Topic: Arduino as a Pic Programmer! (Read 165688 times) previous topic - next topic
Soranne
Feb 20, 2012, 07:12 pm Last Edit: May 06, 2012, 06:38 pm by Soranne Reason: 1
Hi everyone!
Here is my first version of my PIC programmer : program your PIC from USB! Cheap and easy!
Feel free to do what you want with this project, modify it, upgrade it publish it,... but just tell me what you've done so that I can share it with everybody ;)
It works with PIC 16F628 but should work with most pic16F; if you can try at home leave a message so that I can list the working PICs here!
Here is the circuit you need to make :
You can change the resistor value between 330 and more.
Always RESET Arduino before putting 12V (I don't know if we need to, but that's just a safe practice)
And here is the code :
PIC programmer using Arduino
This program is distibuted "AS IS", I offer no garantee.
By Ronan Gaillard
#define  CLOCK  9
#define  DATA   8
#define  VPP1   6
#define  VPP2   5
#define  VPP3   4
#define  PGM    10 //HIGH/LOW voltage select mode
#define  MCLR   11 //LOW voltage only
 pinMode(CLOCK, OUTPUT);
 pinMode(VPP1, OUTPUT);
 pinMode(VPP2, OUTPUT);
 pinMode(VPP3, OUTPUT);
 pinMode(DATA, OUTPUT);
 pinMode(PGM, OUTPUT);
 Serial.println("Started");
//Serial.println("Send s to start (please put Vpp first)");
while(true)
  if (Serial.available() > 0)
   if(Serial.read()=='s')//HIGH VOLTAGE MODE
   //VIN should be around 12V max. is 13.5V
  digitalWrite(VPP1, HIGH);
  digitalWrite(VPP2, HIGH);
  digitalWrite(VPP3, HIGH);
    Serial.print("D");
   break;
  else//low voltage mode
 digitalWrite(PGM, LOW);
 digitalWrite(VPP1, LOW);
  digitalWrite(VPP2, LOW);
   digitalWrite(MCLR, LOW);
  digitalWrite(VPP3, LOW);
  delayMicroseconds(20);
  delayMicroseconds(3);
  digitalWrite(PGM, HIGH);
    digitalWrite(MCLR, HIGH);
    Serial.print("D");
   break;
 char command = '\0';
  if (Serial.available() > 0) {
    command = Serial.read();
    switch(command)
    case 'b' :
     BulkEraseProgramMemory();
      Serial.print('D');
    break;
    case 'E' :
      EndOfProgramming();
      Serial.print('D');
      break;
    case 'r' :
      char valeur[16];
      ReadDataFromProgramMemory(valeur);
      for(int i=0; i<14;i++)
       Serial.print(valeur[i]);
      //Serial.print("D");
    break;
    case 'l' :
      char WritingValue[14];
      for(int i=0;i<14;i++)
       while(Serial.available() == 0)
       WritingValue[i] = Serial.read();
      LoadDataCommandForProgramMemory(WritingValue);
      Serial.print('D');
      break;
    case 'w' :
      BeginProgrammingOnlyCycle();
      Serial.print('D');
    break;
    case 'W' :
      BeginEraseProgrammingCycle();
      Serial.print('D');
    break;
    case 'i' :
      IncrementAddress();
      Serial.print('D');
      break;
    case 'c' :
      char ConfigValue[14];
       ConfigValue[i] = Serial.read();
      LoadConfiguration(ConfigValue);
      Serial.print('D');
      break;
    case 'R' :
      delay(3);
      Serial.print("D");
    break;
void WriteBit(char nb)
 digitalWrite(CLOCK, HIGH);
 if(nb!='0')
   digitalWrite(DATA,HIGH);
 digitalWrite(CLOCK, LOW);
   digitalWrite(DATA,LOW);
byte ReadBit()
 byte valeur = 0;
 if(digitalRead(DATA)==HIGH)
  valeur = '1';
   valeur = '0';
 return valeur;
void ReadDataFromProgramMemory(char valeur[])
 //Command
 WriteBit('0');
 WriteBit('0');
 WriteBit('1');
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 pinMode(DATA, INPUT);
 //DATA
 ReadBit();
 for(int i =13;i>=0;i--)
   valeur[i] = ReadBit();
 ReadBit();
void LoadDataCommandForProgramMemory(char valeur[])
 //Command
 WriteBit('0');
 WriteBit('1');
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 //DATA
 WriteBit('0');//always 0
   WriteBit(valeur[i]);
 WriteBit('0');//always 0 (stop bit)
void BeginProgrammingOnlyCycle()
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 WriteBit('1');
 WriteBit('1');
 WriteBit('0');
 delay(20);
void BeginEraseProgrammingCycle()
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 WriteBit('1');
 WriteBit('0');
 WriteBit('0');
 delay(20);
void BulkEraseProgramMemory()
 WriteBit('1');
 WriteBit('0');
 WriteBit('0');
 WriteBit('1');
 WriteBit('0');
 WriteBit('0');
 delay(20);
void FullEraseProgramMemory()
 char Erase [] = {'1','1','1','1','1','1','1','1','1','1','1','1','1','1'};
 LoadDataCommandForProgramMemory(Erase);
void IncrementAddress()
 WriteBit('0');
 WriteBit('1');
 WriteBit('1');
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
void LoadDataCommandForDataMemory(char valeur[])
 //Command
 WriteBit('1');
 WriteBit('1');
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 //DATA
void LoadConfiguration(char valeur[])
 //Command
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 WriteBit('0');
 //DATA
void EndOfProgramming()
 //Command
 WriteBit('1');
 WriteBit('1');
 WriteBit('1');
 WriteBit('0');
 WriteBit('1');
 WriteBit('0');
To program use your COM port, here are the commands :
Just after RESET send s to start with HVP (High Voltage Programming) or S to start with Low Voltage Programming
wXXXXXXXXXXXXXX : writes word to location pointed by PC (program counter)
i : increases PC
r : read current location
e : erase full program memory
R : resets the PIC (PC to 0)
Every command returns character D if success
To Do :
- This only reads and writes to program memory on PIC, improve it to access DATA memory(=EEPROM)
- Support more PICs
Supported PICs : (Your PIC is not listed here? Don't hesitate to post a comment here so that I can add it!)
