Topic: Interfacing with AutoHotkey (Easy GUI's on Windows & Linux) (Read 29256 times) previous topic - next topic
kruzan
Mar 15, 2011, 04:52 pm Last Edit: Mar 16, 2011, 02:02 pm by kruzan Reason: 1
I have started a library for interfacing AutoHotkey with your Arduino.
These examples utilize the AutoHotkey scripting language [ http://autohotkey.com ]
Quote from: autohotkey.com
AutoHotkey is a free, open-source utility for Windows. With it, you can:
    * Automate almost anything by sending keystrokes and mouse clicks. You can write a mouse or keyboard macro by hand or use the macro recorder.
    * Create hotkeys for keyboard, joystick, and mouse. Virtually any key, button, or combination can become a hotkey.
    * Expand abbreviations as you type them. For example, typing "btw" can automatically produce "by the way".
    * Create custom data-entry forms, user interfaces, and menu bars. See GUI for details.
    * Remap keys and buttons on your keyboard, joystick, and mouse.
    * Respond to signals from hand-held remote controls via the WinLIRC client script.
    * Run existing AutoIt v2 scripts and enhance them with new capabilities.
    * Convert any script into an EXE file that can be run on computers that don't have AutoHotkey installed.
Getting started might be easier than you think. Check out the quick-start tutorial.
Here is the AutoHotkey forum thread. http://www.autohotkey.com/forum/viewtopic.php?t=69598&start=0&postdays=0&postorder=asc&highlight=arduino
This is the initial release, so there will be bugs, maybe some things are done weird, etc. I just need some feedback :)
The first example I'll give is moving a servo with a slider contol in a gui
(GUI picture below)
Moving a servo with a slider control
To use:
- attach a servo on pin 9
1)Extract the archive
2)Upload Servo.pde sketch to arduino
3)Open Arduino-servo.ahk
4)Edit your com port on line 15
5)Save Arduino-servo.ahk
6)drag Arduino-servo.ahk onto AutoHotkey.exe
7)click and drag and move the slider to move the servo
:D
I included the Autohotkey.exe for ease of use, you can get the executeable from the autohotkey.com site if you would rather. (it's in the zip download)
if you are on linux you need to do a couple things
install wine
Code: [Select]
$ sudo apt-get install wine
create a link from your linux tty device to emulate the com port
(replace ttyACM0 with the name of arduino that shows up in arduino ide)
Code: [Select]
$ sudo ln -s /dev/ttyACM0 ~/.wine/dosdevices/com2
make the AutoHotkey.exe file executeable
Code: [Select]
sudo chmod 777 AutoHotkey.exe
run the scripts like so:
Code: [Select]
wine AutoHotkey.exe CIRC10.ahk
you dont need to modify the .ahk files, they are setup to use COM2
Riaan Deyzel
Good day
Is it possible to do this for two servos, pan and tilt.
I have been strugling to control two servos with buttons (UP/DOWN/LEFT/RIGHT)in C#, C++ or VB, but with no luck.
I would rely appreciate it if you can help me with this, even if it is sliders for two servos.
Or if you know of a website with source code & scetch to control 2 servo's, please let me know.
Thank you & regards,
Riaan Deyzel
kruzan
You may be interested in this example :)
Origionally posted http://forums.adafruit.com/viewtopic.php?p=105119#p105119
This next example has 2 buttons. they each send a byte to the arduino.
the included arduino sketch listens for serial command and responds with a Y for 1 or an N for 2
To use:
2)Upload Command.pde sketch to arduino
3)Open Arduino-command.ahk
5)Save Arduino-command.ahk
6)drag Arduino-command.ahk onto AutoHotkey.exe
kruzan
#3
Mar 16, 2011, 01:49 pm Last Edit: Mar 16, 2011, 01:51 pm by kruzan Reason: 1
Here is that example slightly modifed to have more buttons
Code: [Select]
; AutoHotkey Version: 1.x
; Language:       English
; Platform:       Windows XP +??
; Author:         ahklerner / kruzan
; Script Function:
; Arduino GUI Example
; set some defaults
#NoEnv  ; Recommended for performance and compatibility with future AutoHotkey releases.
SendMode Input  ; Recommended for new scripts due to its superior speed and reliability.
SetWorkingDir %A_ScriptDir%  ; Ensures a consistent starting directory.
; serial settings
ARDUINO_Port     = COM2
ARDUINO_Baud     = 115200
ARDUINO_Parity   = N
ARDUINO_Data     = 8
ARDUINO_Stop     = 1
; setup arduino serial communication
arduino_setup()
; *****************GUI CODE***************
; add first button
Gui, Add, Button, gButton1_Press, Servo 1 Left
Gui, Add, Button, gButton2_Press, Servo 1 Center
Gui, Add, Button, gButton3_Press, Servo 1 Right
; add first button
Gui, Add, Button, gButton4_Press, Servo 2 Up
Gui, Add, Button, gButton5_Press, Servo 2 Center
Gui, Add, Button, gButton6_Press, Servo 2 Down
Gui, Add, Text,, Arduino Response:
Gui, Add, Text, vReply,**NO DATA RECEIVED YET**
; show the gui (it will be auto sized and positioned)
Gui, Show
return
; ******button action code ******
Button1_Press:
GuiControl,,Reply, % arduino_send("1")
return
Button2_Press:
GuiControl,,Reply, % arduino_send("2")
return
Button3_Press:
GuiControl,,Reply, % arduino_send("3")
return
Button4_Press:
GuiControl,,Reply, % arduino_send("4")
return
Button5_Press:
GuiControl,,Reply, % arduino_send("5")
return
Button6_Press:
GuiControl,,Reply, % arduino_send("6")
return
; *****Do not edit below this line unless you want to change the core functionality of the script*****
; called when the gui is closed
;also called when program exits
GuiClose:
OnExit:
; make sure to cleanly shut down serial port on exit
arduino_close()
; this is important!! or else theprogram does not end when closed
ExitApp
#include %A_ScriptDir%\include\Arduino.ahk
Here is example Arduino Sketch (needs servo code)
Code: [Select]
int command = 0 ;
 delay(1000);          // wait a bit before starting
 Serial.begin(115200);   // set up Serial library at 9600 bps
   if (Serial.available() > 0) {
   command = Serial.read();
   if (command == "1"){
//pan left
   }if (command == "2"){
//pan center
   }if (command == "3"){
//pan right
   }if (command == "4"){
//tilt up
   }if (command == "5"){
//tilt center
   }if (command == "6"){
//tilt down
   command = 0;
kruzan
This example is getting sensor data.
