Loading...
Pages: 1 2 [3]   Go Down
Author Topic: Interfacing Arduino with 74HC595 and a 7-Seg  (Read 3115 times)
Dallas, Texas
Offline Offline
God Member
View Profile
You're welcome. Keep us posted.
Logged
North York, Ontario
Offline Offline
Full Member
Arduino rocks!
View Profile
Finally got 'er done! Even had it working on the first try. Oh boy, am I happy!
Code:
#include <DallasTemperature.h>
int bottomDataPin = 5;
int bottomLatchPin = 6;
int bottomClockPin = 7;
int topLatchPin = 3;
int topClockPin = 4;
int topDataPin = 2;
int j = 1;
int toShift_Top = 0;
int toShift_Bottom = 0;
char m[4];
byte data;
byte dataArray[10];
DallasTemperature tempSensor0;
DallasTemperature tempSensor1;
  pinMode(topLatchPin, OUTPUT);
  pinMode(bottomLatchPin, OUTPUT);
  tempSensor0.begin(11);
  tempSensor1.begin(12);
  dataArray[0] = 0x3F; // 0
  dataArray[1] = 0x06; // 1
  dataArray[2] = 0x5B; // 2
  dataArray[3] = 0x4F; // 3
  dataArray[4] = 0x66; // 4
  dataArray[5] = 0x6D; // 5
  dataArray[6] = 0x7C; // 6
  dataArray[7] = 0x07; // 7
  dataArray[8] = 0x7F; // 8
  dataArray[9] = 0x67; // 9
  // clear both displays with 0's
  // top
  digitalWrite(topLatchPin, 0);
  shiftOut(topDataPin, topClockPin, dataArray[0]);
  digitalWrite(topLatchPin, 1);
  //bottom
  digitalWrite(bottomLatchPin, 0);
  shiftOut(bottomDataPin, bottomClockPin, dataArray[0]);
  digitalWrite(bottomLatchPin, 1);
  int k = 1000;
  toShift_Top = (tempSensor0.getTemperature() * 100);
  // the following code is by EmilyJane of arduino.cc forums
  int temp = toShift_Top;
  for (int i = 3; i >= 0; i--)
    m[i] = temp / k;
    temp = temp - (m[i] * k);
    k = k / 10;
  // end
  shiftOut(topDataPin, topClockPin, dataArray[m[0]]);
  shiftOut(topDataPin, topClockPin, dataArray[m[1]]);
  shiftOut(topDataPin, topClockPin, dataArray[m[2]]);
  shiftOut(topDataPin, topClockPin, dataArray[m[3]]);
  k = 1000;
  toShift_Bottom = (tempSensor1.getTemperature() * 100);
  // again, the following code is by EmilyJane of arduino.cc forums
  temp = toShift_Bottom;
    m[i] = temp / k;
    k = k / 10;
  // end
  shiftOut(bottomDataPin, bottomClockPin, dataArray[m[0]]);
  shiftOut(bottomDataPin, bottomClockPin, dataArray[m[1]]);
  shiftOut(bottomDataPin, bottomClockPin, dataArray[m[2]]);
  shiftOut(bottomDataPin, bottomClockPin, dataArray[m[3]]);
// the heart of the program
void shiftOut(int myDataPin, int myClockPin, byte myDataOut)
  // This shifts 8 bits out MSB first,
  //on the rising edge of the clock,
  //clock idles low
  //internal function setup
  int i=0;
  int pinState;
  pinMode(myClockPin, OUTPUT);
  pinMode(myDataPin, OUTPUT);
  //clear everything out just in case to
  //prepare shift register for bit shifting
  digitalWrite(myDataPin, 0);
  digitalWrite(myClockPin, 0);
  //for each bit in the byte myDataOut?
  //NOTICE THAT WE ARE COUNTING DOWN in our for loop
  //This means that %00000001 or "1" will go through such
  //that it will be pin Q0 that lights.
  for (i=7; i>=0; i--)  {
    //if the value passed to myDataOut and a bitmask result
    // true then... so if we are at i=6 and our value is
    // %11010100 it would the code compares it to %01000000
    // and proceeds to set pinState to 1.
    if ( myDataOut & (1<<i) ) {
      pinState= 1;
    else {
      pinState= 0;
    //Sets the pin to HIGH or LOW depending on pinState
    digitalWrite(myDataPin, pinState);
    //register shifts bits on upstroke of clock pin
    digitalWrite(myClockPin, 1);
    //zero the data pin after shift to prevent bleed through
  //stop shifting
« Last Edit: July 23, 2009, 09:02:19 pm by SpikedCola » Logged
Dallas, Texas
Offline Offline
God Member
View Profile
Wow! Beautiful job. Congratulations!
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
