Topic: arduinosudoku (Read 1 time) previous topic - next topic
carl47
Oct 18, 2010, 03:56 am Last Edit: Oct 18, 2010, 04:16 am by carl47 Reason: 1
I have always been a fan of sudoku.
The first program I wrote for sudoku  used visual basic.
I then rewrote it in C to run on linux.
I expanded it to C++ and incorporated all the functions in a .dll
I used this .dll in a VB program to run on windows.
http://sourceforge.net/projects/mysudoku/files/
I wanted a break from my weather station project.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1283073954
It is not possible to have the whole sudoku solution in memory.
This would take 81 * what I have used.
My sudokuarray uses 3*3*3*3*3*3 = 729 bytes.
It could be done with external memory.
The program prints out a random completed sudoku each time its run.
A LCD display and a joystick would be able to display the full sudoku as I have done in the linux/windows program.
The program uses brute force. Random numbers are selected until we have a complete solution. No attempt has been made to use the finer rules of sudoku construction.
It's runs in fractions of a second on a PC.
It takes 1 to 20 seconds on the arduino.
The code is in three parts the first part is:
Quote
//sketch for Arduino 2009 (with 328)
//each time the sketch runs it prints out a random completed sudoku
char sudokuarray[3][3][3][3][3][3];
char arraynumber = 0;
  Serial.begin(9600);   // initialize serial communications at 9600
  randomSeed(analogRead(0));
}//end of setup
 generatesudoku();
 if(arraynumber > 80)
 printout();  //solved sodoku
 while ( 0 == 0)
 asm volatile("nop"); //sit here after printed one sudoku
 }//end of print out
}//end of loop
void generatesudoku(void)  //generate a sudoku
 construct(); //start with new array
 arraynumber = 0;
 boolean noblanks = true;
 while((arraynumber < 80) && noblanks)
 char x = random(9);
 char y = random(9);
 char number = random(9);
 setnumber(x,y,number);
 checkselection();
 for(char xl = 0; xl <3; xl++)
 for(char yl = 0; yl <3; yl++)
  for(char xs = 0; xs <3; xs++)
   for(char ys = 0; ys <3; ys++)
    char numberselected = 0;  //find how many zero's in this box
    for(char yn = 0; yn <3; yn++)
     for(char xn = 0; xn <3; xn++)
     if( sudokuarray[xl][yl][xs][ys][xn][yn] == 0)
       numberselected += 1;  //count number in this box
      }//next xn
     }//next yn
      if(numberselected == 9)
      noblanks = false;
   }//next ys
  }//next xs
 }//next yl
}//next xl...checked all for any blanks
 }//end of get random sudoku
}//end of generate sudoku
carl47
#1
Oct 18, 2010, 03:58 am Last Edit: Oct 18, 2010, 04:02 am by carl47 Reason: 1
The second part is:
Quote
void checkselection(void)  //see if one or two numbers can be selected
while(findsingle() == 0)  //find if one can be selected
}// end of check selection
char findsingle(void)  //select standalone number and return if found
char bignumber = 0;  //holds the selected number
char nonselect = 1;  //flag for standalone number = 0 for true
 for(char yl = 0 ; yl <3; yl++)
  for(char xs = 0; xs <3 ;xs++)
            bignumber = sudokuarray[xl][yl][xs][ys][xn][yn];
      }//next xn
     }//next yn
      if((numberselected == 8) && (bignumber < 0x40))
      setnumber(xl *3 + xs,yl *3 + ys,bignumber - 0x31);  //select the stadalone
         nonselect = 0;  //we have found a stand alone number
      }//end of number selected if
   }//next ys
  }//next xs
 }//next yl
}//next xl...............................all done
return nonselect;
}//end of select standalone number
void setnumber(char x, char y, char number)
{//values 0 t0 8
 boolean selected = false;  //check to see if number already selected
 boolean nopossible = false;  //check to see if no possibilities to select exist
 boolean crossedout = false;  //check to see if the number has been crossed out
 if(sudokuarray[x/3][y/3][x%3][y%3][number%3][number/3] == 0)
 crossedout = true;  //the number has been crossed out
  for(int yn = 0; yn <3; yn++)  // in this number box
     for(int xn = 0; xn <3; xn++)
