Loading...
Pages: [1]   Go Down
Author Topic: IR Remote controlled finger for camera shutter (completed with demo video)  (Read 1606 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
This is one of my first completed arduino projects.  A IR remote controlled (and also laser controlled) finger to manually press a camera shutter button on a Nikon P100 camera, since that camera has no other way to support remote shutter.
Demo video here.
I plan to eventually put up some sort of tutorial somewhere for other newbies to help avoid some of the issues I struggled with while learning, if anyone knows a good place to put up a quick and simple tutorial without a bunch of hoops to jump through let me know.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
By the way, here is the code.
Code:
/* Note, first time run, with no values stored in EEPROM might be a bit buggy,
as soon as values are stored, will work fine */
#include <IRremote.h>
#include <Servo.h>
#include <EEPROM.h>
int RECV_PIN = 11;  //ir reciever hooked on pin 11 through 220ohm resistor
Servo myservo;   // create servo object to control a servo
int position1;   //servo position 1
int position2;   //servo position 2
int position3;   //servo position 3
int codeValue;   //the code from the remote
int current;     //keeps track of current servo position
IRrecv irrecv(RECV_PIN);
decode_results results;
  position1 = EEPROM.read(1);    //default servo positon 1
  position2 = EEPROM.read(2);   //default servo position 2
  position3 = EEPROM.read(3);  //default servo position 3
  irrecv.enableIRIn(); // Start the receiver
  myservo.attach(9);  // attaches the servo on pin 9
  myservo.write(position1);   //start the servo out at position 1
  current = position1;
  if (irrecv.decode(&results)) {
    codeValue = results.value;
    switch (codeValue) {
    case 16753245:
    case 16736925:
      myservo.write(position2);
      current = position2;
    case 16769565:
      myservo.write(position3);
      current = position3;
    case 16761405:
      ++current;                //moves servo 1 degrees
      if (current > 179) current = 179;  //this makes sure the current variable doesn't exceed the servo range
      myservo.write(current);
    case 16748655:
      --current;
      if (current < 0) current = 0;  //makes sure variable doesn't drop below 0
    case 16712445:
      current += 10;  //moves servo 10 degrees
    case 16754775:
      current -= 10;
    case 16720605:
      myservo.write(179);  //moves servo all the way to 179
      current = 179;
    case 16769055:
      myservo.write(0);
      current = 0;
    case 16738455:
      position1 = current;  //stores current position as servo position 1
      EEPROM.write(1, position1);  //writes position 1 to eeprom address 1
    case 16750695:
      position2 = current;  //stores current position as servo position 2
      EEPROM.write(2, position2);  //writes position 2 to eeprom address 2
    case 16756815:
      position3 = current;  //stores current position as servo position 3
      EEPROM.write(3, position3);  //writes position 3 to eeprom  address 3
    case 16724175:    //this is for the laser sensor
      int sensorValue = analogRead(A0);     //cds photocell hooked to analog 0, has 10k pulldown resistor to ground
      while (sensorValue > 950) {              //value can be adjusted, 950 very sensitive for my conditions
        digitalWrite(13, HIGH);        //status light, led on means laser is armed
        sensorValue = analogRead(A0);    //reads sensor value again for the loop
      digitalWrite(13, LOW);             //turns led off to indicate status that servo was activated.
      delay(1000);                        //delay just for good measure, holds servo for a second
      myservo.write(position1);          //moves servo back to position 1
irrecv.resume(); // Receive the next value
Logged
Red Sea, Saudi Arabia
Offline Offline
God Member
..On The Red Sea
View Profile
WWW
Nice!
This would be an optional output choice for this: http://yourduino.com/camera-control.htm
Logged
Regards, Terry King  ..On the Red Sea at KAUST.edu.sa
terry@yourduino.com  LEARN! DO! (Arduino Boards, Sensors, Parts @ http://yourduino.com)
Offline Offline
Newbie
View Profile
Im very new to arduino and was looking for some thing like your project to use with my sony nex-3. I made a "copy paste" of your code but when I try to send the code to my arduino it gives so many errors that I dont know were is the problem !?!?! can you help me?
Thanks.
Ps. the errors ar in the atached file.
Logged
Pages: [1]   Go Up
Print
Jump to:
