Loading...
Pages: [1]   Go Down
Author Topic: DL2416 Intelligent LED Display using Arduino  (Read 976 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
Here's a Siemens DL2416 intelligent LED alphanumeric display being run by a Boarduino:
Code:
/* DL2416T intelligent 16-segment display test
   version: 0.2
   author: Alex Davis
   hardware: Atmega168 or Atmega328 Arduino
   Sends text to a directly-connected DL2416T 16-segment
   four-character alphanumeric display.
   There are probably enough pins to do four displays
   without external logic. As is the code does just one.
   If you debug using Serial you will set d0 high and throw off every other character.
#include <avr/pgmspace.h>
// strings to display stored in EEPROM
// don't put spaces at the start - the code assumes there won't be any
// do put a space on the end
prog_char string0[] PROGMEM = "SING WHILE YOU MAY ";
prog_char string1[] PROGMEM = "LIKE A FLY THAT'S TRAPPED ON A WINDOW ";
prog_char string2[] PROGMEM = "SING WHILE YOU MAY ";
prog_char string3[] PROGMEM = "THOUGH THERE'S NOTHING IN THE WORLD ";
prog_char string4[] PROGMEM = "THAT YOU CAN CHANGE ";
prog_char string5[] PROGMEM = "SING WHILE YOU MAY ";
prog_char string6[] PROGMEM = "'CAUSE IT MAY NOT BE VERY LONG ";
#define NUM_STRINGS 7
#define MAX_SIZE 81
// an array of strings
// if you change the number of strings above
// update this as well to match
PROGMEM  const char *stringSet[] = {string0,
string1,
string2,
string3,
string4,
string5,
string6
// function prototypes
void formatStr(char []);
void displayChar(char, int, byte);
// set ports and pins
  byte pinLoop;
  // set port d to all outputs, except serial in
  // then set them low
  DDRD = B11111110;
  PORTD = B00000000;
  // set pins 8-16 to outputs
  for (pinLoop = 8; pinLoop < 17; pinLoop++) {
    pinMode(pinLoop, OUTPUT);
  // set the pin states
  // use 8 for BL and set to HIGH
  digitalWrite(8, HIGH);
  // use 9 for AO and set to LOW
  digitalWrite(9, LOW);
  // use 10 for A1 and set to LOW
  digitalWrite(10, LOW);
  // if you tie C1 and C2 on each display
  // then 11 can be for display0
  // and 12 can be for display1
  // use 11 for C1 and set to HIGH
  digitalWrite(11, HIGH);
  // use 12 for C2 and set to HIGH
  digitalWrite(12, HIGH);
  // use 13 for CLR and set to HIGH
  digitalWrite(13, HIGH);
  // use 14 for CU and set to HIGH
  digitalWrite(14, HIGH);
  // use 15 for WR and set to HIGH
  digitalWrite(15, HIGH);
  // use 16 for CUE and set to LOW
  digitalWrite(16, LOW);
// main
  byte i;
  // buffer string stored in RAM
  char currentString[MAX_SIZE];
  for (i = 0; i < NUM_STRINGS; i++)
    // copy a string from the array of strings in the EEPROM
    // to a local buffer string in RAM
    strcpy_P(currentString, (char*)pgm_read_word(&(stringSet[i])));
    // parse the string for display
    formatStr(currentString);
    // pause a bit
   function formatStr
   purpose: formats a string for display on a DL2416T
   expects: a pointer to a string
   returns: nothing
void formatStr(char toDisplay[])
  int wStart = 0, // start of word in string
  wEnd = 0; // end of word in string
  int count = 0, // string position counter
  x = 0, // string position counter for word < 5
  n = 0, // display counter for word > 5 mid-word
  wordLen = 0, // length of string
  d = 0, // display counter for word >5 end word
  dLen = 0; // length - 1 for display purposes
  byte displayNum = 0; // selects display 0 or 1
  byte setChar;
  int segCount = 0;
  // loop until the end of the string
  while (toDisplay[count] != '\0')
    // assume string begins a word and not with a space
    wStart = count;
    wordLen = 0;
    // find the length of the word until we reach a space
    // or the end of the string
    while ((toDisplay[count] != ' ') && (toDisplay[count] != '\0'))
      // set the end to the current location
      // when we drop out of the loop this will be
      // the last character in the word
      wEnd = count;
      // move to the next position in the string
      count++;
      // increment the character count
      wordLen++;
    // display directly if it fits on the display
    if (wordLen < 5)
      // write the characters between wStart and wEnd directly
      // to the display
      // back through the buffer array and set one character
      // on the display at a time