I decided to base it off of the oomlut CIRC10 example. [ http://www.oomlout.com/a/products/ardx/circ-10 ]
no modifications to the arduino sketch above are needed.
see image below what the example gui looks like on windows xp with zune theme
The necessary files are attached.
once you have completed the circuit as directed, and uploaded the arduino sketch from the example
To use:
2)Open CIRC10.ahk
3)Edit your com port on line 15
4)Save CIRC10.ahk
5)drag CIRC10.ahk onto AutoHotkey.exe
Riaan Deyzel
Good day
I would like to know of the following scetch will work for the "Here is that example slightly modifed to have more buttons" to control two servos on D9 & D10?, as the code supplied does not have servo code in it.
Code: [Select]
#include <Servo.h>
Servo myservo1;
Servo myservo2;
int command = 0 ;
Serial.begin(9600);   // set up Serial library at 9600 bps
myservo1.attach(9);
myservo2.attach(10);
    myservo1.write(command);                  // sets the servo position according to the scaled value
    Serial.println(command);
    delay(15);
    myservo2.write(command);                  // sets the servo position according to the scaled value
    delay(15);
    if (command == '1')
//pan left
    if (command == '2')
//pan center
    if (command == '3')
//pan right
    if (command == '4')
//tilt up
    if (command == '5')
//tilt center
    if (command == '6')
//tilt down
    command = 0;
kruzan
sorry, i thought if you were far enough along to try to make a gui to move your servos, you would already know what values to use to point the servo to a position
maybe this helps?
Code: [Select]
#include <Servo.h>
Servo myservo1;
Servo myservo2;
int command = 0 ;
myservo1.attach(9);
    if (command == '1'){
//pan left
myservo1.write(0);
delay(15);
    }else if (command == '2'){
//pan center
myservo1.write(90);
delay(15);
    }else if (command == '3'){
//pan right
myservo1.write(180);
delay(15);
    }else if (command == '4'){
//tilt up
myservo2.write(0);
delay(15);
    }else if (command == '5'){
//tilt center
myservo2.write(90);
delay(15);
    }else if (command == '6'){
//tilt down
myservo2.write(180);
delay(15);
    command = 0;
Riaan Deyzel
Thank you very much kruzan.
I will give it a go this weekend, and see how it works.
Regards,
Riaan Deyzel
Riaan Deyzel
I have tested this code, and it did not work, I will look further for the same app to control 2 servo's, but will look for c# code, as I do not know AutoHotKey at all.
Regards,
Riaan Deyzel
Jaaptina
In the arduino code command is defined as int. But void loop says (command == "1"). This is not okay. Changing it to if (command == '1') is better. But is seems akh is not sending a '1'. If I change to if (command == 1) than arduino recognises the command form akh. This way sending commands to Arduino works wel. However the akh GUI is still showing chineese caracters in response. So help is needed.
My arduino code with lcd shield:
#include <LCD4Bit_mod.h>           // initialise LCD library
LCD4Bit_mod lcd = LCD4Bit_mod(2);
int command = 0 ;
char buf[12];
  lcd.init();
  lcd.clear();           // clear screen of old display
  delay(1000);           // time to see the cleared screen
  lcd.printIn("Start");  // visible start after reset
  delay(1000);           // time to see the "Start" displayed
  lcd.clear();           // clear screen before display of first value
    lcd.clear();
    if (command == 1){show();}
    if (command == '2'){show();} // faulty
    if (command == '3'){show();} // fauly
    if (command == 4){show();}
    if (command == 5){show();}
    if (command == 6){show();}
    command = 0;
void show(){
  lcd.printIn(itoa(command, buf, 10));
bitcloud
G'day,
I'm hoping you might have some ideas how I could expand upon this...
Specifically I wish to have several sliders in AHK controlling several servos (and perhaps some examples of controlling RGB LEDs)
I can't figure out quite how to do this... Send a signal from AHK to prepare the Arduino code for incoming servo data? I've tried a bunch of things and nothing is working.
Kruzan, you seem to be some kind of genius on this topic... is there any chance you could help us out with some pointers on getting multiple sliders sending data to multiple servos via AHK?
Cheers
Drako
Ehi, where is the Library you were talking about at the beginning of this post?
Did you manage to complete it?
I want to make an autohotkey script to control my arduino and make it a stand alone (with a touch screen and everything). Your library sounds very interesting!
Taurion
I'm trying to get the arduino-command.ahk
To run and I keep getting the error:
Error in #include file "include\Arduino.ahk":
Call to nonexistent function.
Specifically: isFunc(f:=" OnSerialData")
What is wrong?
uxomm
The "Arduino.ahk" is to run on your PC not on your arduino.
".ahk" is the extension for AutoHotkey scripts. To run it on your (windows) pc, drag it onto AutoHotkey.exe. It does make no sense to include it in the arduino sketch.
Always decouple electronic circuitry.
