Topic: arduino mini & analong pins 6 & 7 (Read 1 time) previous topic - next topic
Hello,
I can't seem to get the 7h and 8th analog channels to work.  1-6 are great.  any suggestions??
Thanks,
Willie
mellis
Which version of the Arduino software are you using?  Support for the last two analog inputs was only added in Arduino 0006.  Also, the channels are numbered 0 to 7, not 1 to 8.
Hello,
Thanks for the reply.  I'm using 0007.  And yes, I'm trying to access inputs 6 & 7 of 0-7.  Here's the code I wrote to create smoothed midi continuous controls from the 8 analog ins.  Analog 0-5 work beautifully.  Any ideas?
Thanks,
Willie
Code: [Select]
// Variables:
int LED = 13;
int ANA_AVG_old[8] = {0, 0, 0, 0, 0, 0, 0, 0};
int ANA_AVG_new[8] = {0, 0, 0, 0, 0, 0, 0, 0};
// Functions:
//  compile midi message
void ConC(char cmd, char data1, char data2) {
Serial.print(cmd, BYTE);
Serial.print(data1, BYTE);
Serial.print(data2, BYTE);
//  Set MIDI baud rate:
Serial.begin(31250);
//Read Analog pins, make a running average, if diff then send values
int i;
  for (i = 0; i < 8; i++) {
    ANA_AVG_new[i] = (ANA_AVG_old[i] + analogRead(i)) /2;
          if (ANA_AVG_new[i] != ANA_AVG_old[i]) { //if diff do stuff
            ConC(176, i, ANA_AVG_new[i]/8);
            analogWrite(LED, 128);
            delay(10);
            ANA_AVG_old[i] = ANA_AVG_new[i];
          } else { //else if same do less stuff
            analogWrite(LED, 0);
}  //END VOID LOOP
mellis
What do you mean by not working correctly?  What values do you get?  How did you physically connect to the analog inputs?
#4
Jan 15, 2007, 09:20 pm Last Edit: Jan 15, 2007, 09:21 pm by wfastenow Reason: 1
I'm getting no values at all on the last two.  Physically, I have all 8 inputs connected identically. I'm using a potentiometer to send midi continuous control values from 0-127.  Inputs 0-5 work flawlessly.  But I get absolutely nothing out of 6 & 7.  Is there something different about these last two inputs?  Do they need to be addressed differently? Do they need to be somehow declared/prepped in the void setup()?  I've tried multiple minis in different capacities and have not been able to get anything from inputs 6 & 7 in botth Arduino 0006 and 0007.
CosineKitty
Which processor are you using?  On the ATmega8, there are only 6 analog input pins: 0..5.
thanks for the post.  i'm using the atmega168 with (supposedly) 8 analog ins.
is there anybody who is using the last two analog ins?  it seems like there is something inherently different about AD6 and AD7 based off of my and my associates' trials.  the issue is really perplexing us, as 0-5 work swiftly, and there is nothing shown coming in to 6-7.
best,
willie
#7
Jan 17, 2007, 06:52 am Last Edit: Jan 17, 2007, 06:53 am by wfastenow Reason: 1
replace the pins_arduino.c file with the following code
path is
arduino-0007/lib/targets/arduino/
and pins 6 &7 will work!
Thanks to all who helped.
Best,
Willie
Code: [Select]
 pins_arduino.c - pin definitions for the Arduino board
 Part of Arduino / Wiring Lite
 Copyright (c) 2005 David A. Mellis
 This library is free software; you can redistribute it and/or
 modify it under the terms of the GNU Lesser General Public
 License as published by the Free Software Foundation; either
 version 2.1 of the License, or (at your option) any later version.
 This library is distributed in the hope that it will be useful,
 but WITHOUT ANY WARRANTY; without even the implied warranty of
 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
 Lesser General Public License for more details.
 You should have received a copy of the GNU Lesser General
 Public License along with this library; if not, write to the
 Free Software Foundation, Inc., 59 Temple Place, Suite 330,
 Boston, MA  02111-1307  USA
 $Id: pins_arduino.c 191 2006-10-15 11:45:26Z mellis $
#include <avr/io.h>
#include "wiring.h"
// On the Arduino board, digital pins are also used
// for the analog output (software PWM).  Analog input
// pins are a separate set.
