Topic: Small Arduino "Webserver" -> blinkm rgb (Read 7695 times) previous topic - next topic
b00lean
Hello!
I made a simple application for the ethernet shield to control a blinkm RGB LED. It has a small form on a webpage to change the colors as you wish.
I used several libraries as you can see in my code..
Hope you like it ;)
Code: [Select]
// Small Arduino Webserver
// by Andreas Cahen
// Used libraries and examples:
// Arduino Ethershield, server.pde
// TextString Library, WString.h
// Blinkm Library, BlinkMfuncs.h
#include <Ethernet.h>
#include <WString.h>
#include <Wire.h>
#include <BlinkM_funcs.h>
#define maxLength 25
#define blinkm_addr 0x00
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 177 };
String inString = String(maxLength);
int val;
int r;
int g;
int b;
Server server(80);
 Ethernet.begin(mac, ip);
 server.begin();
 BlinkM_beginWithPower();
 BlinkM_stopScript( blinkm_addr );
 Client client = server.available();
 if (client) {
   boolean current_line_is_blank = true;
   while (client.connected()) {
     if (client.available()) {
       char c = client.read();
       if (inString.length() < maxLength) {
         inString.append(c);
       if (c == '\n' && current_line_is_blank) {
         if (inString.contains("?")) {
          int Pos_r = inString.indexOf("r");
          int Pos_g = inString.indexOf("g");
          int Pos_b = inString.indexOf("b");
          int End = inString.indexOf("H");
          r = atoi(inString.substring((Pos_r+2), (Pos_g-1)));
          g = atoi(inString.substring((Pos_g+2), (Pos_b-1)));
          b = atoi(inString.substring((Pos_b+2), (End-1)));
          BlinkM_fadeToRGB( blinkm_addr, r, g, b );
         client.println("Content-Type: text/html");
         client.println();
         client.println("<html><head></head><body>");
         client.println("<h1>blinkm & ethershield colorpicker</h1>");
         client.println("<form method=get>R:<input type=text size=3 name=r>G:<input type=text size=3 name=g>B:<input type=text size=3 name=b>&nbsp;<input type=submit value=submit></form></body></html>");
       if (c == '\n') {
       } else if (c != '\r') {
         current_line_is_blank = false;
   delay(1);
   inString = "";
   client.stop();
Here some pictures...
http://www.flickr.com/photos/boolean/3399886646/
http://www.flickr.com/photos/boolean/3399075841/
Cheers,
Andreas
boomy
This is great!
I've learned to use the ethernet en webpage modules from your code.
Thank you so much!
Now I'm going to find out if I can build something like:
http://www.youtube.com/watch?v=1F7CF7cQJho
(Controlling the light via a graphical hue interface via a browser)
PsycleSam
updated for Arduino 0021. Thanks for the original code Andreas!
Code: [Select]
// Small Arduino Webserver --- for BlinkM
// by Andreas Cahen ---** updated for Arduino 0021 - by PsycleSam and Co. 20101219 tested on arduino uno with updated ethernet shield
// Blinkm Library, BlinkMfuncs.h +++**SPI Library, SPI.h
// ---** no longer used - TextString Library, WString.h
#include <SPI.h>
//#include <WString.h>
#include <Wire.h>
#define blinkm_addr 0x09
byte mac[] = {
 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; //update with your MAC and IP
byte ip[] = {
 192, 168, 0, 200 };
int val;
int r = 0;
int g = 0;
int b = 0;
char colorBuff[4];
Server server(80);
 //Serial.begin(9600);
 server.begin();
 int bufLength;
 if (client) {
         //inString.append(c);
         inString += c;
         if (inString.indexOf("?") > -1) {
           int Pos_g = inString.indexOf("g", Pos_r);
           int Pos_b = inString.indexOf("b", Pos_g);
           int End = inString.indexOf("H", Pos_b);
           if(End < 0){
             End =  inString.length() + 1;
           bufLength = ((Pos_g) - (Pos_r+2));
           if(bufLength > 4){  //dont overflow the buffer
             bufLength = 4;
           inString.substring((Pos_r+2), (Pos_g-1)).toCharArray(colorBuff, bufLength);  //transfer substring to buffer
           r = atoi(colorBuff);
           bufLength = ((Pos_b) - (Pos_g+2));
             bufLength = 4;
           inString.substring((Pos_g+2), (Pos_b-1)).toCharArray(colorBuff, bufLength);  //transfer substring to buffer
           g = atoi(colorBuff);
           bufLength = ((End) - (Pos_b+2));
             bufLength = 4;
           inString.substring((Pos_b+2), (End-1)).toCharArray(colorBuff, bufLength);  //transfer substring to buffer
           b = atoi(colorBuff);
           // Serial.print("Red = ");
           // Serial.println( r );
           // Serial.print("Grn = ");
           // Serial.println( g );
           // Serial.print("Blu = ");
           // Serial.println( b );
         client.println();
         client.println("<h1>BlinkM - enter values 0 to 255</h1>");
         client.print("<form method=get>R:<input type=text size=3 name=r value=");
         client.print(r);
         client.print(">G:<input type=text size=3 name=g value=");
         client.print(g);
         client.print(">B:<input type=text size=3 name=b value=");
         client.print(b);
         client.println(">&nbsp;<input name=H type=submit value=submit></form>");
         client.println("</body></html>");
       if (c == '\n') {
   delay(1);
   inString = "";
   client.stop();
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