Most 16F pics should be supported
Don't hesitate to tell me if it works with other PICs.
Latest updates :
03/03/2012 : updated C# prog + arduino code
24/02/2012 : uploaded new Software that writes to Prog memory and loads the Configuration Word, and uploaded the Arduino Firmware, which supports LVP (Low Voltage Programming) by sending 'S' just after RESET.
22/02/2012 : updated the C# code : you can now burn HEX file to PIC! (only program memory supported, not EEPROM and Config word)
21/02/2012 : added the reset command, and started to program a C# program to send HEX to PIC
Here is a 18f programmer : https://sites.google.com/site/thehighspark/arduino-pic18f Special thanks to kirill578!
Enjoy,
Soranne
My projects :
- Interfacing with Minitel : http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1271350467
- Arduino PIC programmer : http://ardu
Soranne
#1
Feb 21, 2012, 07:14 pm Last Edit: Mar 03, 2012, 06:31 pm by Soranne Reason: 1
Here is the start of the C# prog used to control the Arduino PIC programmer, not finished at all, just a start ;) (updated on 24/02/2012)
You need to :
- reset Arduino before starting the prog/reading/writing
- don't forget the 12V
- .NET Run Time 4.0 (should already be on your PC if you use Windows)
See end of post for download
As this is just a prototype I encourage you to check your PIC memory with your normal programmer.
My projects :
Techone
That is an interesting project. I will figured out this project, doing experiments amd try it.
Thank Soranne. Merci  <-- In english in this section.   :D
NI$HANT
HI Sorraine such a nice project i have different types of pic's a few putting up with me lying around without a JDM programmer usage as my desktop us ruined it cant be used on laptop so i can check with those pic's.
i just wanted that can you provide intallable exe file of your c# programme which is used to programme pic's (i dnt have visual c# IDE installed and configured)
"Real Men can Accomplish  Anything"
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Soranne
Thank you for your comment :) Merci!
Hi NI$HANT,
Thank you for your comment too!
For the moment I'm not providing the *.exe because the program doesn't burn the hex file yet :s . As soon as I have improve the program I will post the *.exe here ;)
This afternoon (it's now 09:06 in France ;) ) I will certainly have a good c# program running so I will post the exe here !
My projects :
NI$HANT
Thanks a lot SOrraine, Im waiting for it impatiently.do not want to struggle for with parallel programmers and serial programmers any more.
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Soranne
I uploaded the C# prog to the second post. See indication on second post ;)
Enjoy!
My projects :
NI$HANT
I'm the First to Download it, but im sure not the last!  :D
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Soranne
#8
Feb 23, 2012, 08:44 am Last Edit: Feb 23, 2012, 07:18 pm by Soranne Reason: 1
Thanks! :) I just noticed there may be a problem : the software might writeMSB (Most Significant Byte) first whereas it should write LSB (Least Significant Byte) first. I'll check this afternoon!
Have a nice day!
EDIT : i fixed everything, I also added configuration word support. But I have an internet problem so I can't upload my code and .exe yet :s
My projects :
NI$HANT
@ Soranne, Hi thanks for prompt update, I'm eagerly waiting for the latest .exe file and code, please prompt ASAP.
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Soranne
#10
Feb 24, 2012, 05:20 pm Last Edit: Feb 24, 2012, 06:19 pm by Soranne Reason: 1
Working on LVP (Low Volatage Mode = no need for 12V) and release the code in less than one hour!
PS : just received my 16F876A, so I'm gonna try! ;)
EDIT : ARRRRRHHHHH having problemes with LVP :s Doesn't work, actually 16F876 don't work like 16F628, that's a bit more complicated than ithought. Anybody who want to help is welcome!
My projects :
NI$HANT
I think Sorrance giving external 12v to programme should not be that much of a headache for us Arduino Dude's  :D for us the fact that arduino is being able to route the binary into the chip is enough and also these Stubborn PIC's would not that easily let one access them in low voltage mode ,However some would but not all.
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Soranne
Yeah that was just a test, too much trouble yet, I'll try it later.
I just posted the software and new Arduino code up there :)
My projects :
NI$HANT
I just downloaded the latest code from the second post and want to know that whether you want to give me some instructions on using it.
- skype : nishants5
ਫ਼ਤੇਹ ਕਰੁਂ!
www.winacro.com
Soranne
Just follow what the program says and put your hex file in C:/mem.hex
And before starting the prog reset the Arduino, it should work ;)
My projects :
