I realise this may be too late to help the original poster, but since searching for 'vector' (as I did) brings you here, I'll post this for others:
It's relatively simple to write your own Vector class if you need basic functionality (no iterators, removing items once added etc.). The following class allows you to define your own Vector<AnyType>, push_back() objects and recall them with the [] notation.
// Minimal class to replace std::vector
template<typename Data>
class Vector {
size_t d_size; // Stores no. of actually stored objects
size_t d_capacity; // Stores allocated capacity
Data *d_data; // Stores data
public:
Vector() : d_size(0), d_capacity(0), d_data(0) {}; // Default constructor
Vector(Vector const &other) : d_size(other.d_size), d_capacity(other.d_capacity), d_data(0) { d_data = (Data *)malloc(d_capacity*sizeof(Data)); memcpy(d_data, other.d_data, d_size*sizeof(Data)); }; // Copy constuctor
~Vector() { free(d_data); }; // Destructor
Vector &operator=(Vector const &other) { free(d_data); d_size = other.d_size; d_capacity = other.d_capacity; d_data = (Data *)malloc(d_capacity*sizeof(Data)); memcpy(d_data, other.d_data, d_size*sizeof(Data)); return *this; }; // Needed for memory management
void push_back(Data const &x) { if (d_capacity == d_size) resize(); d_data[d_size++] = x; }; // Adds new value. If needed, allocates more space
size_t size() const { return d_size; }; // Size getter
Data const &operator[](size_t idx) const { return d_data[idx]; }; // Const getter
Data &operator[](size_t idx) { return d_data[idx]; }; // Changeable getter
private:
void resize() { d_capacity = d_capacity ? d_capacity*2 : 1; Data *newdata = (Data *)malloc(d_capacity*sizeof(Data)); memcpy(newdata, d_data, d_size * sizeof(Data)); free(d_data); d_data = newdata; };// Allocates double the old space
Note that due to memory constraints it would be unwise to store large objects. Also note that due to differences between free and delete[], the destructor of objects stored in a Vector might not be called. Be careful when storing objects which contain allocated memory.
An example of usage is given below. This loops through the numbers 2 to 100, storing all prime numbers in the Vector "prime" and meanwhile having the led-light (on the Uno) blink them all out (so first it blinks twice, then 3 times, etc).
// Example of Vector usage: store prime numbers and blink LED
// initialize the digital pin as an output.
// Pin 13 has an LED connected on most Arduino boards:
pinMode(13, OUTPUT);
void blink(size_t n, size_t d = 1000) {
for (size_t idx = 0; idx < n; ++idx) {
digitalWrite(13, HIGH);
delay(d/2);
digitalWrite(13, LOW);
delay(d/2);
Vector<size_t> prime;
for (size_t num = 2; num < 100; ++num) {
boolean isPrime = true;
for (size_t idx = 0; idx < prime.size(); ++idx)
if (!(num % prime[idx])) {
isPrime = false;
if (!isPrime)
continue;
prime.push_back(num);
blink(num);
Edit: Added memory management for copy constructor and assignment-operator. We wouldn't want that to fail...