      // blank the display
      digitalWrite(8, LOW);
      delay(1);
      // go through the buffer array backwards and write the
      // characters to the display
      segCount = 0;
      for (n = wEnd; n > (wStart - 1); n--)
        // send the character, display position and display
        displayChar(toDisplay[n], segCount, displayNum);
        segCount++;
      // unblank the display
      // a pause to read the word
      delay(750);
      // clear the display
      digitalWrite(13, LOW);
      delay(2);
    // if it is more than four characters long
    // display using the scrolling method
    if (wordLen > 4)
      dLen = wordLen - 1;
      // write the characters between wStart and wEnd so they
      // appear to scroll from left to right
      // it takes length + 2 iterations to scroll
      // all the way to the last character
      // we will use x to keep track of where we are in the
      // scrolling process
      for (x = 0; x < (wordLen + 3); x++)
        delay(2);
        // scroll until the fourth character in the word
        // read the buffer backwards
        if (x < 4) {
          segCount = 0;
          for (d = (wEnd - (dLen - x)); d > (wStart - 1) ; d--)
            displayChar(toDisplay[d], segCount, displayNum);
            segCount++;
        // after the fourth character scroll on
        // until the end of the word
        if ((x > 3) && (x < wordLen))
          segCount = 0;
          for (d = wEnd - (dLen - x); d > ((wStart + (x - 3)) - 1); d--)
            segCount++;
        // once we get to the end of the word
        // scroll off by reading forwards in the array
        // while counting backwards in the display position
        if (x > dLen)
          segCount = 3;
          for (d = (wStart + (x - 3)); d < (wEnd + 1); d++)
            segCount--;
      // a small delay between scroll
      delay(200);
      delay(2);
    count++;
} // end function formatStr
   function displayChar
   purpose: displays a character on a DL2416T
   expects: a character, a position and a display (0,1,2 etc...)
   returns: nothing
void displayChar(char myChar, int myPos, byte myDisp)
  /* here's how to set a character:
         1. select an address using a0-a1 which here are arduino pins 9-10
         2. pull WR to LOW to enable loading
         3. send the bit-shifted character to the data lines d0-d6 all at once using PORTD
         4. set the WR pin back to HIGH
         5. repeat for next character
  // right now we only do one display
  // but logic for more would be added here
  // using a case if more than one were used
  if (myDisp == 0)
    // enable display 0 by setting C1-C2 LOW
    digitalWrite(11, LOW);
    // disable display 1 by setting C1-C2 HIGH
    delay(2);
  // we are going to set the ASCII character all at once on PORTD
  // but we must avoid pin 0, which is serial RX
  // so we will shift one bit to the left
  myChar = myChar << 1;
  // the segment position is the opposite of the array
  // eg. seg0 is array[3]
  // set the character pin state
  // cheap binary conversion of setChar
  switch (myPos)
    case 0:
    case 1:
      digitalWrite(9, HIGH);
    case 2:
      digitalWrite(10, HIGH);
    case 3:
  // set the WR pin LOW to enable loading
  digitalWrite(14, LOW);
  delay(2);
  // set the shifted character to PORTD
  PORTD = myChar;
  delay(2);
  // set WR pin HIGH to finish loading
  delay(2);
} // end function displayChar
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
here's the link to the video:
It's a small display, so the code takes an array of strings, breaks them down into words, and then displays them all at once if they fit or scrolls them if they don't. I did it all using just the array index so as to conserve RAM.
Logged
North York, Ontario
Offline Offline
Full Member
Arduino rocks!
View Profile
Awesome, Ive been contemplating figuring out how to hook these up, and youve done the work for me! Looks good, thanks!
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Where did you get that display at? I can't seem to find a good 4 digit 14 segment display.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I pulled them out of some surplus lab gear I bought for a few dollars. I wouldn't recommend trying to buy them online. They exist, but the prices are outrageous. Too bad, I do like how they look.
