Wirral, UK
Offline
Newbie
« on: September 05, 2012, 03:37:39 am » |
First post! Be gentle!!  I’ve breadboarded a ATMEGA328 and managed to bootload it (using the UNO) but I am having terrible troubles loading any sketches to it. Thinking I’d possibly cocked up the bootloader / chip I jumpered it to the socket on the uno and managed to program it, however this is not ideal as I really want it to be re-programable in situ once its installed. I’ve been using a CP2102 based, usb to serial converter to attempt the programming.. Used the following diagram, http://www.miconbkk.com/shop/m/miconbkk/img-lib/spd_20120411163027_b.jpgIt seems to reset, but immediately goes back into the ‘blink’ program that I programmed using the uno, and I get the error; avrdude: stk500_getsync(): not in sync: resp=0x00. Any ideas chaps!? I’ve already checked the CP2102 is working (looped the TX>RX) and the DTR seems ok as its reseting. Is there any particular setting the IDE needs to be set to use the CP2102 > Serial (apart from setting the correct usb port!)  Many thanks in advance! Matt
Logged
Got there in the end!
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #1 on: September 05, 2012, 03:41:45 am » |
... I jumpered it to the socket on the uno and managed to program it ... OK, I'll be gentle, and welcome to the forum! What is this "it" of which you speak?
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #2 on: September 05, 2012, 03:42:49 am » |
Logged
Wirral, UK
Offline
Newbie
« Reply #3 on: September 05, 2012, 03:44:12 am » |
... I jumpered it to the socket on the uno and managed to program it ... OK, I'll be gentle, and welcome to the forum! What is this "it" of which you speak? sorry managed to program the ATM328P.
Logged
Wirral, UK
Offline
Newbie
« Reply #4 on: September 05, 2012, 03:14:58 pm » |
Checked out suggested page and looks like i am doing everything right, I am thinking could be the USB > Serial converter (the same error presents itself when I remove the TX/RX lines). Anyone else have any experiance with the CP2102 chipset adaptors with the arduino IDE??  Any help would be appreciated... Regards Matt
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #5 on: September 05, 2012, 03:57:52 pm » |
Where is that orange wire on the right going? The one connected to pin 2 of the chip.
Logged
Wirral, UK
Offline
Newbie
« Reply #6 on: September 05, 2012, 04:16:03 pm » |
Sorry its not very clear is it! Plus the colours dont match at the CP2102 end!!
Orange (pin2) > TXD on CP2102 Yellow (pin3) > RXD on CP2102
Regards
Matt
Logged
Global Moderator
Offline
Shannon Member
Lua rocks!
« Reply #7 on: September 05, 2012, 08:21:42 pm » |
Is that capacitor in series with reset really 0.1 uF?
Logged
Wirral, UK
Offline
Newbie
« Reply #8 on: September 06, 2012, 02:45:15 am » |
Yes, already swapped it out with another just to make sure it too!
Logged
Wirral, UK
Offline
Newbie
« Reply #9 on: September 07, 2012, 08:07:21 pm » |
I rebuilt it following carefully http://shrimping.it/blog/shrimp/shrimpduino_bb_minimal/ and seem to have made some progress, managed to program it a few times! Programmed the blink sketch and noticed that the LED was flashing in a very non-uniform manner. Could the crystal be a bit duff??
Logged
Offline
Newbie
« Reply #10 on: September 08, 2012, 11:50:36 am » |
@bromatt..
No, I would assume that the wire is not connected properly.. try change it and tell us if you still have the same problem...
Logged
Austin, TX
Offline
Faraday Member
CMiYC
« Reply #11 on: September 08, 2012, 01:40:32 pm » |
Anyone else have any experiance with the CP2102 chipset adaptors with the arduino IDE?? Yes, lots of people have problems getting it to work out. Most of those adapters have a pin called "RESET" which has nothing to do with resetting the Arduino. You have to find a via on the breakout board that is connected to the DTR pin of the CP2102 and carefully solder a wire to it. Or, manually reset your arduino when programming.
Logged
Morecambe, UK
Offline
Newbie
Laptop Shrimping and Free public Arduino workshops in Morecambe, UK
« Reply #12 on: September 11, 2012, 06:56:27 am » |
@bromatt I recently experienced a blown/broken crystal, which didn't behave as you describe - the circuit simply didn't function. However, I don't know if there's any weird behaviour before one fails completely. Without seeing the circuit in action, it sounds like it might be resetting for some reason, such as a temporary load which affects the voltage. If I'm right, the variation in blinking is therefore to do with it restarting the whole program again. I've seen this happen in unprotected circuits controlling motors, and it may reveal latent issues with having some contacts which are not conducting well for some reason (perhaps corrosion in the breadboard connections). Protection from variations in load is one primary reason, as well as stable analog reference voltages, for the differences between the minimal programmable circuit at... http://shrimping.it/blog/shrimp/shrimpduino_bb_minimal/...and the more practical, protected circuit at... http://shrimping.it/blog/shrimp/shrimpduino_bb/...which is recommended for any substantial physical computing work. Try the more protected circuit instead, and be sure everything is cleanly contacting.
Logged
Anaheim CA.
Offline
Edison Member
Experienced old Whitebeard with a Full head of Hair...
« Reply #13 on: September 11, 2012, 10:17:23 am » |
Sort of Apropos the subject, Is there any real difference between the FTDI232, CP2102 and the PL2303 USB to TTL Adapters. I'd not given the subject much thought until this thread but for some reason (I own all) this question 'popped' up and I was wondering what if any difference there was practically and particularly. I will be doing a small pcb and I own a couple of the FTDI chips in a 'usable' (SSOP) package so my thought was that If there is a good reason to avoid any of the devices in particular... Which?. Jumpers are ok for this job as it is a picture frame with a 328 and a 3.2" Itead display and the pictures can be loaded onto the SD card and simply be 'plugged' in. If there is an advantage beyond immediate possession of the FTDI device I will include it on the board, If not then I will place a connector footprint rather than an IC footprint.
Doc
Logged
“The solution of every problem is another problem.” -Johann Wolfgang von Goethe
Wirral, UK
Offline
Newbie
« Reply #14 on: September 14, 2012, 03:22:46 am » |
Hi Guys, Sorry for not keeping upto-date life does get in the way sometimes! The original breadboarded layout I have pulled apart as I was practising getting 2x TLC5940 daisy-chained, I did notice some weird behaviour out of the breadboard (flickering led's) so I suspect that it might not be upto scratch so that is definitely one avenue - I'm going to give the 'shrimped' (am I using the correct terminology) another go, but this time going to build it on strip-board / matrix board - in t-he meantime however I purchased a RBBB Arduino http://shop.moderndevice.com/products/rbbb-kit from ebay - and put it together, works perfectly BUT still the CP2102 module refuses to play ball, but programs perfectly using RX/RT/RESET BLAH BLAH jumpered from a chipless Uno. Doc: Differences, FTDI232 - is the one that's used on the Uno itself! Works!! (at least from the uno) CP2102 - the one I have - very cheap! Works?? People say it does, I have faith!! PL2303 - Pass! Never seen one. There all USB > Serial Bridges - electronically they shouldn't make a jot of difference, i think the trade off is support/price/reliability..Given the choice again, i would go for the FTDI232!  Matt
Logged
