Loading...
Pages: [1]   Go Down
Author Topic: xBee.h doesn't compile with leonardo - Serial problem  (Read 767 times)
New Jersey
Offline Offline
Sr. Member
View Profile
I am trying to use xbee.h (http://code.google.com/p/xbee-arduino/) with the new Leonardo.  I get this error when I verify the sketch:
769: error: cannot convert 'Serial_*' to 'HardwareSerial*' in assignment
I assume it has something to do with the Leonardo not using serial by default and you have to use Serial1 or something, but I don't know what code to change to fix this.  Can anyone help?
--Scott
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
Replace line 769 of XBee.cpp
Code:
_serial = &Serial;
with
Code:
_serial = &Serial1;
Logged
New Jersey
Offline Offline
Sr. Member
View Profile
That worked, thanks.   In the \libraries\ folder I created a new directory called \XBee_Leo and copied XBee.h and XBee.cpp in there and renamed them to XBeeLeo.h and XBeeLeo.cpp.  In the XBeeLeo.cpp I made the serial1 change and changed #include XBee.h to #include XBeeLeo.h.  In my sketch I just changed the include from <XBee.h> to <XbeeLeo.h> and all is good.
It would be nice if one library could compile both Leonardo boards and non-Leonardo boards. I tried some stuff with #ifdef, but it didn't work.  Here's what I tried:
First I changed added a #define to my sketch:
Code:
#define LEONARDO
#include <XBee.h>
In XBee.cpp, I changed
Code:
_serial = &Serial;
to
Code:
#ifdef LEONARDO
   _serial = &Serial1;
#else
   _serial = &Serial;
#endif
But this didn't work.
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
This does not work because the defines and includes are rearranged before fed to the compiler.
But you can change your library this way and you don't have to do anything special. If you choose the Leonardo as the board type automatically the correct code is generated.
Code:
#ifdef defined(USBCON)
   _serial = &Serial1;
#else
   _serial = &Serial;
#endif
Logged
New Jersey
Offline Offline
Sr. Member
View Profile
I made the change and made sure I closed then re-opened the Arduino IDE, but my sketch didn't compile when I selected the Leonardo board.  I got this error:
/Volumes/srg/Arduino Sketches/libraries/XBee/XBee.cpp: In constructor 'XBee::XBee()':
/Volumes/srg/Arduino Sketches/libraries/XBee/XBee.cpp:774: error: cannot convert 'Serial_*' to 'HardwareSerial*' in assignment
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
Sorry, my fault, had a copy/paste error in my posted code. Should be an #if and not an #ifdef:
Code:
#if defined(USBCON)
   _serial = &Serial1;
#else
   _serial = &Serial;
#endif
Logged
New Jersey
Offline Offline
Sr. Member
View Profile
That worked, thanks!
Logged
Offline Offline
Newbie
View Profile
I am having the same problem with the MICRO; I tried the fix described here but it does not work.
I am putting the
Code:
#if defined(USBCON)
   _serial = &Serial1;
#else
   _serial = &Serial;
#endif
at the beginning of the xbee.cpp file
is there something else I should do???
Bill
Logged
Switzerland
Offline Offline
Faraday Member
View Profile
You have to replace the line
Code:
_serial = &Serial;
with the code you posted. If you just add the code at the beginning it has absolutely no effect.
Logged
Pages: [1]   Go Up
Print
Jump to:
