Pages: [1] 2   Go Down
Author Topic: Weather LCD display via XML  (Read 1211 times)
Good day,
I'm starting a project on displaying the weather of the area i'm in (i.e. Sydney) on a LCD via an arduino uno with ethernet shield.
first, how do you get the xml code? i've seen some examples that links to google weather but the google weather link is not working?
appreciate it if someone could teach me how to get the xml code?
An example or sample code would be helpful too!
cheers!
CH
Book Writer "Arduino Praxiseinstieg"
You can use the Yahoo Weather API. I implemented a project in my book.
See my blog post regarding the stop of Google Weather
http://arduino-praxis.ch/2012/08/google-stoppt-weather-api/
I will post the code soon.
Thanks for the info mate. Looking forward to have a look at your code.
cheers!
Good day Webmeister,
Would you be kind to provide a sample code for the implementation of weather using yahoo's api?
Also if there's anyone that could help, i will appreciate it heaps!
Cheers!
CH
To read the XML from Yahoo Weather API you can use the TextFinder library.
Before you read the weather data you need to get the ID (woeid) from your city.
Example: Zurich/Switzerland
http://query.yahooapis.com/v1/public/yql?q=select%20*%20from%20geo.places%20where%20text%3D%22Schweiz%20Z%C3%BCrich%22&format=xml
You will find the ID in the field <woeid>
Code to read the Yahoo Weather API
// Read Yahoo Weather API XML
// 03.09.2012
// http://arduino-praxis.ch
#include <SPI.h>
#include <Ethernet.h>
#include <TextFinder.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xAD };
byte ip[] = { 10, 0, 1, 101 };
byte gateway[] = { 10, 0, 1, 1 };
byte subnet[] = { 255, 255, 255, 0 };
// Server Yahoo
IPAddress server(87,248,122,181);
EthernetClient client;
TextFinder  finder( client );
char place[50];
char hum[30];
  // Start Ehternet
  Ethernet.begin(mac, ip);
  // Start Serial Port
  Serial.println("Setup...");
  if (client.connect(server, 80))
    // Call Wetter-API
    // w: ID from your City
    // http://weather.yahooapis.com/forecastrss?w=12893459&u=c
    Serial.println("Connect to Yahoo Weather...");
    client.println("GET /forecastrss?w=12893459&u=c HTTP/1.0");
    client.println("HOST:weather.yahooapis.com\n\n");
    client.println();
    Serial.println("Connected...");
    Serial.println(" connection failed");
  if (client.connected())
    // Humidity
   if ( (finder.getString("<yweather:atmosphere humidity=\"", "\"",hum,4)!=0) )
     Serial.print("Humidity:  ");
     Serial.println(hum);
     Serial.print("No Humidity Data");
    // Place/City
    if ( (finder.getString("<title>Conditions for ", " ",place,50)!=0) )
      Serial.print("City:  ");
      Serial.println(place);
    // Temperature
    if(finder.find("temp=") )
     int temperature = finder.getValue();
     Serial.print("Temp C:  ");
     Serial.println(temperature);
     Serial.print("No Temperature Data");
  // END XML
    Serial.println("Disconnected");
  client.stop();
  client.flush();
  delay(60000);
Thanks for this code, it was super helpful. Does anyone know how to read in the forecasted temperature, not just the current?  I modified the code above to search for "High" or even "Forecast" which seems to appear in the raw RSS feed, but it doesnt return anything.  In fact finder.getvalue() doesn't return anything after the "Current Conditions", to me indicating that somehow the the forecast isn't part of the RSS link in the code above (even thought it appears when you look at the RSS in a browser).  I'm trying to get the forcasted High and Low and the chance of rain as a number (although that doesn't appear in the RSS so I might have to look elsewhere).  Any help would be immensely appreciated.
CH
@dbutt
Please show us your modified code.
To find data in the xml stream you can also use the method finder.getString
THanks for the response.  My goal is to use the code to find the high and low temps (and eventually chance of rain) and then change the color of some LEDs depending on the range.  I've left the LED part out until I can figure out how to read in the right information.
I've tried searching for "High", "Low", "Forecast", which all appear (at least to me) in the source RSS feed.  If I search for "Current Conditions" that does work.
