Hello,
This template may be useful to someone, who started to play with Arduino IDE but wants to change to Code::Blocks.
Set up for Windows:
Create an ArduinoProject dir in the
C:\Documents and Settings\<your login name>\Application Data\codeblocks\UserTemplates
directory
In this dir create two empty files:
start.cpp
ArduinoProject.cbp
Copy into start.cpp the lines below:
extern "C" void __cxa_pure_virtual(void); //for C++ defines
void __cxa_pure_virtual(void) {};
#include <WProgram.h>
Serial.println("Hello from Arduino Code::Blocks template");
copy into ArduinoProject.cbp the lines below:
<?xml version="1.0" encoding="UTF-8" standalone="yes" ?>
<CodeBlocks_project_file>
<FileVersion major="1" minor="6" />
<Project>
<Option title="ArduinoProject" />
<Option pch_mode="2" />
<Option compiler="avrgcc" />
<Build>
<Target title="Debug">
<Option output="bin\Debug\ArduinoProject.elf" prefix_auto="1" extension_auto="0" />
<Option object_output="obj\Debug\" />
<Option type="1" />
</Target>
<Target title="Release">
<Option output="bin\Release\ArduinoProject.elf" prefix_auto="1" extension_auto="0" />
<Option object_output="obj\Release\" />
<Option type="1" />
<ExtraCommands>
<Add after="avr-size --mcu=atmega328p --format=avr $(TARGET_OUTPUT_FILE)" />
<Add after="avr-objcopy -O ihex -R .eeprom -R .eesafe $(TARGET_OUTPUT_FILE) $(TARGET_OUTPUT_FILE).hex" />
<Add after="avr-objcopy --no-change-warnings -j .eeprom --change-section-lma .eeprom=0 -O ihex $(TARGET_OUTPUT_FILE) $(TARGET_OUTPUT_FILE).eep.hex" />
<Add after='cmd /c "avr-objdump -h -S $(TARGET_OUTPUT_FILE) > $(TARGET_OUTPUT_FILE).lss"' />
<Add after="C:\_apps\arduino-0018\hardware\tools\avr\bin\avrdude.exe -CC:\_apps\arduino-0018\hardware\tools\avr\etc\avrdude.conf -v -v -v -v -pm328p -cstk500v1 -P\\.\COM4 -b 57600 -D -Uflash:w:${PROJECT_DIR}/${TARGET_OUTPUT_DIR}/${TARGET_OUTPUT_BASENAME}.elf.hex:a" />
<Mode after="always" />
</ExtraCommands>
</Target>
</Build>
<Compiler>
<Add option="-Os" />
<Add option="-Wall" />
<Add option="-mmcu=atmega328p" />
<Add option="-DF_CPU=16000000UL" />
</Compiler>
<Linker>
<Add option="-Wl,-Map=$(TARGET_OUTPUT_FILE).map,--cref" />
<Add library="C:\_apps\arduino-0018\libArduinoCoreAT328p\core.a" />
</Linker>
<ExtraCommands>
</ExtraCommands>
<Unit filename="start.cpp">
<Option compilerVar="CC" />
</Unit>
<Extensions>
<code_completion />
<debugger />
</Extensions>
</Project>
</CodeBlocks_project_file>
Edit ArduinoProject.cbp file:
Replace C:\_apps\arduino-0018\ with your Arduino install directory
Replace C:\_apps\arduino-0018\libArduinoCoreAT328p\ with the directory where your Arduino IDE made the core.a file
Replace COM4 to the port of your arduino bord
Usage:
Run Code::Blocks
File menu->New->From template , choose User templates on the left and ArduinoProject on the right. When finished,
Build menu->Select target ->Release
Build menu->Build
After building, it starts to upload your program onto the arduino board.
Run Arduino IDE and click on Serial Monitor.
If you see in Serial Monitor the text:
it works.
Please take into account, that I am new in Arduino, in C++ and Code::Blocks.