// ATMEL ATMEGA8 / ARDUINO
//       PC6  1|    |28  PC5 (AI 5)
// (D 0) PD0  2|    |27  PC4 (AI 4)
// (D 1) PD1  3|    |26  PC3 (AI 3)
// (D 2) PD2  4|    |25  PC2 (AI 2)
// (D 3) PD3  5|    |24  PC1 (AI 1)
// (D 4) PD4  6|    |23  PC0 (AI 0)
//       VCC  7|    |22  GND
//       GND  8|    |21  AREF
//       PB6  9|    |20  AVCC
//       PB7 10|    |19  PB5 (D 13)
// (D 5) PD5 11|    |18  PB4 (D 12)
// (D 6) PD6 12|    |17  PB3 (D 11) PWM
// (D 7) PD7 13|    |16  PB2 (D 10) PWM
// (D 8) PB0 14|    |15  PB1 (D 9) PWM
#define NUM_DIGITAL_PINS 14
#define NUM_ANALOG_OUT_PINS 11
#define NUM_ANALOG_IN_PINS 8
#define NUM_PORTS 4
#define PB 2
#define PC 3
#define PD 4
// these arrays map port names (e.g. port B) to the
// appropriate addresses for various functions (e.g. reading
// and writing)
int port_to_mode[NUM_PORTS + 1] = {
     NOT_A_PORT,
     NOT_A_PORT,
     _SFR_IO_ADDR(DDRB),
     _SFR_IO_ADDR(DDRC),
     _SFR_IO_ADDR(DDRD),
int port_to_output[NUM_PORTS + 1] = {
     NOT_A_PORT,
     NOT_A_PORT,
     _SFR_IO_ADDR(PORTB),
     _SFR_IO_ADDR(PORTC),
     _SFR_IO_ADDR(PORTD),
int port_to_input[NUM_PORTS + 1] = {
     NOT_A_PORT,
     NOT_A_PORT,
     _SFR_IO_ADDR(PINB),
     _SFR_IO_ADDR(PINC),
     _SFR_IO_ADDR(PIND),
// these arrays map the pin numbers on the arduino
// board to the atmega8 port and pin numbers
pin_t digital_pin_to_port_array[NUM_DIGITAL_PINS] = {
     { PD, 0 },
     { PD, 1 },
     { PD, 2 },
     { PD, 3 },
     { PD, 4 },
     { PD, 5 },
     { PD, 6 },
     { PD, 7 },
     { PB, 0 },
     { PB, 1 },
     { PB, 2 },
     { PB, 3 },
     { PB, 4 },
     { PB, 5 },
pin_t *digital_pin_to_port = digital_pin_to_port_array;
int analog_out_pin_to_timer_array[NUM_DIGITAL_PINS] = {
     NOT_ON_TIMER,
     NOT_ON_TIMER,
     NOT_ON_TIMER,
     // on the ATmega168, digital pin 3 has hardware pwm
#if defined(__AVR_ATmega168__)
     TIMER2B,
#else
     NOT_ON_TIMER,
#endif
     NOT_ON_TIMER,
     // on the ATmega168, digital pins 5 and 6 have hardware pwm
     TIMER0B,
     TIMER0A,
#else
     NOT_ON_TIMER,
     NOT_ON_TIMER,
#endif
     NOT_ON_TIMER,
     NOT_ON_TIMER,
     TIMER1A,
     TIMER1B,
     TIMER2A,
#else
     TIMER2,
#endif
     NOT_ON_TIMER,
     NOT_ON_TIMER,
int *analog_out_pin_to_timer = analog_out_pin_to_timer_array;
// Some of the digital pins also support hardware PWM (analog output).
pin_t analog_out_pin_to_port_array[NUM_DIGITAL_PINS] = {
     { NOT_A_PIN, NOT_A_PIN },
     { PB, 1 },
     { PB, 2 },
     { PB, 3 },
pin_t *analog_out_pin_to_port = analog_out_pin_to_port_array;
pin_t analog_in_pin_to_port_array[NUM_ANALOG_IN_PINS] = {
     { PC, 0 },
     { PC, 1 },
     { PC, 2 },
     { PC, 3 },
     { PC, 4 },
     { PC, 5 },
     { PC, 6 },
     { PC, 7 },
 { NOT_A_PIN, 6 },
 { NOT_A_PIN, 7 },
#endif
pin_t *analog_in_pin_to_port = analog_in_pin_to_port_array;
mellis
#8
Jan 17, 2007, 09:08 am Last Edit: Jan 17, 2007, 09:17 am by mellis Reason: 1
Whoops.  That's what I get for not soldering some wires to my Mini and testing my code!  I'll fix this in Arduino 0008.
You just changed this line, right?
Code: [Select]
yep! that's the one.  also, make sure the end of the file looks like the below  (that { PC, 6 }, and { PC, 7 }, are included, etc.
best,
willie
Code: [Select]
     { PC, 0 },
     { PC, 1 },
     { PC, 2 },
     { PC, 3 },
     { PC, 4 },
     { PC, 5 },
     { PC, 6 },
     { PC, 7 },
 { NOT_A_PIN, 6 },
 { NOT_A_PIN, 7 },
#endif
mellis
Are you sure it doesn't work if you remove these two lines?
Code: [Select]
     { PC, 6 },
     { PC, 7 },
actually, no, i didn't check it out with those lines removed...  maybe it does.  i'll test it out tonight.
willie, you rock.
I have a question. Have you successfully managed to get the extra pins to work with Max/MSP yet?
(because I haven't...  :( )
-Scott
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