Here is my code:
//Source:
// 03.09.2012
#include <SPI.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0D, 0x73, 0xC5 };
//byte ip[] = { 10, 0, 1, 101 };
// Server Yahoo
char place[50];
char hum[30];
  // Start Ehternet
  Ethernet.begin(mac);
    // Call Wetter-API
    // Alternate access
    //client.println("GET /forecastrss?w=12893459&u=c HTTP/1.0");
    //client.println("HOST:weather.yahooapis.com\n\n");
    client.println("GET /forecastrss/60660_f.xml HTTP/1.0"); //I read on another forum that this link might provide more data
    client.println("HOST:xml.weather.yahoo.com\n\n");
    client.println();
    // Humidity
    // Place/City
    // High Temperature
   // if(finder.find("temp=") )  original
   if(finder.find("Forecast:") )
     long temperature = finder.getValue();
     Serial.print("High Temp F:  ");
    // Low Temperature
   if(finder.find("Low") )
     Serial.print("Low Temp F:  ");
  // END XML
  client.stop();
  client.flush();
  delay(60000);
CH
I suggest that you copy the XML code to your text editor. Now you can identifiy the data you want to read.
To read the current condition use the following code:
char currentcond[50];
// Current Condition
    if ( (finder.getString("<b>Current Conditions:</b><br />", "</br> ",currentcond,50)!=0) )
      Serial.print("Current Cond:  ");
      Serial.println(currentcond);
Thanks.  Yes I can get Current Conditions to print, but not anything after that.  Using your same code for instance and changing Current Conditions for Forecast won't print the Forecast, which is immediately following Current Conditions in the xml code.  I'm also interested just in the number of HIgh and Low, not all the text bit (so that I can easily apply an if statement for a number range).  Any ideas on why your code or the finder.getvalue() wont work for the Forecasted High and Lows.
Thanks.
Dan
CH
As you can see in the XML Code the data for forecast is a datastring divided by HTML-Tags <BR>
<BR /><b>Forecast:</b><BR />
Tue - Mostly Sunny. High: 77 Low: 55<br />
Wed - Partly Cloudy. High: 68 Low: 48<br />
Thu - Partly Cloudy. High: 66 Low: 50<br />
Fri - Mostly Sunny. High: 68 Low: 48<br />
Sat - Sunny. High: 69 Low: 47<br />
<br />
Therefore it isn't possible to retrieve a value for HIGH by using finder.getValue()
It needs a more complex function to read the single values.
In this case I would use a PHP-Script which reads the data and puts them in a simple xml stream. In the second step you can use your Arduino board to read the output of the xml stream and display them in the serial monitor or on a display.
Hello all,
This is my first arduino project, and I've modified the script above to output my local temperature as a voltage that I can send to another system.  Any insight as to why I'm not reading any output from pin 3 with this script?:
//Source:
// 03.09.2012
//TempRSS.pde
#include <SPI.h>
byte mac[] = { 0xXX, 0xXX, 0xXX, 0xXX, 0xXX, 0xXX };
byte ip[] = { XX, XX, XX, XX };
byte gateway[] = { XX, XX, XX, 254 };
// Server Yahoo
  // Start Ehternet
  pinMode(3, OUTPUT);
  int pwm = 0;
    // http://weather.yahooapis.com/forecastrss?w=2445915&u=f
    client.println("GET /forecastrss?w=2445915&u=f HTTP/1.0");
    client.println();
    //connection failed- insert fault?
    // Temperature
     int pwm = (temperature*2.55);
     analogWrite(3, pwm);
     //insert fault output?
  // END XML
  client.stop();
  client.flush();
  delay(60000);
Thanks!
-Matt
« Last Edit: February 04, 2013, 07:03:19 pm by m4ttflynn » Logged
Get Bitlash: http://bitlash.net
No idea.  But you might try printing the value of pwm before the analogWrite to see what's going on.
-br
Oh, by the way I'm using an UNO with a PoE ethernet shield... would I need an lcd to troubleshoot?
Thanks!
-Matt
If it were my problem I'd connect via USB for debugging and use Serial.print().
You can't debug what you can't see.
-br
Pages: [1] 2   Go Up
