Loading...
Pages: [1]   Go Down
Author Topic: Print minimum number of digits  (Read 231 times)
USA
Offline Offline
Full Member
View Profile
What is the best way to "print" (Serial.print) an integer with a specified minimum number of digits (ex. printf("%03d", 1) -> 001)?
Logged
Seattle, WA USA
Offline Offline
Brattain Member
Seattle, WA USA
View Profile
Quote
Use sprintf() to print to a buffer, then Serial.print() the buffer. It's really the only way. That makes it the best way automatically.
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
if it's less than 1000, print a zero
if it's less than 100, print a zero
if it's less than 10, print a zero
print the number
but that's better done in a loop that starts with 1000 and divides by 10 until less than 10.
I've worked it to make fixed-point integers print fast.
Logged
Examples can be found at Learning in the Main Site and at the Playground
USA
Offline Offline
Full Member
View Profile
I thought about that but I didn't thing that would be the preferred way because printf and friends (sprintf, fprintf, vsprintf, etc...) tend to use a lot of program (FLASH) space.
Logged
0
Offline Offline
Faraday Member
20 LEDs are enough
View Profile
WWW
Quote
I would disagree here. The loop approach is harder to implement and will consume a lot more memory because the Arduino lacks hardware division. The approach with the if statements is much simpler and compiles to less instructions.
Even in case of variable digits I would stick with the if statements like so:
Code:
switch (digits) {
    case 5: { if (n<10000) { print('0'); }}
    case 4: { if (n<1000)  { print('0'); }}
    case 3: { if (n<100)   { print('0'); }}
    case 2: { if (n<10)    { print('0'); }}
print(n);
« Last Edit: August 01, 2012, 04:41:54 pm by Udo Klein » Logged
Check out my experiments http://blog.blinkenlight.net
Pages: [1]   Go Up
Print
Jump to:
