Topic: Finally a one Gig ohm resistor is avalible (Read 8793 times) previous topic - next topic
retrolefty
Aug 20, 2011, 07:04 pm Last Edit: Aug 20, 2011, 07:06 pm by retrolefty Reason: 1
Wonder what took them so long to make them avalible? Not sure it would be useful as a pull-down resistor for a arduino input pin.  ;)
Says useful for:
Suitable for Impulse voltage generators, arc furnace damping, energy research, pulse modulators, capacitor crowbar circuits, high voltage snubber circuits , X-ray/imaging equipment, and EMI/lightning supression
http://www.ebay.com/itm/1G-Ohm-3W-5-Resistance-Glaze-High-Voltage-Resistor-/230651855090?pt=LH_DefaultDomain_0&hash=item35b3ec00f2
I would suspect that just touching the body of this resistor and leaving finger prints on it would lower it's resistance value.
Lefty
Jack Christensen
Cool, right up there with 1-Farad capacitors. When I was in school a prof told us that a Farad was such a big unit that a 1F capacitor would be the size of a bathtub; well not quite, as it turns out.
Old cartoon I wish I still had, engineer standing outside the door, semi-trailer backed in, driver handing him papers, engineer says, "No, no, no! I wanted ten, one-million ohm resistors!"
retrolefty
Well size one needing a 100vdc rating and then you will have to clean out the bathtube to hold it.
robtillaart
(433 Farad at 15V - 48750 Joules
Think it is time for a warning to handle these with care ...
// 4.2 Joule can raise 1 gram water 1 degree C. ==> 48750J is enough to raise 1 Liter of water 10+ degrees,
// recall a human is 70% water, so it could raise all your water with 0.2C if spreaded evenly ..
// or raise the water in your index finger far above boiling point.....
Rob Tillaart
westfw
Moore's classic book on Electrostatics has a rule of thumb that 10J discharges can easily be fatal.
(That's for very high voltage circuits where body resistance is insignificant.  It gets more complicated when you have 48000 Joules at 15V.  Recent (and rather good) video here: http://www.youtube.com/watch?v=EoWMF3VkI6U )
cr0sh
#5
Aug 21, 2011, 02:56 am Last Edit: Aug 21, 2011, 03:02 am by cr0sh Reason: 1
Great video; I'm now envisioning a "micro arc-welding rig" in my future (it would cost $70.00 for the caps). I'm wondering, though, if it's possible get stick electrodes smaller than 1/16"...
:D
After some research - I'm now wondering if a micro-TIG rig might be possible... I must be nuts.
westfw
http://www.professionaljeweler.com/archives/articles/2000/apr00/0400mn3.html ??
retrolefty
It looks like you could get much more than 1F @ 100V in a shoebox with 7 of these...
Type 6 BOOSTCAP® Array (433 Farad at 15V - 48750 Joules)
So if we charge a 1F cap to 100 volts through the one Gig resistor(the OP was about using this resistor, lets stay on post subject  ;)  ), how long to fully charged state?
Lets see RC time contant = (10E9 X 1) =  31.7 years to just 63.2 volts ? Is that right? that's beyond my life expectancy!
Someone younger will have to take this project on and run with it.
Lefty
justjed
My landlord does this. Don't remember what size cap he's using though.
... it is poor civic hygiene to install technologies that could someday
facilitate a police state. -- Bruce Schneier
Grumpy_Mike
When I was at University on of the Lecturers (Profs in the U.S) Had a yellow warning triangle saying:-
WARNING ONE MILLION OHMS
Under which he stuck a 1M resistor
The cleaners kept clear of it.
Coding Badly
robtillaart
After seeing this vid I finally know how Darth Vader uses the Force... :)
Rob Tillaart
udoklein
#12
Aug 21, 2011, 06:30 pm Last Edit: Aug 22, 2011, 05:16 pm by Udo Klein Reason: 1
Although not just as cool there are other devices with similar low series resistance. The first thing that springs to mind are car engine starter batteries. A friend of mine (student of electrical engineering working on his thesis - a charger for electrical cars) once had a set of those in series for 600V. He was talking something about "small scale current riples". When I asked about small scale he said "almost nothing, you can barely measure it, maybe 20A". They also had some nice caps >1kF in their lab. I think these were some of the very first ultra caps. These guys had those for experimenting ~15years ago-
If I remember it right they used the caps to provide additional current while the (lead) batteries where not able to deliver enough current.
bld
captain-slow.dk | non contagious!
retrolefty
I want one!!! Not sure why through...
Me neither. Part of me does, but part of me says: hell, its got +/- 50 Meg ohms tolerance, what a POS.
Lefty
