Topic: how to combine the two programs together? (Read 3173 times) previous topic - next topic
moomoo
Hi peeps, i would like to combine the voltage and the mercury tilt switch program together with the SPO2 program, how do i go about? And i would like the delay for the voltage and mercury tilt program to be 400, whereas the SPO2 program will be 100, is it possible to make two delays separately? Please help....
Voltage and mercury tilt switch program
const int mercPin0 = 2;
const int tiltPin3 = 4;
const int mercuryPin5 = 6;
const int tiltyPin7 = 9;
void setup( )
  pinMode(mercPin0, INPUT);
  pinMode(tiltPin3, INPUT);
  pinMode(mercuryPin5, INPUT);
  pinMode(tiltyPin7, INPUT);
  Serial.begin (19200);
void loop( )
  float voltage = 0;
  int sensorValue = analogRead (A0);
  voltage = sensorValue * 0.0048; // code width(sensitivity) = 5 / 210  = 4.8mV
  Serial.print (voltage, DEC);
  int states  = digitalRead(mercPin0);
  if(states == HIGH)
    Serial.print(",O");
    Serial.print(",C");
    int state  = digitalRead(tiltPin3);
  if (state == HIGH)
    Serial.print("O");
    Serial.print("C");
    int condition  = digitalRead(mercuryPin5);
  if(condition == HIGH)
    Serial.print("O");
    Serial.print("C");
    int conditions  = digitalRead(tiltyPin7);
  if(conditions == HIGH)
    Serial.println("O");
    Serial.println("C");
  delay(400);
SPO2 program
#include <NewSoftSerial.h>
NewSoftSerial nss(10,11); // Put your TX and RX pins here, in the correct order
byte vals[3];
int heartRate, oxyLevel;
  nss.begin(19200);
  Serial.begin(19200);
  if(nss.available() >= 3)
    vals[0] = nss.read(); //represent byte 1
    vals[1] = nss.read(); //represent byte 2
    vals[2] = nss.read(); //represent byte 3
bitWrite(heartRate, 0, bitRead(vals[1], 0)); // Set bit 0
bitWrite(heartRate, 1, bitRead(vals[1], 1)); // Set bit 1
bitWrite(heartRate, 2, bitRead(vals[1], 2)); // Set bit 2
bitWrite(heartRate, 3, bitRead(vals[1], 3)); // Set bit 3
bitWrite(heartRate, 4, bitRead(vals[1], 4)); // Set bit 4
bitWrite(heartRate, 5, bitRead(vals[1], 5)); // Set bit 5
bitWrite(heartRate, 6, bitRead(vals[1], 6)); // Set bit 6
bitWrite(heartRate, 7, bitRead(vals[0], 0)); // Set bit 7(Vals[0])
bitWrite(heartRate, 8, bitRead(vals[0], 1)); // Set bit8(Vals[0])
  bitWrite(oxyLevel, 0, bitRead(vals[2], 0)); // Set bit 0
  bitWrite(oxyLevel, 1, bitRead(vals[2], 1)); // Set bit 1
  bitWrite(oxyLevel, 2, bitRead(vals[2], 2)); // Set bit 2
  bitWrite(oxyLevel, 3, bitRead(vals[2], 3)); // Set bit 3
  bitWrite(oxyLevel, 4, bitRead(vals[2], 4)); // Set bit 4
  bitWrite(oxyLevel, 5, bitRead(vals[2], 5)); // Set bit 5
  bitWrite(oxyLevel, 6, bitRead(vals[2], 6)); // Set bit 6
  Serial.print("Heart rate: ");
  Serial.println(heartRate);
  Serial.print("Oxygen level: ");
  Serial.println(oxyLevel);
    delay (100);
AWOL
#1
Mar 07, 2011, 02:35 pm Last Edit: Mar 07, 2011, 02:41 pm by AWOL Reason: 1
Can't you just rename the two "loop" functions and call them in a new sketch?
If necessary, use only "delay(100) and call the one that needs running at 400millisecond intervals every fourth time.
This:
Code: [Select]
is over-complicated (and over-commented) - the statements involving oxyLevel are completely pointless when a simple assignment would suffice.
Some simple binary arithmetic would sort the other one out.
Code: [Select]
  Printing a float to ten decimal places is a little ambitious.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
moomoo
how do we call it for every fourth time?