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
They are called star burst displays and are not so expensive, here is a random one I found:-
http://uk.farnell.com/avago-technologies/hdsp-a47c/led-display-starburst-4-digit-cc/dp/1003351
The one featured in the video is no longer manufactured but I beleve it is this one:-
http://uk.farnell.com/avago-technologies/hpdl-1414/led-display-alphanumeric/dp/1175585
« Last Edit: November 05, 2009, 08:46:14 am by Grumpy_Mike » Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Here's an update to the functions to support a second display:
Code:
   function formatStr
   returns: nothing
  dLen = 0, // length - 1 for display purposes
  offset = 0; // an offset to center the word on the display
  byte displayNum; // selects display 0 or 1
  byte setChar;
  int segCount = 0;
    wStart = count;
    wordLen = 0;
      wEnd = count;
      count++;
      wordLen++;
    // start with 1st display, displayNum = 0
    displayNum = 0;
    if (wordLen < 9)
      // to the display
      delay(1);
      segCount = 0;
        // calculate an offset to center the word
        if ((wordLen > 0 ) && (wordLen < 4))
          offset = 3;
        if ((wordLen > 3) && (wordLen < 6))
          offset = 2;
        if ((wordLen > 5) && (wordLen < 8))
          offset = 1;
        // apply the offset to the segCount
        segCount = segCount + offset;
          // move to 2nd display if segCount > 3
          // eg. displayNum = 1
          if (segCount > 3)
            displayNum = 1;
        segCount++;
      delay(750);
      delay(2);
    // if it is more than eight characters long
    if (wordLen > 8)
      dLen = wordLen - 1;
        delay(2);
        // scroll until the eighth character in the word
        if (x < 7) {
            // start with the first display
            displayNum = 0;
          segCount = 0;
                if (segCount > 3)
                  displayNum = 1;
            segCount++;
        // after the eighth character scroll on
        if ((x > 7) && (x < wordLen))
          segCount = 0;
            displayNum = 0;
                if (segCount > 3)
                  displayNum = 1;
            segCount++;
        if (x > dLen)
          segCount = 7;
                // move to 1st display if segCount < 4
                // eg. displayNum = 0
                if (segCount < 4)
                  displayNum = 0;
            segCount--;
      delay(200);
      delay(2);
    count++;
   returns: nothing
  // enable the correct display
  if (myDisp == 0)
    delay(2);
  if (myDisp == 1)
     // enable display 1 by setting C1-C2 LOW
    digitalWrite(12, LOW);
    // disable display 0 by setting C1-C2 HIGH
    delay(2);
    // convert the 7-0 word frame position to the
    // actual position on display 1
    myPos = myPos - 4;
  switch (myPos)
    case 0:
    case 1:
    case 2:
    case 3:
  delay(2);
  PORTD = myChar;
  delay(2);
  delay(2);
I wanted to have my words centered (more or less). It would not be hard to left-justify instead - just adjust the offset section.
Next stop for this project is to move it beyond the breadboard and add in support for an SD card. The ultimate goal is a handheld speed-reader. Reading one word at a time you can read more than 600 WPM. But I'll need a source for a modern, available display. It'll need to be an OLED or VFD. I don't think an STN LCD will be fast enough.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Auugh! The above code does not work, but this does:
Code:
   function formatStr
   returns: nothing
  byte setChar;
  int segCount = 0;
    wStart = count;
    wordLen = 0;
      wEnd = count;
      count++;
      wordLen++;
    displayNum = 0;
    if (wordLen < 9)
      // to the display
      delay(1);
      segCount = 0;
        if (wordLen < 2)
          offset = 4;
        if ((wordLen > 1 ) && (wordLen < 4))
          offset = 3;
          offset = 2;
          offset = 1;
          if (segCount > 3)
            displayNum = 1;
        segCount++;
      delay(750);
      delay(2);
        // reset offset
        offset = 0;
    if (wordLen > 8)
      dLen = wordLen - 1;
      for (x = 0; x < (wordLen + 7); x++)
        delay(2);
        if (x < 8) {
            displayNum = 0;
          segCount = 0;
                if (segCount > 3)
                  displayNum = 1;
            segCount++;
          segCount = 0;
            displayNum = 0;
          for (d = wEnd - (dLen - x); d > ((wStart + (x - 7)) - 1); d--)
                if (segCount > 3)
                  displayNum = 1;
            segCount++;
        if (x > dLen)
          segCount = 7;
            displayNum = 1;
          for (d = (wStart + (x - 7)); d < (wEnd + 1); d++)
                if (segCount < 4)
                  displayNum = 0;
            segCount--;
      delay(200);
      delay(2);
    count++;
   returns: nothing
  if (myDisp == 0)
    delay(2);
  if (myDisp == 1)
    delay(2);
    myPos = myPos - 4;
  switch (myPos)
    case 0:
    case 1:
    case 2:
    case 3:
  delay(1);
  PORTD = myChar;
  delay(1);
  delay(1);
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I am an absolute Arduino newbie.  I have been trying to connect the HDPL 1414 display to an Arduino Duemilanove.  This is slightly different from to your situation and I am confused about the pin assignment.  Could you please post a quick scheme of the connections in this case?  Thank you very much for your help.
Logged
Rural Arizona
Offline Offline
Edison Member
Incorrigible tinkerer
View Profile
Quote
It's similar,  but not the same:  the 2416 has larger digits,  and a couple of extra chip select lines.  Probably brighter,  too,  since it came along a little later.
The big difference between those and the "starburst" displays you mentioned is the on-chip decoder/driver logic that makes them more convenient to use if you just need a few characters of alphanumeric display for a hobby project.  The tiny characters and limited set kinda limit their appeal to young geeks with good eyesight and old geeks with excessive levels of nostalgia,  though:  not so interesting to a generation that expects even a $5 wristwatch to display an animated,  full-color image of a crowing rooster when that alarm goes off  smiley
Ran
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Datasheet here:
http://www.avagotech.com/docs/5988-3271EN
Looks similar but the pins assignments are moved around a bit. It should be easy to get this working.
Logged
Pages: [1]   Go Up
Print
Jump to:
