Topic: please help with WS2811 led IC (Read 40441 times) previous topic - next topic
ozeri
Hello all,
I recently bought LED strips that has 2811 IC.
I had no idea 2811 is so different from 2801 as it has no clock wire.
can someone help me with Arduino coding for that ?
As all samples online are for the 2801 and use both Data and clock lines, the 2811 seems to have only data line.
I have no idea how to get started with that.
I attached the PDF datasheet
Thanks,
Dror
KirAsh4
I could be interpreting this wrong, but I think you send it all the information, for all the LEDs in the string, then pull the reset low >50us.  This is actually not that different from the WS2801 or WS2803 with the exception that those use 2-wire communications.  The WS2811 uses 1-wire.
I'd say, start experimenting.  Take the code for the WS2801, get rid of the CLK lines since this one doesn't have one anyway, and change the reset timing.  See what happens.
Grumpy_Mike
I don't think you can do it. If you look at the timing you have to be accurate to 100nS and there simply isn't enough time in a 16MHz processor to do that, it turns out to be about two clock cycles. Even in machine code the overhead of reading data and producing those two diffrent waveforms times is too tight.
I think you will have to have a diffrent processor, one that runs faster. Or a very fancy piece of hardware.
KirAsh4
Ah, I missed that part ...  Hrm, maybe the newer AT32UC3 MCUs?
ozeri
I experianced it a lot like you said, using one wire, without the clock.
it just doesn't work. it could be the clock speed as I tried different pauses.
any other idea for Arduino implementation with this 2811 ?
can you send me simple sample code, based on the HIGH/LOW needed, maybe I do something wrong as I'm not expert.
I knew I shouldn't trust the guy selling me 2811 saying it's same as 2801, now I have 600 useless leds...
Thanks for your help
Grumpy_Mike
Yes that is what I said.
The signals it requires are too fast to do with an arduino, at least not in a way I can think of.
It requires signals with a resolution of 100nS, that is an accuracy of 10MHz, as the Arduino has a clock of only 16MHz then you can't do it.
The best I could think of is if you made some sort of shift register / counter arrangement with a 10MHz clock and some handshaking inputs. Even then you would have to run the whole thing from machine code with the interrupts off.
Another point, there is a line on that chip that puts it into double speed mode. If that is set on your strip then you are in even more trouble.
Negative feedback is probably your only course of action.
ozeri
ha ha, he was fine, very good service, even sent me the Datasheet before.
I just trusted him too much... my fault.
how about using my computer with the usb or something like that ?
I know VB programming if it can help.
Dror
Grumpy_Mike
No that won't help, you need to generate two signals, one is high for 0.5uS and low for 2uS and the other is high for 1.2uS and low for 1.3uS. These represent your zeros and ones.
Then you need to stream them out in a package of 24 bits per LED in your strip, that is not so much of problem.
You can't generate signals of that sort without either a fast processor that is not wrapped up in an operating system or some external hardware like a fist full of logic gates or better still a small FPGA. This is probably what is used on the controllers they sell for this product.
ozeri
I will contact supplier and get 2801. it will be much easier.
after your answer, i did an experiment with some direct port coding, it seems to have some resaults.
something like:
PORTD = B00000100;
for (int i = 0 ; i < t ; i++ ) {
   __asm__("nop\n\t");
PORTD = B00000000;
where t is the pause cycles, so far 0 is the best break.
what do you think ? good direction ?
Grumpy_Mike
The problem is that at 16MHz each clock pulse of the mico takes 62.5nS and you are trying to make a signal that has a resolution of 100nS. So you have to do the whole thing in machine code, that includes the for / next bit. You will notice also that 62.5nS is not a multiple of 100nS so it is not going to be a precise signal. If you had a 20MHz processor then things divide a bit better allowing you two clock cycles per resolution. This is still not going to be easy to code but you might stand more of a fighting chance.
Not all machine code instructions take one clock cycle many take more so I don't see how you have the time to generate this sort of signal. You might be better off trying this with a propeller chip in machine code.
KirAsh4
Since some of the Atmel chips claim 'up to 20MHz', what if he builds a standalone unit with a 20MHz crystal?
Grumpy_Mike
No it is all the chips. Yes you could do that, I have built a 644 system to run my reprap, but it is only 20MHz so it is not a great advantage. A propeller on the other hand can run up to 80MHz.
ozeri
as I said I'm not a pro but let me see if I get it right:
the most important thing is not the time of sending high and low, it can be slower and have few cycles
AS LONG AS you don't trigger the Return commend! but to trigger this, you need above 50 microsecends break.
so, all the IF, LOOP ect will not take that long and not trigger the return as long as you keep sending HIGH/LOW data,
I can trigger high low fast enough with the PORTD command and also have a tolerance of ±150ns for each bit HIGH/LOW.
am I right with this direction?
KirAsh4
Then grab one of the new UC3 Atmels ... 66MHz.  Or their ARM series ...
Is there support yet for the UC3 series, for Arduino that is.  Anyone know if cores have been developed yet?
ozeri
Just to sum things up here for future searches:
you were right, even with lots of tries, my way may work with 1-5 leds, but as soon as I go to 20-50, it just doesn't.
I get a lot of inconsistency.
I gave it up, and 600 leds went down the drain...
I bought new 100 leds with 2801 today. hope this should work smoothly.
Thank you all for your great help. you saved me a lot of time on keep tring forever to get the 2811 to work.
Thanks
