Topic: timing accuracy test (Read 1 time) previous topic - next topic
JimEli
I'm checking the accuracy of my arduino clock against a (ChronoDot) DS3231 TCXO running a 1Hz interrupt using the attached code.  Results show +/-1 ms difference every few seconds. Latency in the code, arduino millis calculation issue or crystal? Please comment.
TIA.
Code: [Select]
//ChronoDot test [ds3231]
//NOTE: 10k pullup resistor on SQW line
#include <Wire.h>
#define INT_PIN 3  //chronodot sqw wire
extern volatile unsigned long timer0_millis;
volatile unsigned long t, now, prev;
 //init wire & serial
 Wire.begin();
 Wire.beginTransmission(104);
 Wire.send(0x0e);  //select control register
 //set sqw at specified Hz of  0=1Hz
 Wire.send(0);
 Wire.endTransmission();
 //init interrupt
 pinMode(INT_PIN, INPUT);
 attachInterrupt(1, OneHzInterrupt, FALLING);  //0 = digital pin 3
void OneHzInterrupt(void) {
 now = timer0_millis;
 t = now - prev;
 prev = now;
 Serial.println(t);
RuggedCircuits
The way the code is implemented timer0_millis increments by 1 every 1.024ms then there is a "correction" every 41 milliseconds and it actually increments by 2. Another variable timer0_fract increments by 3 until it reaches 125 indicating it counted 24 times out of 1000 (3/125-->24/1000).
Think of it like this table:
Actual Time | timer0_millis | timer0_fract
1.024ms13
2.048ms26
3.072ms39
41.984ms41123
43.008ms431
44.032ms444
45.056ms457
Thus the correction leads to a hiccup between 41 and 43.
http://www.ruggedcircuits.com
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
