Topic: Arduino 100hz PWM output (Read 4288 times) previous topic - next topic
Z0rr0
Nov 23, 2011, 06:49 am Last Edit: Nov 23, 2011, 06:46 pm by Z0rr0 Reason: 1
I'm trying to get 100Hz PWM out of pin9 to drive a DC motor, and vary the duty cycle via a Pot.
Here is the code i have so far. I'm VERY new to this.
Any Help would be appreciated
int sensorPin = A0;    // select the input pin for the potentiometer
int sensorValue = 0;  // variable to store the value coming from the sensor
int outputValue = 0;
void setup(){
  Serial.begin(19200);
pinMode(9, OUTPUT);
TCCR2B = TCCR2B & 0b11111000 | 0x06;
void loop(){
  sensorValue = analogRead(sensorPin);
  outputValue = map(sensorValue, 0, 1023, 0, 255);
  analogWrite(9, outputValue);
  Serial.println(outputValue);
CrossRoads
Have you read this
http://www.arduino.cc/playground/Main/TimerPWMCheatsheet
& this?
http://www.arcfn.com/2009/07/secrets-of-arduino-pwm.html
PaulS
Posting code that won't compile wastes everybody's time.
Z0rr0
really?
it would have been much easier for you to say, "Hey man, you are missing a } at the end of your setup statement"
PaulS
Quote
post code that compiles.
Z0rr0
Quote
I fixed it, if you don't have anything to say about the question i am asking, Please GTFO.
Z0rr0
im just looking for confirmation that this line:
will give me about 125Hz on pin 9
CrossRoads
#7
Nov 24, 2011, 04:48 am Last Edit: Nov 24, 2011, 04:49 am by CrossRoads Reason: 1
I think you need 0x04 vs 0x06 per here
Pins 9 and 10: controlled by timer 1
Setting          Divisor           Frequency
0x01        1        31250
0x02        8        3906.25
0x03        64        488.28125
0x04        256        122.0703125
0x05        1024        30.517578125
to yield 122 Hz.
Z0rr0
0x01        1        31250
0x02        8        3906.25
0x03        64        488.28125
to yield 122 Hz.
awesome, thanks. I'll give that a try.
i'm trying to switch a 12V load, and when i hook up 12V to the fet, it powers up the arduino. I fear i may need a diode or something on the emitter pin of the fet. Any ideas?
CrossRoads
Sounds like you have the FET wired wrong.
Should look like this as example (from a prior discussion - right hand regulator was meant to be 7805), with a Logic Level FET.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
