Loading...
Pages: [1]   Go Down
Author Topic: Corruption of signals over long wires  (Read 284 times)
Sussex UK / CT USA
Offline Offline
Edison Member
Forums forever
View Profile
WWW
Suppose I have an Arduino in my living room and a 50' wire to a doorbell type swich, normally open.
Are there any steps I can take to protect the Arduino from "seeing" false switch closures arising from voltages induced in that long wire (read "antenna") when big motors around the house (heating pump, refrigerator) throw out "noise"?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Yes
http://www.thebox.myzen.co.uk/Tutorial/Protection.html
Also adding capacitors at the arduino end can help. Also consider using the analogue input to detect the push switch. That way you can set your own thresholds instead of having them set for you by the digital input pins.
Logged
USA
Offline Offline
Jr. Member
Who is John Galt?
View Profile
Use the same noise-suppression technique seen in rs-422 wiring that makes it superior to rs-232 wiring.
See: http://en.wikipedia.org/wiki/Differential_signaling
Logged
Lancashire, UK
Offline Offline
Edison Member
View Profile
WWW
You could decrease the value of your pullup/pulldown resistor.  Hold the sucker high or low by brute force and ignorance.......  smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