      if (sudokuarray[x/3][y/3][x%3][y%3][xn][yn] > 0x40)
             selected = true; //this number already selected
      if (sudokuarray[x/3][y/3][x%3][y%3][xn][yn] > 0)
             nopossible = true;  //at least one possible number exists
      }//next xn
     }//next yn
 if(( ! selected) && (nopossible) && (! crossedout))  //number not selected
   {//select if a its a possible and its not crossed out
   sudokuarray[x/3][y/3][x%3][y%3][number%3][number/3] += 0x10;
   arraynumber += 1;  //we have a number selected
char j = 0;
char i = 0;
for (j = 0; j <3; j++)  //set all to zero except selected number in box
 for (i = 0; i <3; i++)
      if(sudokuarray[x/3][y/3][x%3][y%3][j] < 0x40)
   sudokuarray[x/3][y/3][x%3][y%3][j] = 0;
 }//end of i for
}// end of j for
for (j = 0; j <3; j++)  //horizontal line cannot have this number
      if(sudokuarray[j][y/3][y%3][number%3][number/3] < 0x40)
   sudokuarray[j][y/3][y%3][number%3][number/3] = 0;
 }//end of i for
}// end of j for
for (j = 0; j <3; j++)  //vertical line cannot have this number
 for ( i = 0; i <3; i++)
      if(sudokuarray[x/3][j][x%3][number%3][number/3] < 0x40)
   sudokuarray[x/3][j][x%3][number%3][number/3] = 0;
 }//end of i for
}// end of j for
for (j = 0; j <3; j++)  //box of 9 numbers cannot have this number
      if(sudokuarray[x/3][y/3][j][number%3][number/3] < 0x40)
   sudokuarray[x/3][y/3][j][number%3][number/3] = 0;
 }//end of i for
}// end of j for
   }//end of select number
}//end of set a number
void printout()
  for(char yl = 0; yl < 3; yl++)
  for(char ys = 0; ys < 3; ys++)
  for(char i = 0; i < 81; i++)
   Serial.print(byte(0xaf));
   Serial.println("");
 for(char yn = 0; yn < 3; yn++)
 for(char xl = 0;xl<=2;xl++)
  Serial.print(byte(0x7c));
 for(char xs = 0; xs < 3; xs++)
    Serial.print(" ");
     for(char xn = 0; xn < 3; xn++)
     Serial.print(" ");
     char n = 0;
     n = sudokuarray[xl][yl][xs][ys][xn][yn];  //the solved sudoku
     if(n > 0x40)
     n -= 0x10;  //number is selected so show as 1 to 9
     if(n == 0)
     n = 0xad;  //crossout sign
     Serial.print(n);
      }//next xn
 }//next xs
 Serial.print(" ");
}//next xl
  Serial.print(" ");
  Serial.println("");
}//next yn
}//next ys
   Serial.println("");
}//next yl
}//end of printout the sudoku
carl47
#2
Oct 18, 2010, 04:03 am Last Edit: Oct 18, 2010, 04:11 am by carl47 Reason: 1
And one last function:
Quote
void construct(void)
 //fill the arrray with pencil 1-9 in all the small squares -81 of them
char number =0x31; //start with "1" and move on to "9"
 for(char yl = 0;yl<=2;yl++)
  for(char xs = 0;xs<=2;xs++)
   for(char ys = 0;ys<=2;ys++)
    for(char yn = 0;yn<=2;yn++)
     for(char xn = 0;xn<=2;xn++)
      sudokuarray[xl][yl][xs][ys][xn][yn] = number;//fill the first step
      number = number + 1;  //put in 1 to 9
      }//next xn
     }//next yn
      number=0x31;  //1 to 9 in box now do next
   }//next ys
  }//next xs
 }//next yl
}//end of construct
Si
Why? Because you can of course!
Excellent.
My New Arduino Book: http://www.arduinobook.com
carl47
Simon thanks.
Yes I do it because its there to be done.
And of course it keeps me entertained.
I dont want to construct a full arduino sudoku myself because my priority is to finish my weather station.
I would really like to see someone construct one.
All or part of the code is completely free to reuse.
carl47
#5
Nov 22, 2010, 08:31 am Last Edit: Nov 22, 2010, 08:44 am by carl47 Reason: 1
I have added to the basic sudoku program by the addition of 32k byte ram.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1290379685
This now allows tracking of the sudoku solution steps.
In the sketch sudokuram.pde the arduino now prints out the
random sudoku followed by the start position for this solution.
You can set how hard the solution will be by setting a constant.
Copy the printout to a .txt file with a font 8 size and both
the start and solution will print on 1 A4 sheet.
Download sudokuram.pde from:
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
