Pages: [1]   Go Down
Author Topic: Traktor Pro Arduino Midi Controller [Not working]  (Read 1491 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
i would like to create my own simple midi controller for the dj software traktor pro. After some minutes i implemented a little sketch:
Code:
  Serial.begin(31250);
  pinMode(13, OUTPUT);
  int sensorValue = analogRead(A0);
  int realVal = map(sensorValue, 0, 1023, 0, 20);
  if(realVal >= 10) {
    digitalWrite(13, HIGH);
    noteOn(0x90, 0x1E, 0x45);
    delay(2000);
    //Serial.print(0xFC,BYTE);
    digitalWrite(13, LOW);
void noteOn(int cmd, int pitch, int velocity) {
  Serial.print(cmd, BYTE);
  Serial.print(pitch, BYTE);
  Serial.print(velocity, BYTE);
I use Window 7 and Arduino Duemilanove. SensorValue contains the value from a cheap force sensitive resistor.
Everything works fine and when i press my sensor hard enough a midi message will be transmitted (Serial monitor).
I use MidiYoke and Serial Midi Converter to get a midi device for traktor. When I hit the "Lean Button" in traktor and then press the, nothing happens. I tried every possible combination but i don't get it to work :-(
What i'm doing wrong? Can someone help me please?
Thanks.
Logged
Global Moderator
Netherlands
Offline Offline
Shannon Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
Maybe there is a NoteOff() needed?
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I tried:
    //midi(144, 50, 50);
    //midi(128, 50, 50);
but nothing happens :-(
midi = noteOn();
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
What did i miss? :-(
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I found it!
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1161023163/30
You have to mod the FTDI USB Driver! Enjoy! :-)
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
What did i miss?
__________________
dressale.com vicyc.com  saleomg.com
Logged
Pages: [1]   Go Up
Jump to:
