UPDATE: I finally got it to work, but not the way it is supposed to. If I put the definition in hardware\breadboard\boards.txt in my sketch folder it doesn't work.
If I edit the following into the arduino distribution's boards.txt it works:
atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
atmega328bb.upload.protocol=arduino
atmega328bb.upload.maximum_size=30720
atmega328bb.upload.speed=57600
atmega328bb.bootloader.low_fuses=0xE2
atmega328bb.bootloader.high_fuses=0xDA
atmega328bb.bootloader.extended_fuses=0x05
atmega328bb.bootloader.path=arduino:atmega
atmega328bb.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
atmega328bb.bootloader.unlock_bits=0x3F
atmega328bb.bootloader.lock_bits=0x0F
atmega328bb.build.mcu=atmega328p
atmega328bb.build.f_cpu=8000000L
atmega328bb.build.core=arduino
atmega328bb.build.variant=standard
The changes are upload.protocol = arduino, and build.variant=standard
Should I file a bug?
...original post....
This may be faq, but I can't find it.
The breadboard example:
http://arduino.cc/en/Tutorial/ArduinoToBreadboardworks fine in Arduino 022, but I get this error on 1.0:
In file included from BlinkWithoutDelay.cpp:26:
C:\Users\Kevin\Desktop\hacking\arduino-1.0\hardware\arduino\cores\arduino/Arduino.h:212:26: error: pins_arduino.h: No such file or directory
I saw one posting that said to add build.variant=standard, but it didn't help.
