Loading...
Pages: [1]   Go Down
Author Topic: DS3231.h --- Library for DS3231 (or DS3232) real-time clock  (Read 3909 times)
Chico, CA
Offline Offline
Newbie
View Profile
WWW
I've written a header file/library/examples for the DS3231 clock: it's available here:
    http://hacks.ayars.org/2011/04/ds3231-real-time-clock.html
I wrote it for the DS3231, but the timekeeping registers are identical on the DS3232 so it'll work for that also.
This forum has been incredibly helpful to me over the years, and I hope this is a start on repayment. Drop me an email if you use it, and let me know if you find bugs so I can fix them right away.
-Eric Ayars
<firstname at lastname.org>
Logged
São Paulo/SP/Brazil
Offline Offline
Sr. Member
Brazilian Arduino Team
View Profile
WWW
Great work.
Just a suggestion, why not integrate on the Time Library? There's some examples using DS1307 already, just have to port to work with your library.
Time Library Link:
http://www.arduino.cc/playground/Code/Time
Logged
São Paulo/SP/Brazil
Offline Offline
Sr. Member
View Profile
WWW
I'm with some spare time so I made the library.
https://bitbucket.org/trunet/ds3231rtc
Fully compatible with Time Library and has getTemp method to retrieve temperature.
Just use the TimeRTC examples provided on Time and change DS1307RTC.h to DS3231RTC.h.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Thanks, Eric.  This is cool, I'll be needing that chip in the future and I am glad to have your work!
 smiley-grin
Logged
NZ
Offline Offline
Sr. Member
Turtle in a hard shell
View Profile
I was just curious if you are planning to upgrade this library to Arduino 1.0?
https://github.com/trunet/DS3231RTC
Regards
James
Logged
São Paulo/SP/Brazil
Offline Offline
Sr. Member
View Profile
WWW
it just needs minor updates. I can work with this next week maybe.
Logged
Offline Offline
Newbie
View Profile
As it turns out i ran into the same issue with the 1.0 ide and ended up updating it myself.
I ran the examples and they seem to work just fine.
i do not know if you already updated the code or not but here is the a copy of the files i updated.
The example codes remains unchanged but is now in an ino file.
http://soiling-detector.googlecode.com/files/DS3231updated.zip
Your orig lib and examples helped me understand how to get this IC up and running for my datalogger.
I have found a few of your sketches to be rather helpful.
Thank you
« Last Edit: February 09, 2012, 12:55:10 pm by jhub » Logged
São Paulo/SP/Brazil
Offline Offline
Sr. Member
View Profile
WWW
that's the way open source software works... thanks for your help and I'll update the code later.
Logged
Offline Offline
Newbie
View Profile
I set my clock with the example in the zip, and when I run the example test for some reason one time is exactly 6 hours off of the other.  The logs look like:
2012 2 17 5 19 30 25 24h T=20.00 O+
Alarm 1: 5 DoW 19 22 30 enabled
Alarm 2: 17 Date 19 23 enabled
12/2/17day of the week :5
13:30:26
Any ideas where I can look for the bug?  Or ideas what it may be?
Logged
Offline Offline
Newbie
View Profile
It appears from my tests that getHour() is returning the proper hours, but getTime() is not, looking at the code and there didnt seem to be any glaring differences though, any local pros have an idea?
Logged
Offline Offline
Newbie
View Profile
Found it, there is a bug on line 40 of DS3231.cpp where the hours are run through bdcToDec() twice.  To fix this, on line 40 change:
tempBuffer = bcdToDec(Wire.read());
to
tempBuffer = Wire.read();
After this your getTime() calls should read correctly!
Logged
Offline Offline
Newbie
View Profile
hm... how will i get leading zeros?
can anybody help?
Logged
Pages: [1]   Go Up
Print
Jump to:
