at the moment ia not a big deal.
Im a mediumi-noob at the programming stuff :(
PaulS
Quote
The forum is not a money making operation. As a result, our crystal ball was re-possessed.
You'll need to describe the symptoms, at the very least. Otherwise, we can just say that it must be your expectations that are wrong.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
