Topic: Linux problem with arduino UNO (Read 7739 times) previous topic - next topic
knight
Hi, I bought my arduino UNO starter kit. it works perfectly fine on windows 7 but I cant upload the software from arduino IDE to the arduino board when using linux. I have tried linux mint 10 , ubuntu 10.10 and fedora 14 all of them have the same problem. Sometimes /dev/ttyACM0 is detected and most of the time its not. When it does detect it and I chose to upload to the board it either says ACM0 not found or ACM0 is already in use. Only once I was actually able to upload to the arduino UNO using linux mint (arduino 0021) but after that I have tried numerous solutions and nothing works.
I have tried using a self-powered usb hub to connect my arduino UNO board to the PC but no luck. Basically I connected an IR distance sensor to the arduino and programmed it using windows just to see if it communicates back to the PC in linux and it was only successful in doing so once. I got a reading for distance in cm on the serial monitor by moving my hand closer and away from the sensor. otherwise I have had absolutely no luck in uploading to the board. I even tried to use arduino-0022 and replace librxtxSerial.so and RXTXcomm.jar using both 0021 and 0022 but nothing works !
any suggestions ? I really want to use linux
Thank you.
knight
I used this website: https://sites.google.com/a/lyz.jp/arduino/about-arduino/arduino-setup-for-fedora14 and the arduino.cc playground to setup my arduino IDE and both failed.
I have tried the soltuions listed here: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1292104213
James C4S
When you get the error message that the serial port is already in use, run this command:
"lsof | grep ttyACM0"  (or change ttyACM0 to whatever your Arduino's serial port is.)
What processes are listed as using the serial port?
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
mrtaylor
on ubuntu 10.10 could you plug the usb port in and run this command
dmesg | grep usb
pls post the output
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
