Topic: NOOB needs help (7 segment countdown) (Read 15195 times) previous topic - next topic
Techone
I just finish a 2 digit multiplexer program. It just count up from 0 to 99 and repeat. I did use the BCD converter routine and my LED display routine. And just I said some FOR ( x=0;x<10;x++) statements. It is not test yet and with no comments. Anyway here is the code and let me know of what you think. I just hope it help others.  :)
Code: [Select]
size = 1432
Here a program to multiplex two LED display.
It will count from 0 to 99.
Parts:
1 - 7447 BCD to LED display decoder
1 - 330 ohms resistor network - 14 pins
or
7 - 330 ohms resistor
1 double common anode LED display
or
2 double common anode LED display
2 - PNP - 2N3906 transistor
2 - 1 k resistor.
Not tested yet. No comments yet.
Program by Serge J Desjardins <-- techone
Toronto, Ontario, Canada
const int led[6] = {9,10,11,12,8,7};
int pin;
int counting;
int dataone;
int datatwo;
int storage;
int looping;
  for (pin =0; pin < 6; pin++ )
     pinMode (led[pin], OUTPUT);
for (counting=0; counting<100; counting++)
  BCDconverter();
  for (looping=0; looping<25000; looping++)
    storage=dataone;
    displaydigit();
    digitalWrite (led[4],HIGH);
    digitalWrite (led[5], LOW);
    delay(17);
    storage=datatwo;
    displaydigit();
    digitalWrite (led[5],HIGH);
    digitalWrite (led[4], LOW);
    delay(17);
void BCDconverter()
  dataone=counting/10;
  datatwo=counting % 10;
void displaydigit()
  boolean A=bitRead(storage,3);
  boolean B=bitRead(storage,2);
  boolean C=bitRead(storage,1);
  boolean D=bitRead(storage,0);
  digitalWrite (led[3], A);
  digitalWrite (led[2], B);
  digitalWrite (led[1], C);
  digitalWrite (led[0], D);
AWOL
Code: [Select]
void displaydigit()
couple of things there;
1)"bitRead" doesn't return a "boolean"
2) "digitalWrite" takes an "int", not a "boolean".
Code: [Select]
void displaydigit()
  for (int i = 0; i < 4; ++i {
   digitalWrite (led[i], bitRead(storage,i));
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
Techone
1st.. Thank AWOL for the new, efficient routine by using the FOR statement. It does eliminate repetitions. Specially if I need to use 8 bits or more bits.  Example : Using Arduino to program an EPROM.
2nd.. I use boolean is because in digitalWrite ( pin#, HIGH ) or digitalWrite( pin# , LOW )  HIGH or LOW is a boolean value ---> 1 or 0
3rd.. I use bitread to isolate the bit I want to display whatever is 1 or 0.
Anyway thank AWOL for the new routine. I will use it.
Techone
Hey guys, I just finish to re-design and refine my 2 digit multiplex program. The program work, I "fine tune" it and with some modifications could be use for count down or display multidigit system ex: 8 display During testing, the Ardiuno just keep reset ( due to low power/current ) so please use a seperated power line ( +5 V ) if using a 7447 or 7448 chip. If using a CMOS type ( a 4000 series chips ) you can use the 9V ( going into the Ardiuno board ) And of course connect the ground from the Ardiuno to the circuit.
Here the code. I hope it help in some of your designs.
Code: [Select]
size = 1420
Version 1.6
Here a program to multiplex two seven-seqment LED display.
Tested and Worked
Parts:
or
1 double common anode or cathode 7 segment LED display
or
2 double common anode or cathode 7 segment LED display
2 - PNP - 2N3906 transistor for commun anode
2 - NPN - 2N3906 transistor for commun cathode
2 - 1 k resistor.
When you connect to the Arduino, please use a separated power for
the 7 segment display circuit. And dont forget the ground if I may
quote AWOL :)
const int led[6] = {9,10,11,12,7,8};
pin 12 is MSD to pin 9 is LSD
ABCD - pin 12,11,10,9
pin 7 is the unit
pin 8 is the ten's
int pin;
int counting;
int dataone;
int datatwo;
int storage;
int looping;
// init the Arduino Pins
// count from 0 to 99
  BCDconverter();
  for (looping=0; looping<200; looping++)
  // hold the display for 1 second
    storage=dataone; // display ten's and place data to be display
    displaydigit();
    digitalWrite (led[5], LOW); // turn on tens digit
    digitalWrite (led[4], HIGH); // turn off the unit digit
    if using PNP and commmun anode, need a LOW - 0 signal to
    turn the digit on.
    if using NPN and commun cathode, need a HIGH - 1 signal to
    turn the digit on.
    so just simply change LOW to HIGH or HIGH to LOW
    delay(5);
    the time delay is to prevent "flikering" or strobe effect
    the longer the delay, the stonger the strobe effect is.
    so keep the time short.
    storage=datatwo; // display unit and place data to be display
    displaydigit();
    digitalWrite (led[5], HIGH); // turn on unit digit
    digitalWrite (led[4], LOW); // turn off tens digit
    delay(5);
void BCDconverter()
extract the tens and the units numbers
void displaydigit()
display the data. ( see my LED display program )
And thank to AWOL for the Loop idea.
  for (int i = 0; i < 4; i++)
Techone
Just to add to the program (  multiplex 2 7 segment display ), here a schematic to connect to the Arduino
matiasparache
So many thanks for your work, i'll will try to make that counter. My goal is to send values from the monitor serie (like analog reads, values incoming from sensors, etc) to the display, in fact i have one 7-segment-2-digit display plus one 7-segment-1-digit display, and i have to work with the three digits at same time. Also i have two IC DM74LS47N, as i read in the datasheet i can control more than 3 digits, am i right? the question for you is, will you work with analogic signals passing thru 7447 and then to the displays?