GrooveFlotilla
Quote
Code: [Select]
  loop_100ms ();  //this has 100ms delay in it
  loop_100ms ();
  loop_100ms ();
  loop_100ms ();
  loop_400ms ();   // this has NO delay in it
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
moomoo
Thanks for your quick reply. I got a problem though. I attempt to upload this sketch below onto my Arduino Pro Mini via the 6 pins header of the 5V FTDI Basic Breakout Board.
Code: [Select]
byte vals[3];
void setup( )
  nss.begin(9600); // Or whatever is appropriate
  Serial.begin (9600);
void loop( )
  float voltage = 0;
  if(states == HIGH)
    Serial.print(",O");
    Serial.print(",C");
  if (state == HIGH)
    Serial.print("O");
    Serial.print("C");
    Serial.print("O");
    Serial.print("C");
    Serial.print("O");
    Serial.print("C");
    heartRate = 0; // Sets all 8 bits to 0
    oxyLevel = 0; // Sets all 8 bits to 0
    bitWrite(heartRate, 8, bitRead(vals[0], 1)); // Set bit 8(Vals[0])
    oxyLevel = vals[2];
    Serial.print(heartRate);
    delay(100);
However, during uploading, the rx pin of the 5V FTDI Basic Breakout Board keep blinking. What is the problem? I cannot open serial monitor too.
AWOL
Sorry, can't help I have never used the setup you're using, but it is unlikely to be a problem with your code.
Have you tried uploading any of the example, known-good sketches?
Code: [Select]
It is best if your comments at least match your code.]
"heartRate" is a 16 bit quantity.
Code: [Select]
    oxyLevel = vals[2];
If you're going to overwrite it, why bother zeroing it?
moomoo
This is my final program
Code: [Select]
byte vals[3];
void setup( )
void loop( )
  float voltage = 0;
  if(states == HIGH)
    Serial.print(",O");
    Serial.print(",C");
  if (state == HIGH)
    Serial.print("O");
    Serial.print("C");
    Serial.print("O");
    Serial.print("C");
    Serial.print("O");
    Serial.print("C");
    oxyLevel = vals[2];
    delay(400);
how should i type the loop delay into the prgram if i have to use two delays of 100ms and 400ms...
AWOL
#7
Mar 08, 2011, 02:48 pm Last Edit: Mar 08, 2011, 04:24 pm by AWOL Reason: 1
Like in reply #3.
(uncompiled, untested, still with scope for improvement.)
Code: [Select]
void setup( )
 nss.begin(9600);
void loop ()
 fn1 ();
 delay (100);
 fn1 ();
 delay (100);
 fn1 ();
 delay (100);
 fn1();
 fn2 ();
 delay (100);
void fn1( )
 float voltage = sensorValue * 0.0048; // code width(sensitivity) = 5 / 210  = 4.8mV
 Serial.print (voltage, 2);
 if( digitalRead(mercPin0))
   Serial.print(",O");
   Serial.print(",C");
 if ( digitalRead(tiltPin3))
   Serial.print("O");
   Serial.print("C");
 if(digitalRead(mercuryPin5))
   Serial.print("O");
   Serial.print("C");
 if( digitalRead(tiltyPin7))
   Serial.print("O");
   Serial.print("C");
void fn2 ()
   int heartMS = nss.read();
   int heartLS = nss.read();
   int oxyLevel = nss.read();
   int heartRate = ((heartMS & 3) << 8) + heartLS;
At some point in the future, you're going to look at this:
Code: [Select]
and think "?"
I remember a comment about the futility of this:
Code: [Select]
EDIT: Have you external pull-ups/pull-downs on the switch pins?
moomoo
ya i have external pull ups for the switches. Guys, i tried the program written by AWOL. My serial monitor doesn't show my heartrate and oxylevels readings when i connect my Pro Mini to the FTDI Breakout Board and open serial monitor. For my voltage and tilt switches combinations, the readings are super fast, not according to the delay. Why is this happening!?!?! :smiley-sad-blue:
AWOL
#9
Mar 09, 2011, 08:50 am Last Edit: Mar 09, 2011, 10:05 am by AWOL Reason: 1
Quote
Because I got fn1 and fn2 the wrong way around.
