Offline
Newbie
« on: December 08, 2012, 11:39:44 am » |
Could you tell me why this simple code put onboard Led 13 always on ?
/* * * Controle d'un relai après un certain temps * */ int pinRelai = 31; // commande du relai (via transistor P2N2222AG)
void setup() { pinMode( pinRelai, OUTPUT ); }
void loop() { delay(5000); digitalWrite( pinRelai, HIGH ); delay(5000); digitalWrite( pinRelai, LOW ); }
Logged
0
Offline
God Member
Get Bitlash: http://bitlash.net
« Reply #1 on: December 08, 2012, 11:49:25 am » |
What size resistor do you have connecting the digital output pin to the base of the transistor?
-br
Logged
Offline
Newbie
« Reply #2 on: December 08, 2012, 12:16:27 pm » |
10k ohm
Logged
0
Offline
God Member
« Reply #3 on: December 08, 2012, 12:26:47 pm » |
I'm stumped. An interesting mystery. The relay is happy, right?
-br
Logged
Offline
Newbie
« Reply #4 on: December 08, 2012, 12:28:39 pm » |
Yes relay does function.
With some code, Led is on, with other it's off
Strange
Thierry
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #5 on: December 08, 2012, 12:43:08 pm » |
Strange Not really. Whether the pin is INPUT or OUTPUT matters. Whether the pin is HIGH or LOW matters. Without seeing the two different codes, all we can do is assume that it is perfectly normal.
Logged
Johannesburg UTC+2
Offline
Edison Member
« Reply #6 on: December 08, 2012, 12:52:29 pm » |
I have a Uno and find that with sketches which don't even refer to that pin at all, the built-in led on 13 is on more often than not. I stick these lines in at the top of each sketch, because having that led on when I don't want it on, annoys the cr@p out of me! pinMode(13, OUTPUT); digitalWrite(13, LOW);
Logged
IT Crowd: Roy... "Have you tried turning it off and on again?" Moss.. "Have you tried forcing an unexpected reboot?"
0
Offline
God Member
« Reply #7 on: December 08, 2012, 12:55:33 pm » |
Sounds like a bootloader bug. Worth reporting if it's an official Arduino board.
-br
Logged
Offline
Newbie
« Reply #8 on: December 08, 2012, 01:06:02 pm » |
--> PaulS
You have an example of code in my post. I juste do copy-paste as a new program, run it and Led will light
Logged
Offline
Newbie
« Reply #9 on: December 08, 2012, 01:07:24 pm » |
--> JimboZA
Nice to meet another one with same problem :-)
Thierry
Logged
Germany
Offline
Newbie
« Reply #10 on: January 28, 2013, 01:56:18 pm » |
hi all,
i just received my arduino mega 2560 r3 and led on pin 13 is always on, even with "bare minimum" sketch. when i use the blink example it blinks correctly.
have you found any solution to this? is that the only problem you have or might this be just the tip of the iceberg and the whole board is flawed?
cheers, stefan
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #11 on: January 28, 2013, 06:37:02 pm » |
I drug out a selection of Arduinos - a Duemilanove, a Micro, a Mega, a Leonardo, a Due, and an Esplora. I loaded the same sketch onto each one. On the Due, the LED on pin 13 stayed on. On all the others, the LED on pin 13 was off while the sketch was running. Changing the pin from 31 to 13, for each board, caused the onboard LED to flash, as expected.
I guess, then, that JimboZA's suggestion is what you need to do, if having the onboard LED on bothers you.
Logged
Germany
Offline
Newbie
« Reply #12 on: January 28, 2013, 06:48:41 pm » |
hi Paul, whoaa, thanks for your investigation! so pin13 is off on your MEGA but on on the DUE... seems random to me  a resistor from pin 13 to ground "solves" the problem, i just hope that there aren't any underlying defects that cause this behavior. thanks again, stefan
Logged
Seattle, WA USA
Online
Brattain Member
Seattle, WA USA
« Reply #13 on: January 28, 2013, 06:55:16 pm » |
a resistor from pin 13 to ground "solves" the problem That is what JimboZA's code does, in effect, but all in software.
Logged
Offline
Sr. Member
« Reply #14 on: January 28, 2013, 07:44:32 pm » |
Could a floating pin somehow drive the LED?
Logged
