Topic: Single Pulse Help. (Read 2098 times) previous topic - next topic
anura92
Nov 02, 2011, 01:32 pm Last Edit: Nov 02, 2011, 02:31 pm by anura92 Reason: 1
Hey arduino community,
Edited:
This exactly  what i'm trying to do:
I have an LDR  and up/downCounter circuit. For now, I want the counter to count up everytime the LDR is activated. In other words, every time the LDR is covered with my hand, it will sent a single pulse to my counter circuit.
Diagram:
http://www.flickr.com/photos/64214999@N05/6305469215/
Counter Circuit (* ignore other connection as this was take from an old project):
http://www.flickr.com/photos/64214999@N05/6276037343/in/photostream/
LDR Circuit:
http://farm7.static.flickr.com/6229/6276037577_ddef4f15be.jpg
I start with this code... but i'm new so mine horrible coding.
Code: [Select]
int up = 9;
int ldr = 8;
pinMode(up, OUTPUT);
pinMode(ldr, INPUT);
if (ldr == HIGH){
digitalWrite(up, HIGH);
else if (ldr == LOW){
digitalWrite(up, LOW);
Thanks,
Anura  XD
PaulS
Quote
I have a up/down counter
You need to describe this in more detail. Is this somehow connected to an Arduino?
Quote
i want it to sent a single pulse like on the digital trainers.
Like so?
Code: [Select]
Serial.print("pulse");
What is "it" what should send this pulse? Where should it send it to? How long should the pulse last?
Quote
I wondering if can give me some advice?
Yes.
AWOL
You may need
Code: [Select]
Serial.print("-pulse"); if you want a negative-going pulse
"Pete, it's a fool (who) looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
anura92
I have edited my question. Thanks anyway.
AWOL
Code: [Select]
if (ldr == HIGH){
You have given "ldr" the value 8.
That is never going to equal HIGH (aka 1)
You're missing a "digitalRead (ldr)"
anura92
But i have to define the ldr pin right?
I just added the "digitalRead (ldr)" to the "void loop" but it does no work.
AWOL
Quote
Yes, but you have to check what the return value is.
You did that, right?
anura92
I managed to tweak the code by using "analogRead".
Thanks anyway.
